电子发烧友论坛|
大家好,
用2×VDAC VREF采购选项,你可以使用低电压的范围?例如,与VDAC,这在理论上是可能的设置范围,8mv(4MV×2)。我认为,这可能会造成很大的噪音,或造成SINAD大幅度减少。看来我们还必须使用外部去耦电容太。 如果是这样的话,我们可以设置使用VDAC仍然取得好成绩最低的范围是什么?例如,可以设置VDAC的0.512v给它1.024v良好的性能范围(0.512v×2)? 任何澄清都会有帮助。 亚历克斯 以上来自于百度翻译 以下为原文 Hello All, With the 2*VDAC Vref sourcing option, can you apply low voltages to the range? For example, with the VDAC, it is theoretically possible to set the range to 8mV (4mv*2). I would assume that this would probably cause a lot of noise, or cause a major reduction in SINAD. It seems that we also have to use external decoupling capacitors too. If this is the case, what is the lowest range that we can set using the VDAC and still get good results? For example, would setting the VDAC to 0.512V give it a good performance range of 1.024V (0.512V*2)? Any clarification would be helpful. Alex |
2个回答
在KIT-030这样的工具箱中,用户可以很容易地将参考电容焊在原区域上。我相信SAR ADC的参考引脚都被引入到原空间中。
以上来自于百度翻译 以下为原文 On the kits like Kit-030 a user could easily solder the refernce capacitor on the protoarea. I believe both the reference pins for the SAR ADC are brought out in to the proto space. |
OOPS忽略以前的帖子,这是一个错误。打算在另一个话题发表文章。
但是关于VDAC参考的使用。从理论上讲,VDAC可能能够达到与DAC的最小计数一样低的范围,但是我们必须理解,有很多因素影响ADC性能。 其中,有DAC噪声作为参考噪声加入。输出噪声是在任何代码相同的楼层,而ADC是比例的参考。这意味着在参考值较低的情况下,这种噪声可能具有显性效应。ENOB可能会产生严重的影响。 此外,DAC可能具有的任何线性误差将表现为ADC中的线性和增益误差。 我也会担心由于使用VDAC,因为它的高输出阻抗系统对带宽的影响。 虽然在数据表(用户)中还没有出现这种情况,但我认为,在这种情况下,应该期望一些性能下降。 以上来自于百度翻译 以下为原文 Oops ignore the previous post it was a mistake. Intended to post in another topic. But about the use of the VDAC reference. Theoritically the VDAC might be able to achieve a range as low as the least count of the DAC but we have to understand that there are lot of factors of the reference that affects the ADCs performance. For one, there is the DACs noise which would be adding in as a reference noise. The output noise is the same floor at any code whereas the ADC is ratiometric to the reference. Which means at the lower values of the reference this noise might have a dominant effect. There could be a serious effect on ENOB. Also any linearity errors that the DAC might have would manifest into linearity and gain errors in the ADC. I would also be worried about the effect on the bandwidth due to the use of the VDAC since its a high output impedance system. Though this has not been brought out in the datasheet, a user, I believe should expect some performance degrdation in this case. |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2477 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2074 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7567浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-2 13:59 , Processed in 0.775734 second(s), Total 77, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1050
