PB6 --------- SCL
PB7---------- SDA OLED是网上0.96寸12864的OLED,接口为IIC。 void IIC_Init(void) { RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE); RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C1, ENABLE); GPIO_InitTypeDef GPIO_InitStructure; /* 配置I2C1----------------------------------------*/ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7; //IO端口的第6和第7位 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //翻转速度为50M //GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_OD; //端口模式复用开漏输出方式,测试不行??? GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽输出 GPIO_Init(GPIOB, &GPIO_InitStructure); //用以上几个参数初始化PB口 I2C_InitTypeDef I2C_InitStructure; I2C_InitStructure.I2C_Mode = I2C_Mode_I2C;//SMBus主控模式 I2C_InitStructure.I2C_DutyCycle = I2C_DutyCycle_2;//快速模式Tlow / Thigh = 2 //I2C_InitStructure.I2C_OwnAddress1 = 0x0010;//设备自身地址 I2C_InitStructure.I2C_OwnAddress1 = OLED_ADDRESS; I2C_InitStructure.I2C_Ack = I2C_Ack_Disable;//失能应答 I2C_InitStructure.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit;//应答7位地址 I2C_InitStructure.I2C_ClockSpeed = 400000;//设置时钟频率,这个值不能高于400KHz I2C_Init(I2C1,&I2C_InitStructure);//初始化配置 /* Enable I2C1 ----------------------------------------------------*/ I2C_Cmd(I2C1, ENABLE); //使能I2C1 I2C_AcknowledgeConfig(I2C1,ENABLE); //使能IIC2应答状态 } /******************************************************************************* * 名 称: OLED_WR_Byte * 功 能: OLED写入一个数据或命令 * 形 参: Byte:数据内容;DC:命令/数据 * 返 回: 无 * 说 明: 无 * 更新日期:2016-9-16 ******************************************************************************/ void OLED_WR_Byte(u8 Byte,u8 DC) { I2C_GenerateSTART(I2C1,ENABLE);//产生I2Cx传输START条件 //while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_MODE_SELECT)); I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_MODE_SELECT); //I2C_SendData(I2C1,OLED_ADDRESS); //Slave address,SA0=0 I2C_Send7bitAddress(I2C1, OLED_ADDRESS, I2C_Direction_Transmitter); I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_MODE_SELECT); //while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED)); I2C_SendData(I2C1,DC); //write command I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_MODE_SELECT); //while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_TRANSMITTED)); I2C_SendData(I2C1,Byte); I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_MODE_SELECT); //while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_TRANSMITTED)); I2C_GenerateSTOP(I2C1,ENABLE);//产生I2Cx传输STOP条件 } 其他部分与软件模拟程序相同,不再列举。 求助: 1、使用软件模拟方法,OLED能正常使用 但使用硬件模拟,不能使用。究竟是哪出的问题。 2、GPIO模式不能设成GPIO_Mode_AF_OD,否则连软件模拟也不能正常运行,这与网说法很大出入。这又是怎么一回事? |
10个回答
首先你要明白,IIC一根是时钟先,一根数据线。时钟只是输出,可以选推挽。SDA输入输出都有,开漏。另外这样的问题应该是不难的,都有现成的代码,移植下就好。
boju81 发表于 2019-1-2 22:01 驱动OLED,找到的都是使用软件模拟的。 折腾,就是为了学习。 我这是移植驱动24C02的,但发现不能正常驱动OLED。 很多注释了的语句,就是发现调不通。 如: 发了开始信号后的 while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_MODE_SELECT)); 结果调试时一直卡在那。 |
boju81 发表于 2019-1-2 22:01 关于端口,有书写用复用推挽_AF_PP |
已调通了 。
初始化中: GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_OD; //开漏模式是有效的,如果不读入可以用PP模式 I2C_InitStructure.I2C_Ack = I2C_Ack_Enable; //这个设置成允许应答,原来不知抄的是哪家的。 写数据 在最开始增加 while(I2C_GetFLagStatus(I2C1,I2C_FLAG_BUSY)); 为了与其他IIC产品驱动通用 后面都恢复带while语句 |
那么简单的东西
抄别人的例程即可
没那么费劲的
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
1477 浏览 1 评论
1137 浏览 0 评论
1001 浏览 0 评论
STM32F405驱动DS1302时钟模块,输出时间错乱该怎么排查?
5380 浏览 2 评论
stm32f405rgt6驱动DS1302ZN出现时间错乱问题
4168 浏览 1 评论
/9
GMT+8, 2025-12-15 09:40 , Processed in 1.589462 second(s), Total 91, Slave 74 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1697
