电子发烧友论坛|
我需要生成一个与外部信号相位匹配的FPGA内部时钟。
通过相位匹配,我的意思是外部信号和内部时钟的相对相位是已知且稳定的。 有证据表明这是PLL inV5 / 6的预期使用模型。 V6时钟指南说: •IBUFG - 全局时钟输入缓冲器,MMCM将补偿此路径的延迟。 在许多地方,我们看到BUFG用作PLL的反馈。 因此,它似乎是一个预期的使用模型。 但是......支持这种用法所需的信息就此结束了。 我无法找到IBUFG(DS)的时序规格。 如果我在这个电路上运行时序分析器,时序分析器使用标准的tiOPI用于IBUFGDS以及BUFG及其网络的标准延迟。 是否有一些特殊模式的时序工具来理解“PLL魔术”? 我在这里点什么? 提前致谢。 利斯约翰逊 以上来自于谷歌翻译 以下为原文 I need to generate an FPGA internal clock that is phase matched to an external signal. By phase matched I mean that the relative phase of the external signal and the internal clock is known and stable. There is evidence that this is an intended usage model for the PLL in V5/6. The V6 clocking guide it says: • IBUFG - Global clock input buffer, the MMCM will compensate the delay of this path. And in many places we see a BUFG used as feedback to the PLL. Hence, it appears this is an intended usage model. However... the information necessary to support such a usage ends there. I can find no timing specs for an IBUFG(DS). If I run the timing analyzer on this circuit, the timing analyzer uses a standard tIOPI for the IBUFGDS and standard delays for the BUFG and its network. Is there some special mode for the timing tools to understand "PLL magic"? Am I missing something here? Thanks in advance. Leith Johnson |
2个回答
是的,IBUFG和BUFG的标准延迟将出现在时序报告中,但这些延迟将通过MMCM的负延迟抵消。
------您是否尝试在Google中输入问题? 如果没有,你应该在发布之前。太多结果? 尝试添加网站:www.xilinx.com 以上来自于谷歌翻译 以下为原文 Yes, the standard delays for the IBUFG and the BUFG will be present in the timing reports, but these will be offset with a negative delay through the MMCM.------Have you tried typing your question into Google? If not you should before posting. Too many results? Try adding site:www.xilinx.com |
你好
你试过coregen吗? 我认为这有一个时钟核心! 它有点旧,但XAPP132是您需要的基础。 http://www.xilinx.com/support/documentation/application_notes/xapp132.pdf 以上来自于谷歌翻译 以下为原文 Hi have you tried the coregen ? that I think has a clock core for doing this ! It's a little old, but XAPP132 is the basis you need. http://www.xilinx.com/support/documentation/application_notes/xapp132.pdf |
只有小组成员才能发言,加入小组>>
3115 浏览 7 评论
3405 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2870 浏览 9 评论
3961 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3055 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1324浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1166浏览 1评论
/9
GMT+8, 2025-12-1 10:51 , Processed in 0.801030 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4755
