电子发烧友论坛|
我遇到了一些问题。问题是,当您尝试保存任何文件(项目,.c,.h文件等)时,它会随机开始失败。在我使用它的几天里,它已经发生了3次。其中一个文件直接消失(从磁盘中删除),所以我需要再次创建它(幸运的是它是一个.h文件)。我有点吃亏了。
另一方面,我调试时遇到问题,而且不直观。首先要有一个直接键来编程并进入调试模式(实际上它没有直接键)。但最令人困惑和恼人的是,即使你先前在断点处停止了,运行按钮(F5)也会从开始重新启动程序...,这是第一个发生这种情况的IDE(我编程自25年以前) )。我没有看到重置和运行按钮之间的真正区别......我不得不''发现''继续按钮。我觉得这个产品不是100%完成的东西,我觉得是一个betatester :)。我希望它变得更快,因为stm8s是一个非常有趣的产品 更糟糕的是,我没有看到来自st的stm8论坛的支持,没有人回答我们的问题......,我不明白一家大公司不支持其中一种产品。 #坏支撑的问题,错误 以上来自于谷歌翻译 以下为原文 I'm having some problems with it. The problem is that randomly it starts to fail when you try to save any file (project, .c , . h files, etc). It happened to me 3 times already in the few days that i'm using it. One of the times one of the files was directly gone (deleted from disk) so i need to create it again (lucky that it was a .h file). I'm a bit scaried with it. In other hand i had problems debugging, and it is not intuitive. First thing would be nice to have a direct key to program and go to debug mode (actually it doesnt have a direct key). But the most confusing and annoying stuff is that Run button (F5) restarts the program from beggining even if you stopped previously on a breakpoint..., it is the first IDE where this happens (and i'm programming since 25+ years ago). I dont see the real difference between reset and run button... i had to ''discover'' the continue button. I feel this product as something not 100% finished and i feel like a betatester :). I hope that it gets better fast since stm8s is a very interesting product The worse thing is that i dont see support in stm8 forums from st, none is answering our questions..., I cant understand that a huge company doesnt support one of them products. #bad-support-problems-errors |
1个回答
这是ST为用户提供的公共论坛,以帮助其他用户。
事实上,没有人回答你的帖子表明他们没有看到同样的问题,因此无法帮助你。 您需要联系ST支持他们来帮助您。 http://www.st.com/internet/com/home/home.jsp 然后单击支持选项卡。填写技术支持申请表。 以上来自于谷歌翻译 以下为原文 This is a public forum provided by ST for users to help other users. The fact that no one has answered your post suggest they haven't seen the same problems and therefore cannot help you. You need to contact ST support for them to help you. http://www.st.com/internet/com/home/home.jsp and click the support tab. Fill out a technical support request form. |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1471 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1523 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3673 浏览 1 评论
3864 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2480 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
750浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
683浏览 5评论
729浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
973浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
778浏览 5评论
/9
GMT+8, 2025-12-13 21:29 , Processed in 0.988419 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2227
