大家好,我是学位学生,目前正在完成我的最后一个学期项目,该项目应该是Agilent VEE和SCPI代码。
我正在尝试在我的大学实验室中控制非安捷伦仪器,即DS 1102E数字示波器,并使用Agilent VEE PRO 9.3中的SCPI(可编程仪器标准命令)代码进行命令。 所有程序流程均使用SCPI代码在Agilent VEE软件中完成。 问题:1)如何使用SCPI命令在示波器屏幕上的所需位置使用跟踪模式固定光标点? 附件是我想要设置的所需光标点。 2)如何使用SCPI命令确保显示波形始终保持在固定点? 3)我可以使用SCPI命令直接设置波形的显示位置吗? 以上是我遇到的问题。 真诚地希望获得SCPI编码的建议或解决这些问题的理想选择。 感谢您的答复。 以上来自于谷歌翻译 以下为原文 Hi all, I am a degree student and currently doing my last semester project which due with Agilent VEE and SCPI code. I am trying to control the non Agilent instrument in my college' s laboratory which is DS 1102E Digital Oscilliscope and commands using SCPI (Standard Commands for Programmable Instruments) code in Agilent VEE PRO 9.3. All the program flow is done in Agilent VEE software by using SCPI code. Problems: 1) How can I fix the cursor point with track mode at my desired point on the oscilloscope screen using SCPI commands? Attachment is the desired cursor point that I wish to set. 2) How can I make sure the display waveform always stays at a fixed point using SCPI commands? 3) Can I directly set the display position for the waveform using SCPI commands? Above are my encountered problems. Sincerely hope for the suggestion of SCPI coding or ideal for solving those problems. Thank You for the reply. 附件
1个回答
我想如果你想要答案,你需要提供更多信息 - 例如我有SCPI和示波器的经验,但没有你说过的那个。
此外,SCPI被设计为标准(因此名称),但对于更深奥的功能,它们可能无法从一个制造商,甚至是同一制造商的仪器转换为另一个制造商。 我的建议是你发布一段SCPI手册来处理光标设置,以便论坛中的其他人可以建议可能产生你想要的结果的语法。 HTH,Mike Watts 以上来自于谷歌翻译 以下为原文 I think if you want an answer to this you'll need to provide more information - for example I have experience with SCPI and oscilloscopes but not with the one you stated. Also SCPI is designed to be standard ( hence the name ) but for the more esoteric functions they might not translate from one manufacturer, or even instrument from the same manufacturer, to another. My suggestion would be that you post a section of the SCPI manual which deals with cursor setting so that others in the forum can suggest syntax that might produce the result you want. HTH, Mike Watts |
只有小组成员才能发言,加入小组>>
2166 浏览 1 评论
1949 浏览 1 评论
1812 浏览 5 评论
2683 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1640 浏览 4 评论
646浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
447浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
537浏览 0评论
2336浏览 0评论
1388浏览 0评论
GMT+8, 2024-8-7 18:15 , Processed in 1.316837 second(s), Total 47, Slave 40 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
