首先,我想知道CYUSB3014是否可以输出时钟作为FX2LP外部传感器…
第二,当我使用GPIF与外部传感器通信时,是否需要与外部设备时钟同步? 谢谢!! 以上来自于百度翻译 以下为原文 first, i want to know if CYUSB3014 can output clock to the external sensor as FX2LP... second, when i use GPIF Communicate with external sensor, Does it need to be synchronized with the external device clock.... thanks!! |
5个回答
1. CYSUB3014不能向外部传感器输出时钟。
2。当使用GPIF与外部传感器通信时,需要与外部设备时钟同步。 例如:如果外部传感器运行在24MHz,PCLK到FX3应该是24MHz。 以上来自于百度翻译 以下为原文 1.CYUSB3014 can not output clock to the external sensor. 2. When use GPIF Communicate with external sensor , it need to be synchronized with the external device clock. For example : If external sensor runs at 24MHz, the PCLK to the FX3 should be 24MHz. |
当GPIFII设计器中的“时钟设置”被设置为“内部”时,PCLK(GPIF16)引脚被配置为输出并向外部设备提供时钟。
在这种情况下,GPIF II的状态机硬件由PCLK计时。 如果使用同步接口,则需要同步PCLK和传感器设备时钟。 如果使用异步接口,PCLK引脚不输入/输出时钟,并且不需要与传感器设备时钟同步。但是传输速度会比同步接口慢。 当做, 诺里基 以上来自于百度翻译 以下为原文 When the "Clock settings" is set to "Internal" in the GPIF II Designer, the PCLK (GPIF16) pin is configured as an output and provides a clock to external devices. In this case, the GPIF II's state machine hardware is clocked by the PCLK. If a synchronous interface is used, it is required to synchronize the PCLK and the sensor device clock . If an asynchronous interface is used, the PCLK pin does not input/output a clock and is not required to be synchronized to the sensor device clock. But the transfer speed will be slower than the synchronous interface. Regards, Noriaki |
numuwewr 发表于 2018-12-11 09:03 在我的设计中,我使用有源晶体振荡器提供时钟到图像传感器。 我使用同步接口,连接CysB3014和传感器。 在这种情况下,我只是把PCLK(GPIO16)和传感器的输出时钟连接到数据线之外? GPIF II的状态机硬件也由PCLK或它自己的时钟来计时? 谢谢! 以上来自于百度翻译 以下为原文 in my design, i use a active crystal oscillator provide clock to a image sensor. i use a synchronous interface, Connect CYUSB3014 and sensor. In this case, I just put the PCLK(GPIO16) and ouput clock of sensor be connected In addition to data lines? the GPIF II's state machine hardware is also clocked by the PCLK Or it's own clock? thanks! |
hgjhgd 发表于 2018-12-11 08:50 在我的设计中,我使用有源晶体振荡器提供时钟到图像传感器。 我使用同步接口,连接CysB3014和传感器。 在这种情况下,我只是把PCLK(GPIO16)和传感器的输出时钟连接到数据线之外? GPIF II的状态机硬件也由PCLK或它自己的时钟来计时? 谢谢! 以上来自于百度翻译 以下为原文 in my design, i use a active crystal oscillator provide clock to a image sensor. i use a synchronous interface, Connect CYUSB3014 and sensor. In this case, I just put the PCLK(GPIO16) and ouput clock of sensor be connected In addition to data lines? the GPIF II's state machine hardware is also clocked by the PCLK Or it's own clock? thanks! |
szcxwgyc 发表于 2018-12-11 09:09 如果选择“内部”作为“时钟设置”,则使用内部时钟来对GPIF II的状态机进行计时。内部时钟被命名为“PIB时钟”,时钟用于驱动GPIO16(PCLK)输出。因此,PCLK输出等于状态机硬件时钟。 我不知道你是否能把PCLK输出连接到你的图像传感器。这取决于传感器的规格。 在典型的情况下,一些控制信号连接在FX3和图像传感器之间。 请参阅以下申请须知。 AN7799-如何在USB视频类(UVC)框架中使用EZ-USB®FX3μ来实现图像传感器接口。 当做, 诺里基 以上来自于百度翻译 以下为原文 If "Internal" is selected as the "Clock settings," an internal clock is used to clock the GPIF II's state machine. The internal clock is named as "PIB clock" and the clock is used to drive the GPIO16 (PCLK) output. So, the PCLK output is equal to the state machine hardware clock. I don't know if you can connect the PCLK output to your image sensor. It depends on the sensor's specification. In typical case, some control signals are connected between the FX3 and the image sensor. Please refer following application note too. AN75779 - How to Implement an Image Sensor Interface Using EZ-USB® FX3™ in a USB Video Class (UVC) Framework | Cypress S… Regards, Noriaki |
只有小组成员才能发言,加入小组>>
754个成员聚集在这个小组
加入小组2102 浏览 1 评论
1848 浏览 1 评论
3666 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1783 浏览 6 评论
1533 浏览 1 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
564浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
418浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
434浏览 2评论
380浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
911浏览 2评论
GMT+8, 2024-12-22 09:22 , Processed in 1.413686 second(s), Total 84, Slave 68 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
