您好,我正在寻找小PSoC开发板订购,但没有找到任何。如果有人知道更小的PSoC板,那么PSoC 3启动工具包我真的很感激帮助。这就是我决定从PSoC组件中收集自己的PCB的原因。我想订购CY8C3666 AXI-040组件,但我注意到引脚非常接近对方,这是不可能手动收集。有可能订购引脚彼此远离的组件,并且可以手动收集吗?我刚刚开始会很感激,如果有人可以帮我到哪里去寻找所有的组件?提前感谢
订购用于收集PCB的组件 以上来自于百度翻译 以下为原文 Hello I was looking for small PSoC development board to order, but couldn't find any. If anyone knows smaller PSoC board then PSoC 3 starter kit I'd really appreciate the help. That's the reason that I decided to collect my own PCB from PSoC components. I'm thinking to order CY8C3866AXI-040 component, but I noticed that the pins are very close to each other and it's impossible to collect manually. Is it possible to order components which pins are far from each other and would be possible to collect manually? I'm just starting and would really appreciate if someone could help me where to look for all the components? Thanks in advance |
27个回答
嗨,Gurgen,你说的CY8C3866AXI-040”,其中有100pins TQFP封装。引脚之间0.5mm,比MLF封装宽。它可以小心地用手焊接。如你所知,SSOP pakage更宽,1.27毫米。PVI-021和PVI-070具有SSOP封装。你会选择这个装置吗?
以上来自于百度翻译 以下为原文 Hi Gurgen, You said "CY8C3866AXI-040", Which has 100pins TQFP package. Between pins is 0.5mm, It's rather wide than MLF package. It can soldering by hand with carefully. As you know, SSOP pakage is more wide, 1.27mm. PVI-021 and PVI-070 has SSOP package. Would you chose this device? |
看起来最好用PSoC重新设计控制器。PSoC岩石
以上来自于百度翻译 以下为原文 Looks like it is better to redesign the controller with PSoC.. PSoC rocks...... |
你在软件论坛,但是你的请求有点像硬件,不是吗?
到目前为止,只有PSOC1器件进入DIL封装,优选地是CY8C9466 PXOTH。有一个开发套件PSoC1耗资40美元。PSOS1与PSOC3/4/5相比的缺点是: 只有8位CPU很少寄存器缓慢执行没有内在的调试能力(或者你必须通过冰块) 在套件库中已经有PSoC板,最便宜的是PSoC4先锋套件,它甚至比PSoC1套件还要便宜,它可以根据您的需要进行编程,并且可以用断点、变量检查等调试程序。 看看这里的工具包:HTTP://www. CyPress?ID=2218和源=头 这里是:HTTP://www. CyPress?ID=4749 鲍勃 以上来自于百度翻译 以下为原文 You are here in the Software - forum but your request smells a bit like hardware, isn't it? Until now, only PSoC1 devices come in DIL-package, preferrably the CY8C29466-pxsomething. There is a development kit for PSoC1 costing $40. The disadvantages using PSoC1 compared to PSoC3/4/5 are: Only 8-bit CPU Few registers slow execution No intrinsic debug-capabilities (or you have to by an ICE-Cube) There are already PSoC boards in the Kit-store the cheapest is the PSoC4 Pioneer kit which even costs less than the PSoC1 kit, It is programmable to your needs and you can debug your programs with breakpoints, variable inspection etc. Have a look at the kits here: http://www.cypress.com/?id=2218&source=header and here: http://www.cypress.com/?id=4749 Bob |
如果YIUU正在寻找开发板,你可能想看看
FreeSoc(http://freesoc.net/)为psoc5lp洛基(http://www.arachnidlabs.com/blog/2013/01/22/introducing-loki/)也psoc5lp schmartboard(http://www.schmartboard.com/index.asp?页= products_dev &;ID = 648)为PSoC3和五,也可填充psoc5lp ezpsoc(http://kmmankad.blogspot.de/2012/12/psoc35-hardware-options.html)为PSoC3在SSOP,但你需要建立它自己的PSoCMini(http://dangerousprototypes.com/forum/viewtopic.php?F = 56 &;t = 2823)也建立自己的Powerfulboard(http://www.powerfulboard.com/)在dip40大小PSoC3和5lp 以上来自于百度翻译 以下为原文 If yoiu are looking for development board, you might want to look at
保持冷静,使用热烙铁进行焊接:D
让我们回到话题上来。 用于浸渍包装。您可能需要使用PSoC1。TQFP是可行的,只需要耐心和实践。 以上来自于百度翻译 以下为原文 Keep cool, use HOT iron for soldering :D Let's back to the topic. For DIP package. you may need to use PSoC1. The TQFP, it is doable, just need patient and practice. |
如果你谷歌“YouTube表面贴装焊接”你会得到
在手工焊接上的许多点击。 在我的经验中,商店里最重要的工具是一个大的5—10X放大镜。 光学,你可以使用在精细沥青包装。 问候,Dana。 以上来自于百度翻译 以下为原文 If you google "youtube surface mount soldering" you will get a number of hits on hand soldering. In my experience most important tool in shop is a large 5 - 10X magnifying optic you can use while working on fine pitch packages. Regards, Dana. |
认真的,热空气浏览器和奶油焊膏是方便的。我可以使用它的MLF包喜欢27894。(我可以拖动右下角:-)
以上来自于百度翻译 以下为原文 Seriously, Hot air brower and cream solder paste is handy. I can work with it for MLF package likes a 27894. ( I can drag under-right corner :-) |
