你好,
我目前正在研究STM8L15C6。对于我的应用程序,我需要读取存储在位置VREFINT_FACTORY_CONV的值。此内存位置的值为0xFF。我们假设值大约为0x80。 对此的任何解释都将非常有帮助。 非常感谢, MEGHA 以上来自于谷歌翻译 以下为原文 Hello, I am currently working on STM8L15C6. For my application I need to read the value stored at location VREFINT_FACTORY_CONV. The value at this memory location is 0xFF. We were assuming the value to be somewhere around 0x80. Any explanation on this would be very helpful. Many Thanks, Megha |
3个回答
这个值似乎错了。
根据数据表,VREFINT_FACTORY_CONV存储在0x4910,并且在电源为3000 mV +/- 10 mV的工厂测试期间包含ADC转换输出的低字节。 由于0x06是ADC转换输出的高字节,因此器件的参考电压输出应为0x6FF,即约为1311 mV(= 0x6FF * 3000/4096),这超出了器件规格。 问候, EtaPhi 以上来自于谷歌翻译 以下为原文 This value seems wrong. According to the datasheet, VREFINT_FACTORY_CONV is stored at 0x4910 and contains the low byte of the ADC conversion output during the factory tests when the power supply is 3000 mV +/- 10 mV. Since 0x06 is the upper byte of the ADC conversion output, the reference voltage output of your device should be 0x6FF, i.e. about 1311 mV (= 0x6FF * 3000 / 4096) which is outside the device specs. Regards, EtaPhi |
非常感谢EtaPhi,
我在地址VREFINT_FACTORY_CONV(0x4910)处检查了3个以上的芯片,它们都具有0xFF的值。我连接了Rlink调试器,并从Raisonance IDE检查了内存视图中的值,值为0xFF。将附上屏幕截图供您参考。芯片是否有任何错误,如果您发现相同,请告诉我。 问候, MEGHA 以上来自于谷歌翻译 以下为原文 Many Thanks EtaPhi, I have checked more than 3 chips at the address VREFINT_FACTORY_CONV (0x4910) and they all have the value of 0xFF. I connected the Rlink debugger and from the Raisonance IDE checked the value in memory view and the value is 0xFF. Will attach the screen shot for your reference. Is there any bug with the chip please let me know if you find the same. Regards, Megha |
你好,梅加。
STM8L Discovery板中STM8L152C6的VREFINT_FACTORY_CONV字节等于0x69。 这意味着在工厂测试期间,我的micro的ADC输出为0x669。 我认为这个字节没有在你的微程序中编程(或者它已被删除)。 BR EtaPhi 以上来自于谷歌翻译 以下为原文 Hello, Megha. The VREFINT_FACTORY_CONV byte of the STM8L152C6 in my STM8L Discovery board is equal to 0x69. This means that the ADC output of my micro was 0x669 during factory tests. I think that this byte wasn't programmed in your micro (or it was erased). BR EtaPhi |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
2459 浏览 1 评论
3160 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1727 浏览 1 评论
3547 浏览 6 评论
5907 浏览 21 评论
885浏览 4评论
1263浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
528浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
1247浏览 3评论
1299浏览 3评论
GMT+8, 2024-10-1 07:31 , Processed in 1.152948 second(s), Total 83, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
