我有SWO06021-2C MPLAB XC8PRO编译器(中国)我尝试了相同的设置我设置为PRO和仍然使用免费版本重新安装MPLAB IDE,重新安装编译器都不工作,得到许可文件,已经运行WINDOWS.BAT重新启动IDE也窗口,但仍然免费版本,即使我选择PRO?有人能帮忙吗?
以上来自于百度翻译 以下为原文 I have SW006021-2C MPLAB XC8 PRO Compiler (China) i tried same setting i set to PRO and still using free version reinstalled mplab ide, reinstalled compiler all not working, got license file, already run windows.bat restarted ide also windows but still free version even i choose PRO ? can anyone help? |
19个回答
已经一周没有帮助了?下一个项目不会认真使用XC8或任何微芯片产品在有偿服务方面存在巨大的问题…
以上来自于百度翻译 以下为原文 already a week and no help? next project seriously will not use XC8 or any microchip product there is a huge problem on paid services side... |
从编译器安装目录的bin文件夹,转到命令提示符并键入“XCLS-STATE”,您应该看到类似这样的东西(如果您使用Windows版本):
以上来自于百度翻译 以下为原文 From the compiler install directory's bin folder, go to the command prompt and type in "xclm -status", you should see something like this (if you use the Windows version): |
C:程序文件(X86) Microchip xC8V1.44 BIN & GT;XCLSM - StasicMicrochip XC许可管理器版本:2.22许可路径:C:StudioDeaveMicrochip xClM/许可证/产品:XC8类型:工作站版本:1模式:CHNKEY:************- 8761产品:RLMYROAM类型:工作站版本:1模式:?在仪表板上选择为“PRO”的操作模式,我可以看到“生产图像:优化:+空间+ASM+Debug:工作站- CHN-HPA:358天(S)-按状态”,但在构建结束时,我得到消息,就像你在自由模式下编译的那样。在PRO模式下,您可以生成60%个更小的代码和400%个更快的代码。更多信息请参阅HTTP://www. MigChIP.COM/MPLABXC编译器。问题是什么?为什么它不编译为PRO?
以上来自于百度翻译 以下为原文 C:Program Files (x86)Microchipxc8v1.44bin>xclm -status Microchip XC License Manager Version: 2.22 License Path: C:ProgramDataMicrochipxclm/license/ Product: xc8 Type: Workstation Version: 1.0 Mode: chn Key: ****-****-****-8761 Product: rlm_roam Type: Workstation Version: 1.0 Mode: ? this is the result. operation mode selected as "PRO" at Dashboard i can see "Production Image: Optimization: +space +asm +debug License: Workstation - chn - HPA:358 day(s) - Press for Status" but in the end of build i get message as below You have compiled in FREE mode. Using Omniscient Code Generation that is available in PRO mode, you could have produced up to 60% smaller and 400% faster code. See http://www.microchip.com/MPLABXCcompilers for more information. so what is the problem? why it is not compiling as PRO? |
你知道如何选择PRO模式吗?它不会像魔术一样出现。抱歉-目前无法访问我的DeV.机器(否则我会给你确切的位置)。只需查看项目属性。编译器部分IIrc。
以上来自于百度翻译 以下为原文 Do you know how to select the PRO mode? It doesn't come "like magic". Sorry - currently no access to my dev. machine (otherwise I would have given you the exact location). Just have a look into the project properties. IIRC the compiler section. |
为了确保我们在同一页上-右击项目,选择ProjtProjksProtots & Gt;XC8编译器-& gt;选项类别-& gt;优化-gt;操作模式-gt;Pro
以上来自于百度翻译 以下为原文 Just to make sure we are on the same page - Right-click on the project, select Project Properties --> XC8 compiler-->Option Categories-->Optimizations-->Operation mode-->PRO |
这不是付费服务。这是一个用户论坛。对于有偿服务,你会投入支持票。许可证你会发电子邮件。但是先尝试一下建议。
以上来自于百度翻译 以下为原文 This is not paid service. It is a user forum. For paid service you would put in a support ticket. For licensing you would email. But try the suggestions first. |
已经选择和支持,并仍然编译在自由模式!如果有什么不对劲,我想知道
以上来自于百度翻译 以下为原文 already selected and PRO and still compiling in free mode! if something is wrong, i would like to know |
刚刚看到它:因为你似乎有2个条目(第二是“RLMYROAM”),你的安装有一些不寻常的东西。建议也开始支持票。
以上来自于百度翻译 以下为原文 Seeing it just now: as you seem to have 2 entries (2nd is "rlm_roam"), there is something quite unusual about your installation. Suggest too to start a support ticket. |
Switux:MigChIP.com是您联系LISSENG问题的地方。我们可以假设你激活了你的许可证吗?
