电子发烧友论坛|
嗨,
我在我的STM8项目中使用STVD v 4.2.1补丁2,问题是当我想编译时,它会烦恼地停留大约10秒钟然后它开始先保存并正常编译编码。到目前为止,我无法摆脱这10秒的卡住期。 实际上,当STVD尝试保存更改时会发生这种情况。如果有人知道如何解决它或某人之前有同样的问题..? 请,任何帮助将不胜感激! 卡迪尔。 #STVD慢,同时,编译 以上来自于谷歌翻译 以下为原文 Hi, Im using STVD v 4.2.1 patch 2 on my STM8 project, the problem is when I want to compile, it gets stucked annoyingly for around 10 seconds then it starts to save first and compile the codings normally. I couldnt manage to get rid of this 10 seconds stucking period so far. This happens actually when STVD is trying to save the changes. If someone has any idea how to fix it or someone has had the same issue before..? Please, any help will be appreciated! Kadir. #stvd-slow-while-compiling |
2个回答
嗨,
我使用STVD版本4.2.0因为新版本导致了很多问题。我遇到了和你一样的问题,从某个方面来说,save命令需要花费很长时间,而不是windows认为程序被冻结但事实并非如此。我正在使用win7 64bit pro。真正的问题是我不能使用最后一个版本,因为它给了我SWIM错误,我必须运行这个...这是一个多么微不足道的,一些很好的微型支持STVD如此低质量 以上来自于谷歌翻译 以下为原文 Hi, I use STVD version 4.2.0 because new version cause me many problems. I have got the same problem as you, from a certain point the save command take so long time than windows think program is freezed but it is not. I'm using win7 64bit pro. The real problem is that I can't use the last version because it gave me SWIM error and I must run this...what a pitty, some great micro with such a low quality support on STVD |
嗨Mac,
我将STVD升级到最新版本,然后又发生了同样的事情。最后,我通过创建一个具有相同.c文件的新工作区得到了一个解决方案,然后显然它工作正常。所以似乎由于某种原因,一些STVD的设置已经改变了。希望它也适合你。 卡迪尔。 以上来自于谷歌翻译 以下为原文 Hi Mac, I upgraded STVD to the latest version and excatly the same thing happened again. Finally, I got a solution by creating a new workspace with the same .c files then apparently It worked fine. So it seems that some setting of STVD had been changed due to some reason.. Hope it works for you too. Kadir. |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
661浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
941浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-1 22:44 , Processed in 0.889537 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3355
