电子发烧友论坛|
我现在运行了几个项目我观察到安装了程序Xilinx ISE和Vivado的目录高达50 GB,因为我想在运行项目期间生成的文件。
我不记得一开始是不是那么多。 请告诉我哪些可以删除的“运行时”文件以及如何在将来的项目中终止生成这些文件。 以上来自于谷歌翻译 以下为原文 I run several projects now I observe the directory in which the programs Xilinx ISE and Vivado are installed goes up to 50 GB because of the file that generate during the running projects I guess. I do not remember if it was that much in the beginning. Kindly let me know which are those "run time" files that can be deleted and how to terminate generating such files in future projects. |
5个回答
理想情况下,安装目录不应占用比安装期间更多的空间。
临时文件应存储在别处,而不是存储在安装目录中。 因此,在安装目录中没有要删除的内容。 如果这不能回答您的问题,请告诉我。 谢谢,AnirudhPS:请将此标记作为答案,以防它有助于解决您的问题。如果帖子引导您找到解决方案,请给予赞誉。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Ideally the install directory should not consume further additional space than what was during installation. The temporary files should be stored elsewhere and not in the install directory. Hence there is nothing to delete in the install directory. Let me know if this does not answer your question.Thanks, Anirudh PS: Please MARK this as an answer in case it helped resolve your query.Give kudos in case the post guided you to a solution.View solution in original post |
你好@ expertengr
通常,ISE和Vivado工具会在运行完成后删除临时运行时文件。 我怀疑运行的输出产品占用了巨大的空间。 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi @expertengr Generally, ISE and Vivado tools delete the temporary run time files after completion of the run. I suspect the huge space is being occupied by output products of the runs. Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
是的,这是预料之中的。
使用SDK安装最新的Vivado System Edition 2016.2并选择所有设备需要大约33 Gb的空间。 安装目录中没有存储临时文件。如果你安装了2个Vivado,那么它的50GB就不足为奇了。 谢谢,AnirudhPS:请将此标记作为答案,以防它有助于解决您的问题。如果帖子引导您找到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Yes, this is expected. The latest Vivado System Edition 2016.2 installation with SDK and selecting all devices takes around 33 Gb of space. There are no temporary files stored in the install directory. If you have 2 Vivado's installed, then it is not a surprise that its 50GB.Thanks, Anirudh PS: Please MARK this as an answer in case it helped resolve your query.Give kudos in case the post guided you to a solution. |
是的,我在几个项目的框图中验证了设计之后生成了输出产品,但我知道项目目录与安装程序文件目录不同,Xilinx ISE和Xilinx Vivado的安装程序文件目录大约为50 Gb。
有没有办法识别或删除安装目录中的运行时临时文件? 或者没有创建这样的文件,这意味着安装目录在很久以前安装时包含相同的文件和空间。 以上来自于谷歌翻译 以下为原文 Yes true, I have generated output products after the validation of design in the block diagram in several projects but I know that the project directory is different from the installation program file directory which is around 50 Gb for both Xilinx ISE and Xilinx Vivado. Is there any way to recognize or delete the run time temporary files in the installation directory ? or there are no such file created meaning that the installation directory contains the same file and space when it was installed a long time ago. |
临时文件应存储在别处,而不是存储在安装目录中。 因此,在安装目录中没有要删除的内容。 如果这不能回答您的问题,请告诉我。 谢谢,AnirudhPS:请将此标记作为答案,以防它有助于解决您的问题。如果帖子引导您找到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Ideally the install directory should not consume further additional space than what was during installation. The temporary files should be stored elsewhere and not in the install directory. Hence there is nothing to delete in the install directory. Let me know if this does not answer your question.Thanks, Anirudh PS: Please MARK this as an answer in case it helped resolve your query.Give kudos in case the post guided you to a solution. |
只有小组成员才能发言,加入小组>>
3148 浏览 7 评论
3437 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2899 浏览 9 评论
4100 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3083 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1363浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1201浏览 1评论
/9
GMT+8, 2025-12-14 16:08 , Processed in 1.284255 second(s), Total 82, Slave 65 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
7423
