电子发烧友论坛|
在MPLAB 8中,有一个程序员的工具栏,没有一个PROCEDE OPEN,它很容易导入一个.HEX文件,并为许多小程序制作许多零件。它与一个PROCECtiON相似,容易打开。只需要无需先选择设备。----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------“帮助页面”不容易找到关于使用ICD3作为程序员的信息,类似的问题是针对PIDIT3**,我如何导入HEX文件和DO编程?***我将接受任何HelpValdoDo
以上来自于百度翻译 以下为原文 In MPLAB 8 there is a programmer toolbar With no proyect open it is easy to import an .hex file and to program many parts for small production. It is similar and easy with a proyect open. Only need with no proyect is to select device first. -------------- With MPLABX I only found "make and program main proyect" Help page have not easy to found information about use of ICD3 as programmer Similar problem is for PicKit3 *** How can I import hex files an do programming? *** I will apreciate any help Osvaldo |
2个回答
使用带有MPLABX的IPE应用程序,Microchip从MPLABX中取出所有基本的程序员功能,因为它在IPE中。许多人质疑这是个好主意,只有微芯片似乎已经想到了。
以上来自于百度翻译 以下为原文 Use the IPE application that comes with MPLABX. Microchip pulled all the basic programmer functionality out of MPLABX because it was in IPE. Many have questioned if this was a good idea, only Microchip seem to have thought it was. |
谢谢你的回复,这是我第一次听说IPE。我将重新安装与此opisti没有收到一封电子邮件时,你的答复,因为它是在之前的职位,Osvaldo Hojvat
以上来自于百度翻译 以下为原文 Thank you for your reply. It is first time I heard about IPE. I will re-install with this option I have not received a email at the time of your reply as it was in before posts Regards, Osvaldo Hojvat |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1124浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 02:41 , Processed in 1.139321 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
915
