电子发烧友论坛|
您好,我在XY时间模式下使用MSO-X 3054A为测试仪创建一个Lissajous图形。
CH1是x轴,ch2是y轴。 使用同轴电缆(使用1:1探头)连接源。 为了回答我的问题,您可以假设Ch1和Ch2都连接到相互相差90度的5sin(2(PI)100)伏特电源。 当x轴和y轴都设置为2V / div时,示波器显示一个5 div宽的圆。 当使用100Hz正弦波时,圆圈由8个段组成。 Z轴(EXT TRIG IN)未连接,因此不会出现屏幕消隐。 1.在此模式下,x轴似乎限制为3.1V / div。 范围报告“控件处于极限。”我无法在“用户指南”或数据表范围中看到此限制。 请确认这是否是范围限制或如何防止此限制发生。 理想情况下,我想将Ch1,x轴设置为5V / div。 2.我将数据捕获到CVS文件中。 范围仅保存创建的八个段中的一个。 我想抓住整个圈子。 我该如何做到这一点? 为什么屏幕分为八个部分? 驱动示波器的实际电路是测试仪的一部分,该测试仪使用示波器xy模式显示曲线轨迹。 获得上述问题的答案将有助于我更有效地使用范围。 谢谢你的帮助。 以上来自于谷歌翻译 以下为原文 Hello, I am using a MSO-X 3054A in XY time Mode to create a Lissajous figure for a tester. CH1 is the x axis and ch2 is the y axis. The source is connected using coax (1:1 probe used). To answer my questions you may assume that both Ch1 and Ch2 are connected to 5sin(2(PI)100) volt sources that are 90-degress out of phase with eachother. With both x and y axis set to 2V/div, the scope displays a circles that is 5 div wide. The circles made up of 8 segments when a 100Hz sine wave is used. The Z-axis (EXT TRIG IN) is not connected so blanking of the screen does not occur. 1. The x axis appears to be limited to 3.1V/div in this mode. The scope reports “The control is at its limit.” I cannot see this limitation listed in the scope User Guide or data sheet. Please confirm if this is a scope limitation or how to prevent this limit from occurring. I ideally I would like to set Ch1, x-axis, to 5V/div. 2. I captured data to a CVS file. The scope only saves one of the eight segments created. I would like to capture the entire circle. How do I accomplish this? Why is the screen broken into eight segments? The actual circuit that drives the scope is part of a tester that uses the scope xy mode to display a curve trace. Getting answers to my questions above will help me use the scope more effectively. Thanks for your help. |
1个回答
1.示波器的前端最大电压范围为40V(5V / div乘以8垂直分度)。
在XY模式下水平绘制时,有~12.5格,并且最大比例按比例减小以显示相似的范围。 我们可以选择不限制比例,但随后可能会在屏幕上截断信号,对于尝试模拟感觉的数字示波器来说是禁忌。 2. 2000-X和3000-X在XY模式下获取1ms的数据。 如果按[停止]键,将水平模式切换回“正常”,然后缩小,可以看到此信息。 此设置可在3000T和4000-X上调整,但遗憾的是不在3000A上。 无论您处于XY模式还是普通模式,基础数据都是相同的,因此您可以在正常模式下为通道1和2获取更长的捕获,并以这种方式保存CSV文件(如果您可以找到合适的触发器)。 谢谢, - 克里斯 以上来自于谷歌翻译 以下为原文 1. The scope's front end has a maximum voltage range of 40V (5V/div by 8 vertical divisions). When plotted horizontally in XY mode, there are ~12.5 divisions, and the maximum scale is reduced proportionally to show a similar range. We could opt not to limit the scale, but then the signal could potentially be clipped on-screen, a no-no for a digital oscilloscope that's attempting an analog feel. 2. The 2000-X and 3000-X acquire 1ms of data in XY mode. You can see this if you press the [Stop] key, switch the horizontal mode back to Normal, then zoom out. This setting is adjustable on the 3000T and 4000-X, but unfortunately not on the 3000A. The underlying data is identical whether you are in XY or Normal mode, so you can acquire a longer capture in Normal mode for channels 1 and 2 and save the CSV file that way, if you can find a suitable trigger. Thanks, --Chris |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1844浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 03:56 , Processed in 0.530472 second(s), Total 42, Slave 35 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1594
