电子发烧友论坛|
嗨,我有一个PSoC 1 CY32 10-PSoCalv1评估套件。这个套件包括CY8C946624PXI和CY8C2644 3-24PXI设备样本。当查找信息来比较这些设备时,我发现MaseR列出了这两个设备已经过时。这个工具包有一个更新近的版本,但是它使用相同的设备。CyPress逐步淘汰PSoC 1吗?有没有过时的替代设备与这个工具箱一起工作?我的应用需要在PSoC 1中可用的开关电容块的多功能性,而在另一种更现代的PSoC器件中,这种电容器块是不可用的。这些器件具有可编程模拟块,可以提供更好的模拟模块,但它们似乎不像PSOC 1器件那样作为非标准开关电容电路发展的通用性。请告知。干杯!-马特
以上来自于百度翻译 以下为原文 Hi, I have a PSOC 1 CY3210-PSoCEval1 Evaluation Kit. This kit includes CY8C29466-24PXI and CY8C27443-24PXI device samples. When looking for information to compare these devices I found that Mouser lists both of these devices as obsolete. There is a more recent version of this kit, but it uses the same devices. Is Cypress phasing out PSOC 1? Are there non-obsolete alternative devices that work with this kit? My applications require the versatility of the switched capacitor blocks available in PSoC 1 and which do not appear to be available in the other, more modern, PSoC devices. Those devices have programmable analog blocks that may offer better analog modules, but they do not appear to be as versatile for non-standard switched capacitor circuit development as PSoC 1 devices. Please advise. Cheers! -Matt |
3个回答
你好,马修,
PSoC1目前还没有过时。引入新设备已经停止。一些包选项可能过时,主要是非ROHS包。你仍然可以购买很多PSoC1设备。 我也建议你看一下我们的PSoC模拟协处理器,它有类似于PSoC1的SC块。 谢谢, 萨姆普斯 以上来自于百度翻译 以下为原文 Hello Matthew, PSoC1 is not obsolete as of now. Introducing new devices has been stopped. Some package options may be obsolete, mostly non-ROHS packages. You can still purchase many PSoC1 devices. I also suggest you take a look at our PSoC Analog Co-Processor, which has SC blocks similar to PSoC1. Thanks, Sampath |
谢谢,Sampath, 是的,我确实看到了模拟协处理器,但是在PoSc 1 ScBand的现代等价物中,UAB块还不能在创建者中对公众开放。我从PSoC 4论坛了解到他们计划发布。 由于PSOC 1设备适合于目前可用的PSoC 1评估套件,所以如果提供了合适的备选方案,例如表面安装当量和适配器板以适合于DIP插座,这将是很好的。 干杯! -马特 以上来自于百度翻译 以下为原文 Thanks, Sampath, Yes, I did look at the Analog Co-Processor, but the UAB blocks that are the modern equivalent of the PSoC 1 SCBLOCK are not yet available to the public in Creator. I learned from the PSoC 4 forum that they are planned for release. Since the PSoC 1 devices that fit in the PSoC 1 evaluation kit that is presently available are no longer available, it would be nice if the information was provided as to suitable alternatives e.g. surface mount equivalents and adapter boards to fit in the DIP sockets. Cheers! -Matt |
适配器可以在SPARKFAY中找到。这些适配器可以与SOIC/SSOP 28引脚部件一起安装在CY310评估工具箱上的28引脚DIP插座上。 SkkFooSoIC到DIP适配器- 28针 SpkFooSSOP到DIP适配器- 28针 以上来自于百度翻译 以下为原文 Adapters can be found in Sparkfun. These adaptors can be used with SOIC / SSOP 28 pin parts to mount on the 28 pin DIP socket on CY3210 Evaluation Kit. SparkFun SOIC to DIP Adapter - 28-Pin SparkFun SSOP to DIP Adapter - 28-Pin |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-2 07:54 , Processed in 0.648664 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1246
