电子发烧友论坛扫一扫,分享给好友
尊敬的先生/女士,
我从LINK下载了Windows的Vivado 2016.2网络版:-https://www.xilinx.com/support/download.html。 但我的机器是32位机器和我下载的Windows的Vivado 2016.2web版本要求64位机器。 请告诉我应该怎么做以及我应该为我的32位Windows机器安装什么版本。 问候 阿迪亚 以上来自于谷歌翻译 以下为原文 Dear Sir/Madam, I have downloaded Vivado 2016.2 web edition for the windows from the LINK:- https://www.xilinx.com/support/download.html. But mine machine is 32 bit machine and Vivado 2016.2 web edition for the windows that i downloaded is demanding for 64 bit machine. Please tell me what should i do and what release should i install for mine 32 bit Windows machine. Regards Aditya |
9个回答
2015.1发布后支持32位。
请参阅安装指南 http://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_2/ug973-vivado-release-notes-install-license.pdf 不再支持32位请查看第8页 http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_2/ug973-vivado-release-notes-install-license.pdf 删除32位操作系统支持 - 从Vivado 2015.1开始,已删除所有设计输入和实现流程的32位操作系统和应用程序支持。 对于Vivado 2015.1实验版,Windows 7和Red Hat Enterprise Linux 6上的32位支持仍然存在。 Lab Edition是一套免费的编程和调试工具 谢谢和RegardsBalkrishan ----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 32 bit supported after 2015.1 release . please refer installation guide http://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_2/ug973-vivado-release-notes-install-license.pdf 32 bit no more supported please check page number 8 http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_2/ug973-vivado-release-notes-install-license.pdf 32-bit OS Support Removal - Beginning with Vivado 2015.1, 32-bit Operating System and application support has been removed for all design entry and implementation flows. The 32-bit support on Windows 7 and Red Hat Enterprise Linux 6 will remain for Vivado 2015.1 Lab Edition. Lab Edition is a free suite of tools for programming and debug Thanks and Regards Balkrishan -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
adiscb@gmail.com,
转到Vivado 2014.4版本:从这里下载:http://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/vivado-design-tools/2014-4.html 谢谢,Nupur ----------------------------------------------- --------------------------------------------- Google在发布之前提问 。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(点击星标)。 以上来自于谷歌翻译 以下为原文 adiscb@gmail.com, Go for Vivado 2014.4 version: Download it from here: http://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/vivado-design-tools/2014-4.html Thanks, Nupur -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the star mark). |
嗨BalaKrishnan,
在链接上:-http://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/vivado-design-tools/2016-2.html有一个Vivado 2016.2实验室版本版本 在那里,它被提到它将支持64和32位机器,不需要许可证。 我应该下载这个??? 请问这支持SDK吗? 问候 阿迪亚 以上来自于谷歌翻译 以下为原文 Hi BalaKrishnan, On the link:-http://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/vivado-design-tools/2016-2.html there is one Vivado 2016.2 LAB EDITION VERSION is there and it is mentioned there that it will support 64 and 32 bit machine and no licenses is required. Should i download this??? Will this support SDK?? Regards Aditya |
嗨Nupur,
我打算用于Zync开发工具包。 如果我安装Vivado 2014.4 VERSION那么我是否需要为此版本安装补丁???? 问候 阿迪亚 以上来自于谷歌翻译 以下为原文 Hi Nupur, I am planning to use for Zync Development kit. If i install Vivado 2014.4 VERSION then do i need to install the patch for this version also???? Regards Aditya |
不,你需要开发工具。
此版本提供所有7系列,Zynq和UltraScale器件的编程和逻辑/串行IO调试。 看看这个视频 http://www.xilinx.com/video/hardware/migrating-to-vivado-lab-tools.html 查看本指南 http://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_2/ug973-vivado-release-notes-install-license.pdf Vivado Lab Edition是一种新型,紧凑且独立的产品,适用于实验室环境。 它提供所有7系列,Zynq和UltraScale器件的编程和逻辑/串行IO调试。 实验室版不需要证书或激活许可证密钥,并且支持64位和32位操作系统平台。 Vivado硬件服务器使Vivado设计工具能够与远程目标系统进行通信。 谢谢和RegardsBalkrishan ----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 No you need development tool . This edition to provides for programming and logic/serial IO debug of all 7 series, Zynq, and UltraScale devices. check this video http://www.xilinx.com/video/hardware/migrating-to-vivado-lab-tools.html check this guide http://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_2/ug973-vivado-release-notes-install-license.pdf Vivado Lab Edition is a new, compact, and standalone product targeted for use in the lab environments. It provides for programming and logic/serial IO debug of all 7 series, Zynq, and UltraScale devices. Lab Edition requires no certificate or activation license key and supports 64- and 32- bit OS platforms. Vivado Hardware Server enables Vivado Design tools to communicate with a remote target system. Thanks and Regards Balkrishan -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
adiscb@gmail.com,
是的,你也需要它。 安装更新2014.4.1。 谢谢,Nupur ----------------------------------------------- --------------------------------------------- Google在发布之前提问 。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(点击星标)。 以上来自于谷歌翻译 以下为原文 adiscb@gmail.com, Yes, you would need that too. install the update 2014.4.1. Thanks, Nupur -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the star mark). |
嗨Nupur,
当我下载Vivado 2014.4.1更新补丁并试图安装时,它给了我一条消息----“没有这个补丁可以更新的有效安装”。 我已经安装了VIvado2014.4及其gUI,sdk正在打开。 然后我收到了那条消息。 问候 阿迪亚 以上来自于谷歌翻译 以下为原文 Hi Nupur, When i downloaded Vivado 2014.4.1 update patch and tried to install ,it has given the me the message ----"There is no valid installation that this patch can update". I have already installed the VIvado 2014.4 and its gUI, sdk is getting opened. Then i got that message. Regards Aditya |
Hiadiscb@gmail.com
查看讨论此问题的答案记录:http://www.xilinx.com/support/answers/63720.html 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi adiscb@gmail.com Check this answer record that discuss the issue: http://www.xilinx.com/support/answers/63720.html Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
你好Vinay,
我查看了你提到的链接,似乎是。因为我已经安装了Vivado 2014.4 Vivado网络版,并且因此Vivado 2014.4.1补丁无法正常工作..我是对的吗? 但是我想开发Zync系列开发套件,根据我的调查,这个更新不是强制性的。 我对吗??? 问候 阿迪亚 以上来自于谷歌翻译 以下为原文 Hi Vinay, I looked into the link that you refered and it seems that .since i have installed Vivado 2014.4 Vivado Web Edition and becoz of this the Vivado 2014.4.1 patch would not work.. Am i right? But i want to work on Zync series development kit and for this as per mine survey this update is not mandatory. Am i right??? Regards Aditya |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2873 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-1 22:02 , Processed in 1.066197 second(s), Total 88, Slave 71 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
638
