扫一扫,分享给好友
有没有人在64位模式下在Windows 7上使用Genesys 2003.10版本成功?
我收到一个未找到密钥的错误消息。 我有一个timeHasp蓝色LPT键。 以上来自于谷歌翻译 以下为原文 Has anyone been successful using Genesys 2003.10 version on Windows 7 in 64bit mode? I'm getting a key not found error message. I have a TimeHasp blue LPT key. |
2个回答
好吧,不确定旧的CAN在Windows 7上运行。但我怀疑你的第一个问题是使用pcie卡作为ltp1端口。
我听说很多人无法使用USB并口端口适配器工作,因为它只是“模拟”一个并行端口,但没有真正复制它,所以软件找不到它。 你可能遇到同样的麻烦。 http://arstechnica.com/civis/viewtopic.php?f=11&t=1117527显然,你并不是唯一一个试图这样做的人! 获得一个带有并行端口的四核windows xp机器......这是一个后备位置。 以上来自于谷歌翻译 以下为原文 Well, not sure genesys that old CAN run on windows 7. But I suspect your first problem is using a pcie card as the ltp1 port. I have heard many who could not get a USB to parallel port adapter to work because it only "emulated" a parallel port, but did not truly replicate it, so the software could not find it. You may have the same trouble. http://arstechnica.com/civis/viewtopic.php?f=11&t=1117527 Apparently, you are not the only one out there trying to do this! Get a quad core windows xp machine with a parallel port...that is a fallback position. |
hetao1111 发表于 2019-8-9 14:17 谢谢你的回复。 我把事情搞定了。 这就是我做的。 如果用户有Windows 7问题,这里的答案将适用于他们。 1. Windows 7不支持并行端口加密狗所需的双向并行端口功能。 2.要在Windows 7计算机上运行带有并行端口加密狗的Genesys,必须安装Virtual XP计算机。 3.需要使用VMWare创建虚拟机。 Windows XP Virtual PC也不支持并行端口。 4.下载VMWare Player并创建XP机器。 使用add hardware选项安装虚拟并行端口。 5.在虚拟PC中安装Genesys并准备好进行设计。 以上来自于谷歌翻译 以下为原文 Thanks for the response. I got things to work. Here is what I did. In case users have Windows 7 questions here is the answer that will work for them. 1. Windows 7 does not support bidirectional parallel port features required by the parallel port dongles. 2. To run Genesys with a parallel port dongle on a Windows 7 machine you must install a Virtual XP machine. 3. The virtual machine needs to be created with VMWare. Windows XP Virtual PC does not support parallel ports either. 4. Download VMWare Player and create an XP machine. Use the add hardware option to install a virtual parallel port. 5. Install Genesys in the virtual PC and your ready to design. |
只有小组成员才能发言,加入小组>>
2108 浏览 1 评论
1870 浏览 1 评论
1725 浏览 5 评论
2594 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1568 浏览 4 评论
512浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
369浏览 0评论
1429浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
282浏览 0评论
2264浏览 0评论
GMT+8, 2024-5-9 20:22 , Processed in 1.363010 second(s), Total 80, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