TQFP对于士兵来说并不容易,但它是可行的,我们制作了自己的样本,有时需要自己更换芯片。然而,也有一些现成的董事会的建议。
以上来自于百度翻译 以下为原文 TQFP is not easy for soldier but it is doable, we made our own samples and sometimes need to replace chips ourself. However, there are some ready made boards as suggest. |
PSoC4S在易于焊接QFPs,他们可以订购在赛普斯商店和经销商。SSOP和其他软件包也将有设备,但目前还没有。
热空气是伟大的,但我更喜欢使用一个良好的温度控制焊锡和文件夹通量。客家人价廉物美。焊剂在焊接时极为重要。 如果您不是舒适的焊接和设计您自己的板。我会重新获得FieloSoc迷你。它确实很小,里面有PSoC5和程序员。SmiMad板也是好的。 最后,PopNeNoKIT是从PSoC开始的最经济的方式,但它只运行PSoC4。 以上来自于百度翻译 以下为原文 PSOC4s come in easy to solder QFPs, they are available to order on the cypress store and on distriutors. There will also be devices in SSOP and other packages but they are not available yet. Hot air is great, but I prefer using a good temperature controlled solder iron and folder flux. The Hakkos are cheap and have good quality. Flux is extremelly important when soldering. If you are not confortable soldering and designning your own board. I would recomend getting the FREESOC mini. it is really small with a psoc5 and programmer in it. Also the Schmart boards are good. Finally the Pionner kit s the most economical way to start with psocs, but it only sports a PSOC4. |
非常感谢,这真的很有用。
我知道所有的建议。 我想选择ZpSoC(HTTP://KMMAKAD.BogSPo.De/2012/12/PSoC35-HasRead Opth.HTML)。 据我所知,我可以用MIXPROP3编程,也可以进行USB通信。还有我可以使用的好的示意图。 谢谢泽塔。 以上来自于百度翻译 以下为原文 Thank you very much this was really helpfull. I though about all suggestions. I'm thinking to choose [size=10.666667938232422px]EzPSoC (http://kmmankad.blogspot.de/2012/12/psoc35-hardware-options.html[size=10.666667938232422px]) done by Zeta. As I understand I can programm it with miniprog3 and also has USB communication. There is also nice schematic which I can use. Thanks Zeta for that. |
最近我焊接100引脚的TSOP封装(0.5mm间距)的手只花了5分钟左右。基本上你只需要良好的焊剂和焊料灯芯…
以上来自于百度翻译 以下为原文 I recently soldered a 100 pin TSOP package (0.5mm pitch) by hand - took only 5 minutes or so. You basically need only good flux and some solder wick... |
不客气。但是EZPSoC3是由BykMunkad设计和建造的。
实际上,他是第一个为PSoC3设备发布开源板设计的人。用他的设计只是确保你使用一个旧的面具,否则,UBLIN将短与USB连接器的情况。 以上来自于百度翻译 以下为原文 You're welcome. But the EzPSoC3 was designed and build by kmmankad. he was actually the first one to post an open source board design for a PSoC3 device. With his design just make sure you use a older mask as otherwise the USBlines will short with the USB connector case. |
我发现您可以使用“使用”焊锡芯来进行焊接。
用大量的焊剂,将焊料芯放在引脚的顶部,并在焊料芯的顶部使用烙铁,芯上的焊料将转移到引脚和板上。 我仍然在尝试和使用不同的焊锡芯。(您需要首先通过焊接角将芯片的位置固定到PCB)。 以上来自于百度翻译 以下为原文 I found that you can use a "USED" solder wick to do the soldering. With a lot of flux, place the solder wick on the top of the pins and use a soldering iron on the top of the solder wick, the solder on the wick will transfer to the pins and the board. I am still pratising and trying with different USED solder wick. (You need to fix the location of the chip to the PCB by solder the corners first) |
这是我们的广告“朋友”的另一个尝试进入门口吗?
鲍勃 以上来自于百度翻译 以下为原文 Is this another try of our advertising "friend" to get a foot into the door? Bob |
我甚至看到一个“焊接站”由厨房炊具(调节)和煎锅盖。到底是什么使我震惊的是它的工作。我承认调节器是相当大的一个,远远超出了我设计1.5千瓦闭环调节器的能力。
鲍勃 以上来自于百度翻译 以下为原文 I even saw a "Soldering Station" built of a kitchen-cooktop (regulated) and a frying-pan with a lid. What really did astonish me was that it DID work. I admitt the regulator was a rather large one and far off my capabilities of designing a 1.5kW closed-loop regulator. Bob |
只有小组成员才能发言,加入小组>>
741个成员聚集在这个小组
加入小组2002 浏览 1 评论
1759 浏览 1 评论
3543 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1693 浏览 6 评论
1464 浏览 1 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
267浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
166浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
352浏览 2评论
296浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
484浏览 2评论
GMT+8, 2024-9-18 02:24 , Processed in 1.322186 second(s), Total 117, Slave 99 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
