嗨,
在本文件中: https://my.st.com/content/ccc/re ... /DM00090983.pdf/jcr:内容/翻译/ en.DM00090983.pdf 声称EL_POS寄存器在电机停止时写入(注释WS)。 第11.1.2节说:'任何在电机运行时写寄存器的尝试都会导致命令被忽略而CMD_ERROR标志会上升' 但是当电机停止时(电机未运行)写入EL_POS时,命令被忽略,CMD_ERROR标志也会上升。我做了一些实验,发现EL_POS寄存器只能在电机处于HiZ状态时写入。 我不知道这是我的错还是文件错了。任何建议,将不胜感激。谢谢。 #powertep01 #el_pos 以上来自于谷歌翻译 以下为原文 Hi, In this document: https://my.st.com/content/ccc/re ... s/en.DM00090983.pdf The EL_POS register is claimed to be written when the motor is stopped (remark WS). The section 11.1.2 says: 'Any attempt to write the register when the motor is running causes the command to be ignored and the CMD_ERROR flag to rise' But when I write EL_POS when the motor is stopped ( the motor is NOT running), the command is ignored and the CMD_ERROR flag rises too. I have done some experiments, and found that the EL_POS register could be written only when the motor is in HiZ state. I have no idea if it is my fault or the document is wrong. Any suggestions would be appreciated. Thank you. #powerstep01 #el_pos |
2个回答
寄存器只能在器件处于高阻态时写入。
以上来自于谷歌翻译 以下为原文 The register can only be written when the device is in high impedance. |
所以文件是不正确的,因为我怀疑。它错误地说明条件是电机停止,而实际上条件是驱动器处于HiZ状态。
电机停止由STATUS寄存器中的MOT_STATUS位指示,实际上它是相关的HiZ位。 那应该纠正。 以上来自于谷歌翻译 以下为原文 So the documentation is incorrect as ile ile suspected. It incorrectly states that the condition is that the motor be stopped, when in fact the condition is that the driver be in HiZ state. Motor stopped is indicated by the MOT_STATUS bits in the STATUS register when in fact it is the HiZ bit that is relevant. That should be corrected. |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
2738 浏览 1 评论
3241 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1810 浏览 1 评论
3650 浏览 6 评论
6039 浏览 21 评论
1339浏览 4评论
201浏览 3评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
353浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
444浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
275浏览 2评论
GMT+8, 2024-12-25 08:01 , Processed in 1.161427 second(s), Total 78, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
