电子发烧友论坛|
大家好,
我尝试用制造蓝牙测试工具来对CYW920706WCV板进行性能测试。 我遵循了WIDE-Studio5.0/DoC/SuffoButoToToT-Test-Tooal.PDF中描述的步骤,但是当我运行命令MBT重置时,什么也没有发生,它被卡住: 发送HCI命令: 0000和lt;03 0C 00 & gt; 欲了解更多信息,该板是编程与DEMO.Audio.HeSET -CYW920706WCDEVALL,这是兼容的HCI控制器。我所要做的就是得到有关接收到的数据包(CRC错误和数据包丢失)的统计信息。我使用CYW920706WCDEVALL作为音频接收器。音频源来自非CYW20706设备(智能手机和PC)。如果你知道这样做的有效方法,请告诉我。 设置:Windows 7 X64 先谢谢你。 路易斯克鲁兹 以上来自于百度翻译 以下为原文 Hello everyone, I'm trying to set up a performance test of the CYW920706WCDEVAL board with the Manufacturing Bluetooth Test Tool. I followed the steps described in /WICED-Studio-6.0/Doc/Manufacturing-Bluetooth-Test-Tool.pdf but whe I run the command mbt reset nothing happens, it gets stuck at: Sending HCI Command: 0000 < 03 0C 00 > For more information, the board is programmed with demo.audio.headset-CYW920706WCDEVAL, which is compatible with the HCI controller. All I want to do is get statistics about the received packets (CRC errors, and packet loss, mostly). I use the CYW920706WCDEVAL as an audio sink. The audio source comes from a non-CYW20706 device (smartphone and PC). If you know an efficient way to do so, let me know please. Setup: Windows 7 x64 Thank you in advance. Luis CRUZ |
3个回答
嗨,路易斯,
当应用程序运行时,20706将不会响应UART上的HCI命令。发送给控制器的任何HCI命令都必须来自嵌入式应用程序。 雅各伯 以上来自于百度翻译 以下为原文 Hi Luis, When an app is running, the 20706 will not respond to HCI commands on the UART. Any HCI commands sent to the controller will have to come from the embedded application. Jacob |
嗨,Luiz,
在Audio.Head应用程序中,注释HCIIX控件中的WICEDIX传输TITIT(ANP;TrimtT.CFG)。 这显然会禁用WICE传输,并且应用程序不会像预期的那样运行,但是您应该能够使用MBT发送HCI命令。 以上来自于百度翻译 以下为原文 Hi Luiz, In the audio.headset app, comment out the wiced_transport_init(&transport_cfg) in hci_control.c. This will obviously disable the WICED transport and your application won't function as expected but you should be able to use MBT to send HCI commands. |
烈阳异丙醇 发表于 2018-12-3 16:40 我用开关SW7禁用外部串行闪存(U2),发现MBT工作。 以上来自于百度翻译 以下为原文 I disabled the external serial flash (U2) with switches SW7 and found that MBT works. |
只有小组成员才能发言,加入小组>>
788个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7386 浏览 0 评论
2490 浏览 1 评论
2183 浏览 1 评论
4046 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2093 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7875浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6440浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
760浏览 2评论
735浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
8293浏览 2评论
/9
GMT+8, 2025-12-15 05:36 , Processed in 1.242132 second(s), Total 77, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2549
