范围错误地为探针的缩放设置10:1。
运行“探针检查”会返回一条消息“...检测到探针为5:0按OK以应用此值”。 按OK而不是选择5:0(这对于此探针是正确的)似乎再次运行探针检查并返回消息“...检测到探针为2:0按OK以应用此值”。 再次按OK再次运行它并返回消息“...检测到探头为1:0按OK以应用此值”。 再次按OK会短暂闪烁一条我读得不够快的消息。 缩放比例保持为自动10:1。 系统固件2.35和2.12也观察到相同的行为。 唯一的解决方法是将探头的自动检测引脚绝缘,并手动将比例设置为5:0。 运行探测检查然后返回一个传递。 感谢tomasz。 以上来自于谷歌翻译 以下为原文 The scope incorrectly sets 10:1 for the probe's scaling. Running "Probe Check" returns a message "...detected the probe to be 5:0 press OK to apply this value". Pressing OK instead of selecting 5:0 (which is correct for this probe) seems to run the probe check again and returns a message "...detected the probe to be 2:0 press OK to apply this value". Pressing OK again runs it yet again and returns a message "...detected the probe to be 1:0 press OK to apply this value". Pressing OK again briefly flashes a message which I can't read fast enough. The scaling remains on auto 10:1. The same behaviour has been observed with the system firmware 2.35 and 2.12. The only workaround is to insulate the probe's autodetect pin and manually setting the scaling to 5:0. Running the probe check then returns a pass. Thanks tomasz. |
2个回答
顺便说一句,1144A未列为3000X系列示波器的受支持探测器。
它在3000X系列示波器发布时几乎同时停产。 我很高兴您找到了解决方法。 免责声明:为了获得更可靠的响应,您应该考虑致电当地的安捷伦技术呼叫中心。 安捷伦论坛在“可用”的基础上进行监控,并不一定是解决技术问题的最快方式。 以上来自于谷歌翻译 以下为原文 BTW, The 1144A is not listed as a supported probe for the 3000X series of scopes. It was discontinued at just about the same time the 3000X series of scopes were released. I'm happy that you found a workaround. Al Disclaimer: For more reliable response, you should consider calling your local Agilent Technical Call Center. The Agilent Forums are monitored on an "as available" basis, and aren't necessarily the fastest way to get technical questions answered. |
1144A正确设置是自动或手动设置10:1,阻抗50欧姆,这个很关键,不是1M欧姆。
只有小组成员才能发言,加入小组>>
2108 浏览 1 评论
1870 浏览 1 评论
1725 浏览 5 评论
2592 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1568 浏览 4 评论
511浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
368浏览 0评论
1426浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
282浏览 0评论
2264浏览 0评论
GMT+8, 2024-5-8 05:09 , Processed in 0.990898 second(s), Total 50, Slave 44 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
