电子发烧友论坛|
嗨,GuySi有这个项目使用PIC16F83,它几乎满了!我需要添加一些新的代码,但我需要空间…现在该项目使用HiTeC C编译器。我会通过切换到XC8 Pro获得任何东西吗?
以上来自于百度翻译 以下为原文 Hi guys I have this project using a pic16f883 and it is nearly full! I need to add some New code but i need space... Right now the project uses the hitech c compiler. Would i gain anything by switching to xc8 pro? |
5个回答
也许,很难改变PIC本身到一个新的更大的内存,但仍然兼容您的PIC16F83。
以上来自于百度翻译 以下为原文 Maybe, will it be difficult to change the PIC itself to a newer with more memory but still compatible with your pic16f883. |
我考虑切换到具有双闪存的PIC16F86,但问题是我正在开发一个ADDON模块到现有的板上,并且我想把这个模块卖给已经用PIC16F83购买主板的人…如果我能使软件适合,我可以提供一个软件升级与插件模块。把所有的单元都叫回进行硬件升级是很乏味的:
以上来自于百度翻译 以下为原文 I considered switching to the pic16f886 which has double flash memory, but the problem is that i am developing an addon module to the existing board and i want to sell this module to People Who already bought the main board with the pic16f883... If i can get the software to fit, i can offer a software upgrade together with the addon module. It would be tedious to have to call All units back for a hardware upgrade :( |
XC8的Pro模式或多或少是HiTHE实现的。(我认为HiTeCH用户被Microchip吸收了)所以我不希望通过改变编译器来进行任何重大的改变。根据你的能力,可以优化实现(源代码)本身来缩小它。但这确实是关于能力和能力的,因为83并不是“巨人”,我们可以通过PM继续讨论——如果你感兴趣的话。
以上来自于百度翻译 以下为原文 The PRO mode of XC8 is more or less what the Hitech implementation did. (I thing the Hitech people were "absorbed" by Microchip.) So I would not expect any significant change by changing the compiler. Depending on your capabilities it might be possible to optimize the implementation (source code) itself to shrink it. But this is really about ability and capability As the 83 is not that "giant", we might continue some discussion via PM - provided you are interested. |
你在使用高科技专业吗?如果是的话,可能不会。如果你正在使用免费,那么是的,你可以下载XC8编译器并激活EVE模式并尝试。如果你有一个后期版本的高科技,它应该编译很少的变化。
以上来自于百度翻译 以下为原文 Are you using Hi-Tech pro? if yes that probably not. If you are using free then yes by alot. You can download the XC8 compiler and activate the Eval Mode and try. If you have a later version of Hi-Tech it should compile with few changes. |
谢谢你的评论。我完全忘记了MPLAB编译器的评价模式。今天刚试用过,内存占用了96.4%。仍然太高了……我还没有仔细查看源代码(原来的源代码不是我自己的),我希望我能优化这个代码中的一些东西,如DUO090001建议的那样。
以上来自于百度翻译 以下为原文 Thanks for your comments. I totally forgot about the evaluation mode of the mplab compilers. Just tried it today and got 96.4% memory usage. still too high unfurtunately... I haven't had a close look on the source code yet (the original source code is not my own) and I hope I might be able to optimize somethings in this code as du00000001 suggests. |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1124浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 05:38 , Processed in 0.598729 second(s), Total 80, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2638
