电子发烧友论坛|
我正在运行ISE p.20131013并且我正在尝试设置所有内容以便我可以编程我的Spartan 6.当我打开项目管理器时,我得到以下弹出窗口:
当我点击确定没有任何东西发射。 另外,当我点击管理许可证时,没有任 我该怎么办呢? 作为旁注,我将尝试获得运行该软件的学生许可证。 以上来自于谷歌翻译 以下为原文 I am running ISE p.20131013 and am trying to get everything set up so I can program my Spartan 6. When I open the project manager I get the following pop-up: when I click ok nothing launches though. Also when I click manage license nothing happens. How can I go about fixing this? As a side note I am going to try to get a student license to run the software. |
7个回答
嗨@ tylerelectronics1-,
嗯......你是否安装了运行该工具的许可证? 您是否在XLCM中看到许可证? 如果您有.lic文件,请先尝试通过XLCM安装它并重新启动该工具。 谢谢& 问候,Prathik ----------------------------------------------- ------------------------------------------------请注明 帖子作为答案“接受为解决方案”,以防它有助于解决您的查询。帮助回答 - >给予赞誉------------------------- -------------------------------------------------- -------------------- 以上来自于谷歌翻译 以下为原文 Hi @tylerelectronics1-, Well...did you install the license to run the tool? Do you see the licenses in XLCM? If you have a .lic file try installing it first through XLCM and restart the tool. Thanks & Regards, Prathik ----------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helps to resolve your query. Helpful answer -> Give Kudos ----------------------------------------------------------------------------------------------- |
我无法安装许可证来运行该工具,因为当我点击管理许可证时没有任何反应。
此外,XLCM从未启动,这是一个问题。 它为什么不发布? 我没有得到错误代码或崩溃或任何东西。 以上来自于谷歌翻译 以下为原文 I can't install the license to run the tool because when I click manage license nothing happens. Also XLCM NEVER launches which is kind of the problem. Why isn't it launching? I don't get an error code or a crash or anything. |
你好@ tylerelectronics1-
请仔细阅读以下链接,查看几张海报提供的解决方案,希望对您有所帮助。 https://forums.xilinx.com/t5/Installation-and-Licensing/12-1-quot-Manage-License-quot-problem/td-p/77432 问候 罗希特 -------------------------------------------------- --------------------------------------------请注意 - 请注明 如果提供的信息有用,请回答“接受为解决方案”。 将Kudos发送给您认为有用且回复的帖子.------------------------------------ -------------------------------------------------- -------- RegardsRohit ------------------------------------------------- ---------------------------------------------请注意 - 请注明 答案为“接受为解决方案”,如果提供的信息是有帮助的。给予您认为有用并回复导向的帖子。感谢K-- -------------------------------------------------- ---------------------- 以上来自于谷歌翻译 以下为原文 Hi @tylerelectronics1- Please go through the below link and check the the resolutions provided by few of the posters, hope it helps you. https://forums.xilinx.com/t5/Installation-and-Licensing/12-1-quot-Manage-License-quot-problem/td-p/77432 Regards Rohit ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- Regards Rohit ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
嗨,谢谢你,
我开始关注你链接我的论坛页面,但是已经卡住了。 我下载了Dependency Walker并在ISE上运行了该软件。 我得到以下结果: 我不知道如何判断哪个依赖项是一个问题以及如何解决它。 谢谢, 泰勒 以上来自于谷歌翻译 以下为原文 Hi thankurr, I started following the forum page you linked me to, but have gotten stuck. I downloaded Dependency Walker and ran the software on ISE. I got the following result: I don't know how to tell which dependency is a problem and how to fix it. Thanks, Tyler |
你能尝试以下两个建议,看看是否有帮助: 1)在命令行或cmnd提示符下运行以下命令: cd /opt/Xilinx/12.2/ISE_DS 来源./settings64.sh 2)导航到/ Xilinx / 14.x / ISE_DS / common / bin / nt64的安装目录并运行_xlcm.exe。 添加完整的许可证路径,然后重新启动并重新运行ISE。 希望它能帮到你。 问候 罗希特 -------------------------------------------------- --------------------------------------------请注意 - 请注明 如果提供的信息有用,请回答“接受为解决方案”。 将Kudos发送给您认为有用且回复的帖子.------------------------------------ -------------------------------------------------- -------- RegardsRohit ------------------------------------------------- ---------------------------------------------请注意 - 请注明 答案为“接受为解决方案”,如果提供的信息是有帮助的。给予您认为有用并回复导向的帖子。感谢K-- -------------------------------------------------- ---------------------- 以上来自于谷歌翻译 以下为原文 Hi @tylerelectronics1- Can you try the below two suggestions and see if it helps: 1) Run the below command in command line or cmnd prompt: cd /opt/Xilinx/12.2/ISE_DSsource ./settings64.sh2) Navigate to the installation directory as /Xilinx/14.x/ISE_DS/common/bin/nt64 and run _xlcm.exe . Add complete license path and then restart and rerun ISE. Hope it helps you. Regards Rohit ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- Regards Rohit ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
您能否尝试打开ISE命令提示符并输入xlcm -manage,这将打开许可证管理器,然后加载许可证文件并检查是否有帮助。 您能否告诉我们您使用的操作系统? 问候, Sravanthi B 以上来自于谷歌翻译 以下为原文 Hi @tylerelectronics1-, Can you please try openning ISE command prompt and type xlcm -manage this will open license manager then load the license file and check if this helps. Can you please let us know which OS are you using? Regards, Sravanthi B |
我希望您使用的是ISE支持的操作系统之一。 如果是,xinfo可以帮助检查工具调用的系统dll是否正确,包括软件环境变量。 谢谢& 问候,Prathik ----------------------------------------------- ------------------------------------------------请注明 帖子作为答案“接受为解决方案”,以防它有助于解决您的查询。帮助回答 - >给予赞誉------------------------- -------------------------------------------------- -------------------- 以上来自于谷歌翻译 以下为原文 Hi @tylerelectronics1-, I hope you are using one of the supported OS for ISE as mentioned here. If yes, the xinfo can be helpful to check if system dlls called by the tool is proper, including the software environment variables. Thanks & Regards, Prathik ----------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helps to resolve your query. Helpful answer -> Give Kudos ----------------------------------------------------------------------------------------------- |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2874 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1326浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1168浏览 1评论
/9
GMT+8, 2025-12-2 22:37 , Processed in 0.685006 second(s), Total 84, Slave 67 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1864
