嗨,
我有Digilent的ZYBO板,我是从Trenz购买的,因为我在英国。 当我买它时,我无法获得带有锁定Zynq 7010设备的设计工具凭证的配件包。 当时它甚至没有列出,现在已经上市,但没有库存。 现在有没有办法获得许可证,还是我必须购买微型或zybo等其他套件? 我想要许可证,所以我可以调试我的逻辑。 问候 戴夫沃伦 以上来自于谷歌翻译 以下为原文 Hi, I have a ZYBO board from Digilent, I bought it from Trenz because I am in the UK. When I bought it I could not get the accessory kit that has a voucher for design tools locked to Zynq 7010 device. At that time it was not even listed, now it is listed but there is no stock. Is there any way to get the license now or do I have to buy another kit like microzed or zybo? I would like the license so I can debug my logic. Regards Dave Warren |
4个回答
嗨戴夫,
从您购买套件的地方联系digilent。 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi Dave, Contact digilent from where you purchased the kit. Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution.View solution in original post |
嗨戴夫,
从您购买套件的地方联系digilent。 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi Dave, Contact digilent from where you purchased the kit. Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
Heydavewarren,
你有没有获得你的执照? 你是从特伦茨或其他地方得到的吗? 谢谢, 哈桑 以上来自于谷歌翻译 以下为原文 Hey davewarren, Did you manage to get your license ? Did you get it from Trenz or elsewhere ? Thanks, Hassen |
只有小组成员才能发言,加入小组>>
2215 浏览 7 评论
2640 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2119 浏览 9 评论
3188 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2243 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
491浏览 1评论
1570浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2217浏览 0评论
543浏览 0评论
1704浏览 0评论
GMT+8, 2024-6-26 20:15 , Processed in 1.248885 second(s), Total 84, Slave 68 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
