电子发烧友论坛|
嗨,我有一个带有模块85093-60005的Ecal 85093B和一个带有最新版本A.06.04.32的PNA E8357A。
当我尝试安装Ecal时,开始复制文件,然后在查找文件时停止:Agecalv1.sys,我无法找到此文件。 我在哪里可以得到这个? 谢谢。 以上来自于谷歌翻译 以下为原文 Hi, I have an Ecal 85093B with module 85093-60005 an the PNA E8357A with the latest version A.06.04.32. When I try to install the Ecal starts copying the files then stop when looking for the file: Agecalv1.sys and I cant find this file. Where can I get this?. Thanks. |
4个回答
我相信这是老司机的一部分,你应该使用新的;
但我认为要么会奏效。 不幸的是,我不记得所有的细节。 也许布拉德会在这里说话。 同时,我在这里发布了一个包含所有文件(对于旧驱动程序)的zip文件:http://69.12.214.222/ecal/忽略同样位于那里的.exe文件。 以上来自于谷歌翻译 以下为原文 I believe that is part of the old driver and you should be using the newer one; but I think either will work. Unfortunately, I don't remember all the details. Maybe Brad will chime in here. Meanwhile, I have posted a zip file with all the files (for the older driver) here: http://69.12.214.222/ecal/ Ignore the .exe file that is also located there. |
仅供参考,ECal的旧设备驱动程序在PNA-X和更新的PNA上使用ECAL作为噪声调谐器不起作用,它在Windows 7下也不起作用,但对于E835xA PNA(Windows XP),它仍然可以正常工作 。 关于电池问题,我不知道,所以我们必须看看John(jvall)对此的看法。 最好的问候,布拉德 以上来自于谷歌翻译 以下为原文 FYI, that older device driver for ECal does not work with use of ECals as noise tuners on PNA-X and newer PNAs and it also does not work under Windows 7, but for E835xA PNAs (Windows XP) it still works fine as you see. About the battery question I don't know so we'll have to see what John (jvall) thinks about that. Best regards, Brad |
uwyywefwd 发表于 2018-9-24 18:19 谢谢Brad。 就电池而言,它位于CPU板上。 这是一个普通的纽扣锂电池...我认为这个数字是2032,虽然2025也可以使用,但容量略有减少。 阅读有关卸下CPU的说明,因为它并不明显。 以上来自于谷歌翻译 以下为原文 Thanks Brad. As far as the battery goes, it is on the CPU board. It is a common button lithium battery...I think the number is 2032, although the 2025 will also work but has slightly less capacity. Read the instructions on removing the CPU since it is not obvious. |
在PNA中更换备用电池(我有比电池BR2335小3V),你需要抬起A6板,然后取出HD连接器,然后拿回后面的螺丝并拔出CPU。 IT有常规SDRAM笔记本电脑类型,但你不能添加更多内存,因为处理器不会占用它有512 Kb。 当第一次打开它时说没有检测到序列号并且S11中出现了很多噪音,然后让我做一个程序(系统服务选项启用)然后(查看选项更改序列)我没有遵循这一点。 所以我只是把日期/时间重新启动,现在很好。 以上来自于谷歌翻译 以下为原文 Replaced the Back up batt.(I had a 3V. smaller one than stock BR2335) in the PNA you need to lift the A6 board then take the HD connector out then take the back screws and pull the CPU. IT has regular SDRAM laptops type but you cant add more memory as the processor will not take it it has 512 Kb. When first turned on it said no serial number detected and a lot of noise appered in S11, then ask me to do a procedure (System Service Option Enable) then (view options change serial) I did not follow that. So I just put the date/time reboot and it is fine now. |
只有小组成员才能发言,加入小组>>
285 浏览 0 评论
1870 浏览 0 评论
2756 浏览 1 评论
2658 浏览 1 评论
2478 浏览 5 评论
1871浏览 0评论
434浏览 0评论
287浏览 0评论
/9
GMT+8, 2025-12-14 10:15 , Processed in 1.247537 second(s), Total 80, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2714
