尝试执行公司创建的批处理文件,该文件在最新的Windows更新推送到xlinx实验室工具14.7之前工作,并且由于动态链接库(DLL)初始化例程而失败,导致错误“无法加载库libport_Execloader.dll”。
任何想法如何解决这个问题而不回滚更新? 我在另一台机器上遇到同样的错误,全新安装也包含所有最新更新。 它在网络上的旧机器上工作正常,没有推送Windows更新。 以上来自于谷歌翻译 以下为原文 Trying to execute a company created batch file that worked before the latest windows update push on xlinx lab tools 14.7 and getting the error "Failed to load library libport_Execloader.dll because of a dynamic link library (DLL) initalization routine failed. Any ideas how to fix this without rolling back the update? I get the same error on another machine with a fresh install also with all the latest updates. It works fine on older machines off the network with no windows updates pushed. |
7个回答
嗨@ bwilke,
ISE 14.7不正式支持Windows 10。 Xilinx还发布了适用于Windows 10(Windows 10 Professional和Windows 10 Enterprise)的ISE 14.7 VM,但它仅支持spartan-6。 欲了解更多信息,请访问:http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/ug1227-spartan6-vm-windows10.pdf 有一个AR在Windows 10上运行ISE 14.7作为解决方法.https://www.xilinx.com/support/answers/62380.html 它可能会或可能不会帮助你。 问候, hemangd 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi @bwilke, ISE 14.7 does not support windows 10 officially. Xilinx has also released ISE 14.7 VM which works with windows 10 (Windows 10 Professional and Windows 10 Enterprise) but it only supports spartan-6. For more info. https://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/ug1227-spartan6-vm-windows10.pdf There is one AR to run ISE 14.7 on windows 10 as a workaround. https://www.xilinx.com/support/answers/62380.html It may or may not help you. Regards, hemangd View solution in original post |
您还没有说过您使用的是哪个版本的Windows ..这是Win 7吗?
赢8? 赢10? 尽管如此,14.7实验室工具不太可能被修改为与Windows更新一起使用。 这就是我使用Linux和14.7工具的原因,因为操作系统完全稳定。 不要忘记通过接受帖子作为解决方案来尽可能地关闭线程。 以上来自于谷歌翻译 以下为原文 You haven't said what version of Windows you are using.. Is this Win 7? Win 8? Win 10? All the same, it's unlikely that the 14.7 lab tools can be modified to work with your windows update. This is why I use Linux with 14.7 tools, because the OS is completely stable. Don't forget to close a thread when possible by accepting a post as a solution. |
Windows 10并尝试运行xlinx实验室工具14.7,它在其他Windows 7机器上运行良好,并且在更新之前在这些Windows 10机器上工作正常。
我也不确定应该设置哪个环境变量路径哪个可能导致问题? 我已指出impact.exe位于此批处理文件需要启动的位置。 以上来自于谷歌翻译 以下为原文 Windows 10 and trying to run xlinx lab tools 14.7 which works fine on other windows 7 machines and did work fine on these windows 10 machines before an update. I am also unsure what enviornment variable path this should be set to which may be causing the issue? I have it pointed where impact.exe is located which this batch file needs to launch. |
嗨@ bwilke,
检查这个帖子。 这可能会对你有帮助.https://forums.xilinx.com/t5/Configuration/Impact-libPort-ExecLoader-dll-issue/td-p/873096 您可以尝试上一篇文章中提到的:在Windows 10 PC上下载Perl并使用它而不是Xilinx perl.exe 问候, hemangd 以上来自于谷歌翻译 以下为原文 Hi @bwilke, Check this thread. This may help you. https://forums.xilinx.com/t5/Configuration/Impact-libPort-ExecLoader-dll-issue/td-p/873096 You can try as mentioned in the last post of it:download Perl on Windows 10 PC and use this instead of the Xilinx perl.exe Regards, hemangd |
这是确切的错误,我正在尝试做原始海报正在做的事情。我不知道ifperl是安装在公司电脑上的选项。
我试着下载xlinx设计工具Spartan 6 ISE 14.7并仍然得到相同的错误。 是否已知ISE不能在Windows 10中运行? 从现在开始,我可能只需要在Windows 7上运行它。 以上来自于谷歌翻译 以下为原文 That is the exact error and I am trying to do what the original poster is doing. I don't know if perl is an option to install on corporate pc's. I tried to download xlinx Design tools Spartan 6 ISE 14.7 and still get the same error. Is it a known fact that ISE will not work in windows 10? I may just have to run this on the windows 7 pc's from now on. |
嗨@ bwilke,
ISE 14.7不正式支持Windows 10。 Xilinx还发布了适用于Windows 10(Windows 10 Professional和Windows 10 Enterprise)的ISE 14.7 VM,但它仅支持spartan-6。 欲了解更多信息,请访问:http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/ug1227-spartan6-vm-windows10.pdf 有一个AR在Windows 10上运行ISE 14.7作为解决方法.https://www.xilinx.com/support/answers/62380.html 它可能会或可能不会帮助你。 问候, hemangd 以上来自于谷歌翻译 以下为原文 Hi @bwilke, ISE 14.7 does not support windows 10 officially. Xilinx has also released ISE 14.7 VM which works with windows 10 (Windows 10 Professional and Windows 10 Enterprise) but it only supports spartan-6. For more info. https://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/ug1227-spartan6-vm-windows10.pdf There is one AR to run ISE 14.7 on windows 10 as a workaround. https://www.xilinx.com/support/answers/62380.html It may or may not help you. Regards, hemangd |
如果这有助于某人。
我遇到了同样的问题,但发现了一个略有不同的解决方案。 我使用的系统使用旧的ISE工具impact.exe将Vivado的.bit文件输出转换为.hex文件,以便下载到flash。 我能够解决这个问题的最好方法是在我的机器上保留一个14.3 LabTools的版本,因为它是我发现的最新版本的具有impact.exe的版本。 当我开始收到上面列出的dll错误时,这最近在Windows 10更新后停止工作。 在尝试了很多东西并阅读这些帖子后,我发现我可以通过改变我的路径来指向32位版本的impact.exe(LabTools bin nt impact.exe)而不是64位来解决这个问题 版本(LabTools bin nt64 impact.exe)。 希望这会给我带来更多的更新周期。 以上来自于谷歌翻译 以下为原文 In case this helps someone. I ran into this same problem but found a slightly different solution. The system I am using uses the old ISE tool impact.exe to convert the .bit file output from Vivado to a .hex file for downloading to flash. The best way I have been able to deal with this is to keep a version of 14.3 LabTools on my machine since it was the last version I found which has impact.exe. This recently stopped working after a Windows 10 update when I started getting the dll error listed above. After trying a number of things and reading these posts I found that I can work around this issue by changing my path to point at the 32 bit version of impact.exe (LabToolsbinntimpact.exe) instead of the 64 bit version (LabToolsbinnt64impact.exe). Hopefully this buys me a few more update cycles. |
只有小组成员才能发言,加入小组>>
2321 浏览 7 评论
2729 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2217 浏览 9 评论
3295 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2368 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
652浏览 1评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
460浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
220浏览 1评论
667浏览 0评论
1859浏览 0评论
GMT+8, 2024-9-29 05:09 , Processed in 1.349790 second(s), Total 91, Slave 74 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
