求助,现采用STM32L051采集电压 12位ADC,启用DMA,内部参考电压1.2V 理论上可采集最小值1.2/4096=0.2mV ,但在实际测试8MV以下就检测不到了通道数据为0. 贴出代码,熟悉ADC的大神帮忙看一下,谢谢。//ADC初始化
void MX_ADC_Init(void) { ADC_ChannelConfTypeDef sConfig; /**Configure the global features of the ADC (Clock, Resolution, Data Alignment and number of conversion) */ hadc.Instance = ADC1; hadc.Init.OversamplingMode = DISABLE; hadc.Init.ClockPrescaler = ADC_CLOCK_SYNC_PCLK_DIV1; hadc.Init.Resolution = ADC_RESOLUTION_12B; hadc.Init.SamplingTime = ADC_SAMPLETIME_39CYCLES_5; hadc.Init.ScanConvMode = ADC_SCAN_DIRECTION_BACKWARD; hadc.Init.DataAlign = ADC_DATAALIGN_RIGHT; hadc.Init.ContinuousConvMode = ENABLE; hadc.Init.DiscontinuousConvMode = DISABLE; hadc.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE; hadc.Init.ExternalTrigConv = ADC_SOFTWARE_START; hadc.Init.DMAContinuousRequests = ENABLE; hadc.Init.EOCSelection = ADC_EOC_SINGLE_CONV; hadc.Init.Overrun = ADC_OVR_DATA_PRESERVED; hadc.Init.LowPowerAutoWait = DISABLE; hadc.Init.LowPowerFrequencyMode = DISABLE; hadc.Init.LowPowerAutoPowerOff = DISABLE; if (HAL_ADC_Init(&hadc) != HAL_OK) { _Error_Handler(__FILE__, __LINE__); } /**Configure for the selected ADC regular channel to be converted. */ sConfig.Channel = ADC_CHANNEL_4; sConfig.Rank = ADC_RANK_CHANNEL_NUMBER; if (HAL_ADC_ConfigChannel(&hadc, &sConfig) != HAL_OK) { _Error_Handler(__FILE__, __LINE__); } /**Configure for the selected ADC regular channel to be converted. */ sConfig.Channel = ADC_CHANNEL_5; if (HAL_ADC_ConfigChannel(&hadc, &sConfig) != HAL_OK) { _Error_Handler(__FILE__, __LINE__); } /**Configure for the selected ADC regular channel to be converted. */ sConfig.Channel = ADC_CHANNEL_6; if (HAL_ADC_ConfigChannel(&hadc, &sConfig) != HAL_OK) { _Error_Handler(__FILE__, __LINE__); } /**Configure for the selected ADC regular channel to be converted. */ sConfig.Channel = ADC_CHANNEL_7; if (HAL_ADC_ConfigChannel(&hadc, &sConfig) != HAL_OK) { _Error_Handler(__FILE__, __LINE__); } /**Configure for the selected ADC regular channel to be converted. */ sConfig.Channel = ADC_CHANNEL_8; if (HAL_ADC_ConfigChannel(&hadc, &sConfig) != HAL_OK) { _Error_Handler(__FILE__, __LINE__); } /**Configure for the selected ADC regular channel to be converted. */ sConfig.Channel = ADC_CHANNEL_9; if (HAL_ADC_ConfigChannel(&hadc, &sConfig) != HAL_OK) { _Error_Handler(__FILE__, __LINE__); } /**Configure for the selected ADC regular channel to be converted. */ sConfig.Channel = ADC_CHANNEL_TEMPSENSOR; if (HAL_ADC_ConfigChannel(&hadc, &sConfig) != HAL_OK) { _Error_Handler(__FILE__, __LINE__); } /**Configure for the selected ADC regular channel to be converted. */ sConfig.Channel = ADC_CHANNEL_VREFINT; if (HAL_ADC_ConfigChannel(&hadc, &sConfig) != HAL_OK) { _Error_Handler(__FILE__, __LINE__); } } //主函数 int main(void) { HAL_Init(); SystemClock_Config(); MX_GPIO_Init(); MX_DMA_Init(); MX_TIM2_Init(); MX_ADC_Init(); HAL_ADCEx_Calibration_Start(&hadc,ADC_SINGLE_ENDED);//ADC校准 HAL_ADC_Start_DMA(&hadc,ADC_Value.ADC_ConvertedValue,ADC_NUMOFCHANNEL); MX_USART2_UART_Init(); if(HAL_TIM_Base_Start_IT(&htim2) != HAL_OK) { while(1); } /* USER CODE BEGIN 2 */ MCU_CHG_Start; MCU_DSG_Start; /* USER CODE END 2 */ /* Infinite loop */ /* USER CODE BEGIN WHILE */ while (1) { /* USER CODE END WHILE */ HAL_Delay(100); for(uint16_t index=0; index ADC_Value.ADC_ConvertedVoltage[index]=(uint32_t)(ADC_Value.ADC_ConvertedValueAVER[index]&0xFFF)*ADC_VCC/4096; // mv } Project_Data.NTC1Temperature = (int32_t)get_Temperature(get_Resistance(ADC_Value.ADC_ConvertedVoltage[7])); Project_Data.NTC2Temperature = (int32_t)get_Temperature(get_Resistance(ADC_Value.ADC_ConvertedVoltage[6])); Project_Data.NTC3Temperature = (int32_t)get_Temperature(get_Resistance(ADC_Value.ADC_ConvertedVoltage[5])); Project_Data.NTC4Temperature = (int32_t)get_Temperature(get_Resistance(ADC_Value.ADC_ConvertedVoltage[4])); Project_Data.Current=(ADC_Value.ADC_ConvertedVoltage[3]-ADC_Value.ADC_ConvertedVoltage[2])*1000/Current_Resistance;//MA // HAL_IWDG_Refresh(&hiwdg); /* USER CODE BEGIN 3 */ } /* USER CODE END 3 */ } //定时器0.5ms一次 void HAL_TIM_PeriodElapsedCallback(TIM_HandleTypeDef *htim) { ADC_Value.ADC_Filter++; for(uint8_t index=0; index ADC_Value.ADC_ConvertedValueSum[index] += ADC_Value.ADC_ConvertedValue[index]; } if(ADC_Value.ADC_Filter>=20)//20次滤波 { ADC_Value.ADC_Filter = 0; for(uint8_t index=0; index ADC_Value.ADC_ConvertedValueAVER[index] = ADC_Value.ADC_ConvertedValueSum[index]/20; ADC_Value.ADC_ConvertedValueSum[index] = 0; } } } |
8个回答
是3.3,记混了。按3.3来算1LSB=3.3/4096=0.8MV,但ADC通道采样实际还是采集不到2MV以下的电压 |
本帖最后由 hpdell 于 2017-12-27 17:22 编辑 你看看他内部有没有可以设置参考电压的寄存器 ? 我现在使用 stm32L031xx 这个芯片,采集 adc 电压时,貌似有时不不准,也不知道是怎么回事啊 ? 外部使用 两个 47K 电阻分压,本来想使用 470K的电阻,但是每次开机采集的数据不准,所以就换成了 47K, 换成47K的电阻分压后,刚开机可以采集到准确的adc数据,但是貌似时间运行久了 就不行了,你遇到过这个情况没有啊 ?? |
采集数据不准,是指采集的通道数据跳动很大还是采集的电压值和实际值偏差很大。检查通道的实际电压是否稳定,或者尝试增加采样保持时间,若是采集的数据有波动可再软件处理上增加滤波。 |
我已经加了软件滤波,每次采集10次,只保留中间4次的 采集的电压值说明如下: 比如我第一次采集的是 3.30v 但是时间久了后采集的是 3.322v 电压是保持不变的 |
寄存器配置问题
可以采样的
之前遇到过的
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
STM32F405驱动DS1302时钟模块,输出时间错乱该怎么排查?
2810 浏览 2 评论
stm32f405rgt6驱动DS1302ZN出现时间错乱问题
2420 浏览 1 评论
stm32用fsmc读取ad7606采集数据,数据不变,只有开发版复位才更新数据
2288 浏览 0 评论
2404 浏览 1 评论
1643 浏览 1 评论
/9
GMT+8, 2025-12-2 19:20 , Processed in 1.024516 second(s), Total 88, Slave 71 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3339
