电子发烧友论坛|
大家好
我遇到了与此线程类似的问题,但是,即使在创建新项目后,UI滞后也会持续存在。 https://forums.xilinx.com/t5/Ins ... w/m-p/808771#M19804 即使没有模拟窗口运行,UI在打开Vivado几秒钟后仍然保持滞后。 例如,在编辑源文件时,用户输入延迟很长。 此外,与Vivado用户界面交互,如从模拟模式/关闭切换,切换源文件到编辑也会受到影响。 我正在运行Windows 10(最新更新)并拥有一台高端PC(8核1700X AMD,16GB RAM,足够的SSD空间等) 有修复吗? 以上来自于谷歌翻译 以下为原文 Hey Guys I'm experiencing a similar problem as in this thread, however, the UI lags do persist even after creating a new project. https://forums.xilinx.com/t5/Ins ... w/m-p/808771#M19804 Even without simulation window running, the UI keeps lagging after few seconds opening Vivado. For instance, there are very long and harsh user input delays while editing source files. Moreover, interacting with the Vivado User Interface like switching from simulation mode on/off, switching source files to edit are also affected. I'm running Windows 10 (latest updates) and have a high-end PC ( 8core 1700X AMD, 16gb Ram, enough SSD space etc.) Is there a fix? |
5个回答
嗨@yellemode,
在具有运行Vivado功能的系统上调试UI滞后问题通常并不容易。 这是哪个更新? 瀑布创建者有问题(链接)。 你尝试过Vivado 2017.4吗? 最初,您可以尝试WebPACK。 如果它显示相同的行为,那么某些系统环境源/资源可能是工具滞后的原因(符合Henrique的建议)。 在创建新项目之前,请使用示例设计检查运行/行为。 问候,Prathik ----------------------------------------------- ------------------------------------------------请注明 适当的帖子作为答案“接受为解决方案”,以防它有助于解决您的查询。给予您认为有用且回复导向的帖子。感谢.---------------- -------------------------------------------------- ----------------------------- 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi @yellemode, It is usually not easy to debug issues on UI lag on systems which have capability to run Vivado. Which update is this? Falls creator has problems (link). Did you try Vivado 2017.4? Initially you can try WebPACK. If it shows the same behavior then some system environment source/resource might be the cause for the tool lag (in line with Henrique's suggestion). Before creating a new project, check runs/behavior with example designs. Regards, Prathik ----------------------------------------------------------------------------------------------- Please mark the appropriate post as an answer "Accept as solution" in case it helps to resolve your query. Give Kudos to a post which you think is helpful and reply oriented. ----------------------------------------------------------------------------------------------- View solution in original post |
.....编辑源文件时,用户输入延迟很长。
尝试取消选中源文件编辑器设置中的“执行动态语法检查”。 以上来自于谷歌翻译 以下为原文 ..... there are very long and harsh user input delays while editing source files. Try unchecking "Perform dynamic syntax checking" in the settings for the source file editor. |
@yellemodeI将打开资源监视器(TaskManager /性能/资源监视器),然后密切关注任何竞争CPU功率的进程的“CPU”。
然后继续“磁盘”和“内存”。 在“磁盘活动”选项卡上,对“响应时间(毫秒)”进行排序,并检查Vivado是否在等待磁盘。 当我遇到问题时,这通常有助于修复它。 vitorian.com ---我们这样做很有趣。 总是给予赞誉。 如果您的问题得到解答,请接受解决方案。我不会回复个人信息 - 请改用论坛。 以上来自于谷歌翻译 以下为原文 @yellemode I would open Resource Monitor (TaskManager/Performance/Resource Monitor) then keep an eye on "CPU" for any process competing for CPU power. Then go on both "Disk" and "Memory". On the Disk Activity tab, sort for "Response Time (ms)" and check if Vivado is waiting for disk. When I have problems this usually helps fixing it. vitorian.com --- We do this for fun. Always give kudos. Accept as solution if your question was answered. I will not answer to personal messages - use the forums instead. |
嗨@ yellemode,
您可以尝试删除用户主页中的.Xilinx目录并重启机器吗? 此目录将类似于C: Users hemangd AppData Roaming Xilinx Vivado 问候, hemangd 以上来自于谷歌翻译 以下为原文 Hi @yellemode, Can you try to delete the .Xilinx directory in my User Home and reboot the machine? This directory will be like C:UsershemangdAppDataRoamingXilinxVivado Regards, hemangd |
嗨@yellemode,
在具有运行Vivado功能的系统上调试UI滞后问题通常并不容易。 这是哪个更新? 瀑布创建者有问题(链接)。 你尝试过Vivado 2017.4吗? 最初,您可以尝试WebPACK。 如果它显示相同的行为,那么某些系统环境源/资源可能是工具滞后的原因(符合Henrique的建议)。 在创建新项目之前,请使用示例设计检查运行/行为。 问候,Prathik ----------------------------------------------- ------------------------------------------------请注明 适当的帖子作为答案“接受为解决方案”,以防它有助于解决您的查询。给予您认为有用且回复导向的帖子。感谢.---------------- -------------------------------------------------- ----------------------------- 以上来自于谷歌翻译 以下为原文 Hi @yellemode, It is usually not easy to debug issues on UI lag on systems which have capability to run Vivado. Which update is this? Falls creator has problems (link). Did you try Vivado 2017.4? Initially you can try WebPACK. If it shows the same behavior then some system environment source/resource might be the cause for the tool lag (in line with Henrique's suggestion). Before creating a new project, check runs/behavior with example designs. Regards, Prathik ----------------------------------------------------------------------------------------------- Please mark the appropriate post as an answer "Accept as solution" in case it helps to resolve your query. Give Kudos to a post which you think is helpful and reply oriented. ----------------------------------------------------------------------------------------------- |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2874 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-2 07:05 , Processed in 0.801968 second(s), Total 82, Slave 65 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2661
