电子发烧友论坛|
大家好,
在virtex-7 VC709主板上,'VC709'代表什么? 以上来自于谷歌翻译 以下为原文 Hi all, in virtex-7 VC709 board, what does 'VC709' stand for..? |
5个回答
开发板的命名随着时间的推移而发生了变化。
在过去几代中,命名已经过去了 Virtex-5:ML5xx Virtex-6:ML6xx Spartan-6:SP6xx Artix-7:AC7xx Kintex-7:KC7xx Virtex-7:VC7xx Zynq-7000:ZC7xx KintexUltrascale:KCUxxx VirtexUltrascale:VCUxxx 当然,这些适用于Xilinx开发板(不是来自第三方的板)。 至于编号,跨平台可能有一些一致性; 如果它们存在的“01”板往往相当简单,“05”往往是主流的“中型”平台,“09”倾向于专注于高速收发器可视性,但我不确定是否有 一个坚实的模式(UltraScale板似乎使用1xx开始)。 或者,它可能只是“更大的数字是更复杂(因此昂贵!)板”。 Avrum 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 The naming of the development boards have changed over time. For the last few generations, the naming has been Virtex-5: ML5xx Virtex-6: ML6xx Spartan-6: SP6xx Artix-7: AC7xx Kintex-7: KC7xx Virtex-7: VC7xx Zynq-7000: ZC7xx KintexUltrascale: KCUxxx VirtexUltrascale: VCUxxx Of course, these apply to the Xilinx development boards (not boards from 3rd parties). As for the numbering, there may be some consistency across platforms; the "01" boards if they exist tend to be fairly simple, the "05" tend to be the mainstream "medium sized" platform and the "09" tend to focus on high speed transceiver visibility, but I am not certain if there is a solid pattern to this (the UltraScale boards seem to use start at 1xx). Or, it may just be "the larger number is the more sophisticated (hence expensive!) board". Avrum View solution in original post |
@tkganeshbhattk,
检查以下论坛帖子: https://forums.xilinx.com/t5/General-Technical-Discussion/nomenclature-of-Xilinx-FPGA/td-p/27338 https://forums.xilinx.com/t5/General-Technical-Discussion/How-to-read-and-Understand-the-xilinx-part-numbers-and/td-p/358531 --Syed -------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 @tkganeshbhattk, Check the following forum thread: https://forums.xilinx.com/t5/General-Technical-Discussion/nomenclature-of-Xilinx-FPGA/td-p/27338 https://forums.xilinx.com/t5/General-Technical-Discussion/How-to-read-and-Understand-the-xilinx-part-numbers-and/td-p/358531 --Syed --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. --------------------------------------------------------------------------------------------- |
在过去几代中,命名已经过去了 Virtex-5:ML5xx Virtex-6:ML6xx Spartan-6:SP6xx Artix-7:AC7xx Kintex-7:KC7xx Virtex-7:VC7xx Zynq-7000:ZC7xx KintexUltrascale:KCUxxx VirtexUltrascale:VCUxxx 当然,这些适用于Xilinx开发板(不是来自第三方的板)。 至于编号,跨平台可能有一些一致性; 如果它们存在的“01”板往往相当简单,“05”往往是主流的“中型”平台,“09”倾向于专注于高速收发器可视性,但我不确定是否有 一个坚实的模式(UltraScale板似乎使用1xx开始)。 或者,它可能只是“更大的数字是更复杂(因此昂贵!)板”。 Avrum 以上来自于谷歌翻译 以下为原文 The naming of the development boards have changed over time. For the last few generations, the naming has been Virtex-5: ML5xx Virtex-6: ML6xx Spartan-6: SP6xx Artix-7: AC7xx Kintex-7: KC7xx Virtex-7: VC7xx Zynq-7000: ZC7xx KintexUltrascale: KCUxxx VirtexUltrascale: VCUxxx Of course, these apply to the Xilinx development boards (not boards from 3rd parties). As for the numbering, there may be some consistency across platforms; the "01" boards if they exist tend to be fairly simple, the "05" tend to be the mainstream "medium sized" platform and the "09" tend to focus on high speed transceiver visibility, but I am not certain if there is a solid pattern to this (the UltraScale boards seem to use start at 1xx). Or, it may just be "the larger number is the more sophisticated (hence expensive!) board". Avrum |
只有小组成员才能发言,加入小组>>
3148 浏览 7 评论
3437 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2900 浏览 9 评论
4108 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3083 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1363浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1202浏览 1评论
/9
GMT+8, 2025-12-15 03:48 , Processed in 1.053188 second(s), Total 80, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2281
