电子发烧友论坛|
大家好,
我需要将Vivado项目从PC迁移到Linux工作站。 我应该为此目的做些什么? PC上的Vivado版本:2015.4 PC:Win7 x64 谢谢! 以上来自于谷歌翻译 以下为原文 Hi All, I need to migrate Vivado projects from PC to Linux station. What should I do for that purpose? Vivado version on PC: 2015.4 PC: Win7 x64 Thank you! |
9个回答
嗨@ dmitry1417,
按照arpansur的回复中的建议存档项目。 将存档的项目传输到新计算机。 然后,如果尚未安装,请在Linux工作站中安装Vivado。 确保它是受支持的操作系统。(有关支持的操作系统,请参阅此链接的第14页:http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_4/ug973-vivado-release-notes-install-license.pdf) 如果您有另一个适用于Linux机器的Vivado许可证,请安装该许可证。 否则从旧机器返回许可证并将其放在新机器上。 (请参阅此AR以获取重新托管.lic许可证:http://www.xilinx.com/support/answers/36136.html 或此AR用于重新托管.xml许可证:http://www.xilinx.com/support/answers/61960.html) 然后在新机器中打开项目。 谢谢,Nupur ----------------------------------------------- --------------------------------------------- Google在发布之前提问 。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(点击星标)。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi @dmitry1417, Archive the project as suggested in arpansur's reply. Transfer the archived project to new machine. Then, if it is not already installed, install Vivado in the Linux station. Make sure it is supported OS.(Refer page 14 of this link for supported OS: http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_4/ug973-vivado-release-notes-install-license.pdf) If you have another Vivado license for linux machine, then install that license. Else return license from old machine and get it on new machine. (Refer this AR for rehosting .lic license: http://www.xilinx.com/support/answers/36136.html or this AR for rehosting .xml license: http://www.xilinx.com/support/answers/61960.html) Then open the project in new machine. Thanks, Nupur -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the star mark).View solution in original post |
嗨@ dmitry1417,
您可以直接使用同一个项目。 在Linux中打开同一个项目时,您是否遇到任何问题? 您在寻找存档项目的方法吗? 谢谢,Arpan ----------------------------------------------- - - - - - - - - - - - - - - - - - - - - - - - -请注意- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。感谢Kudos .-------------------- -------------------------------------------------- ------------------------ 以上来自于谷歌翻译 以下为原文 Hi @dmitry1417, You can directly use the same project. Are you facing any issues while opening the same project in Linux? Are you looking for a way to archive the project? Thanks, Arpan ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
嗨@ dmitry1417,
按照arpansur的回复中的建议存档项目。 将存档的项目传输到新计算机。 然后,如果尚未安装,请在Linux工作站中安装Vivado。 确保它是受支持的操作系统。(有关支持的操作系统,请参阅此链接的第14页:http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_4/ug973-vivado-release-notes-install-license.pdf) 如果您有另一个适用于Linux机器的Vivado许可证,请安装该许可证。 否则从旧机器返回许可证并将其放在新机器上。 (请参阅此AR以获取重新托管.lic许可证:http://www.xilinx.com/support/answers/36136.html 或此AR用于重新托管.xml许可证:http://www.xilinx.com/support/answers/61960.html) 然后在新机器中打开项目。 谢谢,Nupur ----------------------------------------------- --------------------------------------------- Google在发布之前提问 。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(点击星标)。 以上来自于谷歌翻译 以下为原文 Hi @dmitry1417, Archive the project as suggested in arpansur's reply. Transfer the archived project to new machine. Then, if it is not already installed, install Vivado in the Linux station. Make sure it is supported OS.(Refer page 14 of this link for supported OS: http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_4/ug973-vivado-release-notes-install-license.pdf) If you have another Vivado license for linux machine, then install that license. Else return license from old machine and get it on new machine. (Refer this AR for rehosting .lic license: http://www.xilinx.com/support/answers/36136.html or this AR for rehosting .xml license: http://www.xilinx.com/support/answers/61960.html) Then open the project in new machine. Thanks, Nupur -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the star mark). |
好吧,在我归档项目后,我该如何打开它?
以上来自于谷歌翻译 以下为原文 OK, after I archive the project, how should I open it? |
嗨@ dmitry1417,
将其传输到新机器并解压缩。然后打开项目(它必须具有.xpr扩展名)。 谢谢,Nupur ----------------------------------------------- --------------------------------------------- Google在发布之前提问 。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(点击星标)。 以上来自于谷歌翻译 以下为原文 Hi @dmitry1417, Transfer it to the new machine and extract it. Then open the project(it must be having .xpr extension). Thanks, Nupur -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the star mark). |
归档项目(文件 - >归档项目...)和以其他名称保存项目(文件 - >将项目另存为...)之间有什么区别?
以上来自于谷歌翻译 以下为原文 What's the difference between archiving the project (File-> Archive Project...) and saving the project under another name (File-> Save Project As...)? |
嗨@ dmitry1417,
归档项目时,可以将其与配置设置一起移动,并将所有这些文件发送到.zip文件中。 但是当您执行Save Project As时,它会将项目保存在用户指定的位置,并使用早期目录中的文件。 谢谢,Nupur ----------------------------------------------- --------------------------------------------- Google在发布之前提问 。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(点击星标)。 以上来自于谷歌翻译 以下为原文 Hi @dmitry1417, When you archive a project, you can move it along with the configuration settings and all these files are sent into a .zip file. But when you do Save Project As, it will save the project in a user specified location, with the files that were present in the earlier directory. Thanks, Nupur -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the star mark). |
“但是当你将项目另存为时,它会将项目保存在用户指定的位置,并使用早期目录中的文件” - 所以,所有这些文件(包括创建的IP)都将被复制到新位置或
将留在他们早先的位置,并将从新项目位置引用? 在执行“将项目另存为...”后,是否会删除早期项目位置中的所有文件,还是仍会从新项目位置引用它们? 以上来自于谷歌翻译 以下为原文 "But when you do Save Project As, it will save the project in a user specified location, with the files that were present in the earlier directory" - so, will all these files (including created IPs) be copied to the new location or will stay in their earlier location and will be just referenced from the new project location? After I do the "Save Project As...", would all delete all the files in the earlier project location or will they be still referenced from the new project location? |
嗨@ dmitry1417,
IP文件不会移动到新位置。 它们将从旧位置引用。 将不会从以前的位置删除任何文件。 谢谢,Nupur ----------------------------------------------- --------------------------------------------- Google在发布之前提问 。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(点击星标)。 以上来自于谷歌翻译 以下为原文 Hi @dmitry1417, The IP files will not be moved to new location. They will be referenced from old location. No files will be deleted from previous location. Thanks, Nupur -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the star mark). |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2874 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-2 05:59 , Processed in 0.833154 second(s), Total 88, Slave 71 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2713
