电子发烧友论坛|
你好,我已经启动了一个通过蓝牙连接16 PSoC 6的项目。由于我必须跨越大约400米的面积,我想知道这个BLE 4.2实现支持的范围。此外,我买了一个DEV套件,并订购了范围扩展器EVA套件(CyBLY-224110-EVAL)。我能把这个连接到062-BLE,以及如何?如果没有,我需要取消订单。
谢谢你的帮助 斯特凡 以上来自于百度翻译 以下为原文 Hello, I have started a project to connect 16 PSoC 6 via bluetooth. As I have to span an area of about 400m I am wondering about the range this BLE 4.2 Implementation supports. Also, I have bought a Dev Kit and just ordered a range extender eval kit as well (CYBLE-224110-EVAL). Can I connect this to the 062-BLE, and how ? If not, I need to cancel the order. Thank you for any help on this Stefan |
2个回答
CYBLY-224110-EVE不是一个范围扩展器,它是一个PSoC 4 BLE设备,它自己的专用,内部,功率放大器,以增加其范围。
您可以通过例如I2C、SPI、UART将其连接到062-BLE设备,但它们是独立的设备,而BLE堆栈仍然在CyBur-224110模块上运行,而不是在PSoC 6上运行。然后,您可以在理论上将CyBLY224110作为PSoC 6的“调制解调器”编程。 也就是说,除非您想使用PSoC 6的特定特性,否则在这样的配置中我看不到太多的要点。 以上来自于百度翻译 以下为原文 The CYBLE-224110-EVAL is not a range extender, it's a PSoC 4 BLE device of it's own with a dedicated, internal, power amplifier to increase its range. You can connect it to the 062-BLE device via e.g. I2C, SPI, UART but they are otherwise independent devices and the BLE stack would still run on the CYBLE-224110 modules, not on the PSoC 6. You could then in theory program the CYBLE-224110 as a "modem" for the PSoC 6. That said, unless you want to use a particular feature of the PSoC 6 I don't really see much point in such a configuration. |
它作为一个范围扩展器无论如何为DEV工具箱042-BLE。CYBLY-224110-EZ-BLEμPSOC XT/XR评估板 我通常开发毫无意义的东西-没关系。然而,在这里,我需要扩展062-BLE DEV套件的范围。我只是想知道它是否会简单地连接到新的BLE DEV工具包,因为它与042-BLE。 以上来自于百度翻译 以下为原文 It is sold as a range extender anyway for the dev kit 042-BLE. CYBLE-224110-EVAL EZ-BLE™ PSoC XT/XR Evaluation Board | Cypress Semiconductor I usually develop pointless stuff - never mind . However, here I seriously need to extend the range of the 062-BLE Dev Kit. I just wondered if it will connect as simply to the new BLE Dev Kit as it does with the 042-BLE. |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-2 06:28 , Processed in 0.667524 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
572
