扫一扫,分享给好友
你好,
我正在使用CelaLIT-E02的Bel-Beaon PC软件。 在我的3D视图窗口中,默认的背景图片都是灰色的,不显示为平面图。 我使用它与Windows 10 Pro & P;ThinkPad X260。 除了用户指南之外,还有什么要求吗? 最好的问候, 筱崎 以上来自于百度翻译 以下为原文 Hello, I'm using BLE-Beacon PC software for CYALKIT-E02. In my 3D view window, the default background picture is all greyed out, isn't displayed as a floor map. I'm using it with Windows 10 pro & ThinkPad X260. Is there any requirement other than written in the User Guide? Best regards, Nori Shinozaki |
3个回答
嗨,Shinozaki san
如果你的PC图形设置被称为“Acto-TeaMes”被禁用,这个问题可能会发生。 若要启用设置,请从“个性化设置”StTimg中选择任何AIR主题。 请参阅附图。 当做 福川 以上来自于百度翻译 以下为原文 Hi Shinozaki-san If your PC graphic setting called "Aero Thermes" was disabled, the issue will perhaps be occurred. To enable the setting, please select any Aero Themes from "Personalization" settomg. Refer to attached picture. Regards Eiji Fukawa |
gywefwf 发表于 2019-1-2 20:28 福川散, 非常感谢你的建议。 我检查了“主题”,我使用的是Windows标准的主题之一。 我尝试升级英特尔图形驱动程序。 我想飞机已经起飞了,但是没有任何帮助。 这个问题不仅发生在我的ThinkPad X260中,还发生在我的同事的ThinkPad X260中。 我发现我们的一个同事正在使用比我们的1代更老的ThinkPad。 我让他安装这个工具,发现这个问题不会发生在旧的PC上。 下面是OK和NG PC之间英特尔HD图形规格的差异。 OK:ThinkPad X250/Windows 10 ThinkPad X260/Windows 10 GUI工具可能需要用OpenGL/CL、DirectX版本来构建英特尔HD图形520。 最好的问候, 筱崎 以上来自于百度翻译 以下为原文 Fukawa-san, Really appreciated your advice. I checked the "Theme" and I'm using one of Windows Standard Themes. I tried to upgrade Intel Graphics Driver. I think the Aero is ON, but no help. The issue happens not only in my ThinkPad X260, but also in my co-worker's ThinkPad X260. I found one of our coworkers is using 1 generation older ThinkPad than ours. I asked him to install the tool and found out the issue doesn't happen in the older PC. Here is the differences in Intel HD Graphics specs between OK and NG PCs. OK: ThinkPad X250/Windows 10 NG: ThinkPad X260/Windows 10 The GUI tool might need to be built with OpenGL/CL, DirectX versions for Intel HD Graphics 520. Best regards, N.Shinozaki |
嗨,Shinozaki san 谢谢你的信息。我们将准备类似的规格PC来确认这个问题。 当做 睿儿 以上来自于百度翻译 以下为原文 Hi Shinozaki-san Thank you for your information. We will prepare the similar spec PC to confirm the issue. Regards Eiji |
只有小组成员才能发言,加入小组>>
743个成员聚集在这个小组
加入小组2019 浏览 1 评论
1778 浏览 1 评论
3574 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1711 浏览 6 评论
1477 浏览 1 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
406浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
288浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
371浏览 2评论
311浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
521浏览 2评论
GMT+8, 2024-10-10 02:32 , Processed in 0.792299 second(s), Total 80, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
