电子发烧友论坛|
你好,我想在兼容模式下使用XC8编译器。但是我不知道我该怎么做。在微芯片C18到XC8迁移指南中,他们说我必须这样做:使用兼容性模式,你只需要遵循以下步骤:在MPLAB IDE1中打开你现有的MPLAB C18项目。UMIT..改变MPLAB C18驱动程序应用程序的路径,是由MPLAB C18安装的McC18.EXE应用程序到在MPLAB XC8编译器的bin目录中找到的相同命名的伪应用程序。同样以相同的方式更改MPLKIN .EXE和MPLB.EXE应用程序的路径。(不支持用MasPmiW.EXE应用程序构建的代码。)以通常的方式重建代码。我不知道在哪里可以更改路径。我在工具& gt;&选项;gt;& gt;嵌入的地方改变了McC18.EXE,但是我不知道如何以及在哪里更改MPLB.EXE和迈克林
以上来自于百度翻译 以下为原文 Hi, i'm trying to use the xc8 compiler in compatibility mode. but i don't know how i have to do that. in the Microchip C18 to XC8 Migration Guide they say i have to do: To use compatibility mode, you simply need to follow these steps: • Open your existing MPLAB C18 project in MPLAB IDE1. • Do not change the project toolsuite; continue to use the MPLAB C18 toolsuite. • Change the path for the MPLAB C18 driver application from being the mcc18.exe application installed by MPLAB C18 to the identically named fake application found in your MPLAB XC8 compiler’s bin directory. Also change the path to the mplink.exe and mplib.exe applications in the same way. (There is no support for code built with the mpasmwin.exe application.) • Rebuild your code in the usual way. i don't know where i can change the path. i tryed in the changed in tool>>options>>embeded where changed the mcc18.exe but i don't know how and where to change the mplib.exe and the mplink.exe thank's |
3个回答
嗨,只是确认:你正在使用MPLAB ID8正确吗?不是MPLAB X IDE?如我所记得的,有一个项目& GT;选择语言工具包对话框,允许您选择所需的工具套件,并调整每个组件的位置。
以上来自于百度翻译 以下为原文 Hi, Just to confirm: You are using MPLAB IDE v8 correct? Not MPLAB X IDE? As I recall, there is a Project > Select Language Toolsuite dialog which allows you to select the required tool suite, and adjust the Location of each component. Jeff. |
MPLABX有一个“文件& gt;导入& gt;MPLAB8项目”,您可以继续使用C18。XC8有一些不同的语法,可能需要对项目的源文件进行更改,尤其是对于USB(如我所发现的)。
以上来自于百度翻译 以下为原文 MPLABX has a "File > Import > MPLAB8 project" and you can continue to use C18. XC8 has some different syntax that can require changes to the source files of your project, especially for USB (as I found). |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1122浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
872浏览 1评论
473浏览 0评论
/9
GMT+8, 2025-12-1 21:29 , Processed in 0.736234 second(s), Total 46, Slave 39 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1802
