电子发烧友论坛|
嗨,我有一个CY1306A在我的董事会。我在Windows 10的C++(QT平台)中编码。我想抵制我的代码重新插入USB。
这是我的密码: 空主窗口::NeXyDATA(){//每40毫秒运行一个定时器tiG CCyUSBDevice USBDevice; 短int nNoMuts= UBStuto.DeVICECONTUTE(); if(NoMuths==1){if(UbStudio.ISOPEN()){ 长的长度=包装尺寸; ISSOKO= UBStuto.BulkEndoPT & Gt;XFEDATA((PUCHAR)XFFABORPHION in [ 0 ],长度,(CySyopktIfn*)0,FALSE); } } 但有时效果不错,有时会崩溃。 以上来自于百度翻译 以下为原文 hi, i have a CY1306A in my board. i am coding in C++(Qt platform) in windows 10. i want to resist my code on re-plugging u***. this is my code: void MainWindow::new_Data(){// run every 40 ms with a timer trig CCyUSBDevice USBDevice; short int numDevices = USBDevice.DeviceCount(); if(numDevices==1){ if(USBDevice.IsOpen()){ LONG length = PACKET_SIZE; is_ok=USBDevice.BulkInEndPt->XferData((PUCHAR)xferBuffer_in[0], length , (CCyIsoPktInfo*)0,false); } }} but sometime it works good and some times it crashes. |
2个回答
你好,
-设备是否使用CY7C68013A? -我知道NeXyDATA()是否每40ms执行一次? 每次运行此函数时,您需要在长度为PACKETHEIZIN的XFEFBURIGIN中发送大量端点的数据,对吗? 当你说“崩溃”时,你的意思是XFelDATA()返回false还是应用程序崩溃? 当做, 血竭 以上来自于百度翻译 以下为原文 Hi, - Is the device being used CY7C68013A? - I understand that new_Data() is being executed every 40mS right? - Every time this function is run, you need to send data in xferBuffer_in of length PACKET_SIZE over the Bulk endpoint right? - When you say "it crashes", do you mean the XferData() is returning false OR is the application crashes? Regards, Hemanth |
是的,设备是CY7C68013A,每40毫秒NeXyDATA()执行。我需要在散装端点上读取长度包大小的XFFabelErgin数据。崩溃意味着应用崩溃。 是否有可能在代码检查条件和等待接收数据时,USB断开和崩溃。对此有什么解决方案吗? 以上来自于百度翻译 以下为原文 yes, the device is CY7C68013A. and every 40 ms new_Data() is executed. i need to read data in xferBuffer_in of length PACKET_SIZE over the Bulk endpoint. it crashes means application crashes. is it possible that when the code check true the conditions and waiting for receive data, u*** disconnected and it crashes.is there any solution for this? |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2477 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2074 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7572浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6120浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7965浏览 2评论
/9
GMT+8, 2025-12-2 18:14 , Processed in 0.800180 second(s), Total 77, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
606