以上来自于百度翻译 以下为原文 Swlicensing@microchip.com is where you contact for lisensing issues. Can we assume you actived you license? |
许可证被激活,我可以看到从357天离开,但仍然使用免费版本已经发送电子邮件,让我们看看他们什么时候会回复…
以上来自于百度翻译 以下为原文 license is activated i can see from day count 357 left but still using FREE version already send an email lets see when they will reply... |
我认为你需要用电子邮件发送SWIGRIGN @ MICCHIP.COM并向他们解释你的问题。这究竟是什么?SW06021-2C(中国)?这个东西是专门为中国的窗户建造的吗?另外,如果你使用PRO模式从头开始创建一个简单的新项目,你会得到同样的问题吗?
以上来自于百度翻译 以下为原文 I think you'll need to email swlicensing@microchip.com and explain to them your problem. What is this SW006021-2C (China) anyway? Is this something specifically built for Chinese Windows? Also, if you create a simple new project from scratch using the PRO mode, do you get the same issue? |
可能是中国的特殊版本,它是工作站许可证,已经发送电子邮件给SWIGRIGN @ MICHCHIP.等待回复。
以上来自于百度翻译 以下为原文 probably special version for China it is a workstation license and already send email to swlicensing@microchip.com waiting reply.. |
还有一件事要检查你的目的——实际的许可文件(.LIC)是ATC:StudioDeavicMicrochip xCLMICSENSE。它是一个可以打开的文本文件。运行“xCLS-HoestFipe”,确保主机ID与.LIC文件中的内容匹配。
以上来自于百度翻译 以下为原文 One more thing to check on your end - The actual license file (.lic) is at C:ProgramDataMicrochipxclmicense. It is a text file you can open. Run "xclm -hostinfo", make sure the Host ID matches what's in the .lic file. |
我猜我在中国无法到达服务器去验证,当我在VPN主机ID改变时,MPLAB服务器正在接收我的VPN主机ID,MPLAB X正在获得设备主机ID,而安装MPLAP X正在获得VPN连接的主机ID。代码…希望支持可以找出它BTW我累了BOT有或没有VPN和VPN的主机ID或PC的主机ID
以上来自于百度翻译 以下为原文 my guess cos i am in China can't reach to servers to verify and when i am on VPN host ID changes so mplab server is receiving my VPN's host id and mplab x is getting device host id while installing mplap x was getting VPN connection's host ID this is so hard to know without seeing MP lab's internal code... hope support can figure it out btw i tired bot with or without VPN and with ***'s host id or PC's host id |
我不确定这是否与VPN有关。主机ID实际上是您的计算机的MAC地址。由于每个工作站许可证允许三个不同的主机ID,我想也许您可能已经下载了错误的批处理文件为您正在使用的计算机。这就是为什么我希望你验证报告的主机ID与许可证文件中的主机ID匹配。如果你解决了这个问题,请回来给我们一个更新。你的问题听起来确实很奇怪。
以上来自于百度翻译 以下为原文 I am not sure if this has anything to do with VPN. The host ID is really just your computer's MAC address. Since each workstation license allows three different host IDs, I thought perhaps you might have downloaded wrong batch file for the computer you are using. That's why I wanted you to verify the reported host ID matches the host ID in the license file. If you ever get this problem resolved, do come back and give us an update. Your problem certainly sounds very strange. |
VPN安装虚拟以太网设备,所以主机ID改变,但MPLAX不给出任何关于选择的主机ID或状态以连接到服务器的反馈,所以我不知道什么是问题,必须是MPLAB X bug,这种许可方式完全不起作用,它们应该使用不同的技术。许可。。。
以上来自于百度翻译 以下为原文 VPN installs virtual Ethernet device so Host ID changes but mplab x doesn't give any feedback about chosen host ID or status to connecting to server so i have no idea what is the problem, gotta be a mplab x BUG, this licensing way is totally not working they should have use different technique for licensing... |
OK问题首先解决我不应该使用VPN第二个COS版本是“中国”我必须使用的编译器进来的购买DVD任何其他版本不是“中国”版本不工作。认真不知道为什么F他们选择这样的方式,但我猜是SH。营销计划…
以上来自于百度翻译 以下为原文 ok Problem solved first i am supposed to never use VPN second cos version is "China" i have to use the compiler which coming inside the purchased DVD any other versions are not "CHINA" version so not working. Seriously no idea why the f. they choose such a way but my guess is sh. marketing plan... |
TekNhanH35似乎希望你能阅读中文手册,结果你根本没有阅读手册。祝你好运。
以上来自于百度翻译 以下为原文 @ technohan35 Seems they hoped you would read the chinese manuals. Turns out you're reading no manuals at all. Good luck with that. |
这就引出了一个问题——这是否意味着你可以在任意数量的计算机上安装编译器?事实上,我喜欢这种许可模式:
以上来自于百度翻译 以下为原文 This begs a question - Does this mean you can install the compiler on any number of computers? I actually like this kind of licensing model if this is the case :) |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
514 浏览 0 评论
5819 浏览 9 评论
2351 浏览 8 评论
2238 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3546 浏览 3 评论
1170浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1123浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
893浏览 1评论
514浏览 0评论
/9
GMT+8, 2025-12-17 22:27 , Processed in 1.425321 second(s), Total 108, Slave 91 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1633
