电子发烧友论坛|
按用户指南把28335的I2C配置成从机后,用上位机给它发信息,28335进不了I2C的中断,请问是否有相关例程可以参考?
以下附上我自己的I2C初始化程序和ISR,我只是想做一下最简单的测试,让I2C一旦工作就进中断停下 附: //初始化程序 void init_I2C(void) [ // Step1: Config Own Address (work as a slave device) I2caRegs.I2COAR = PCM_I2C_DEVICE_ADDRESS; // TMS320F28335 I2C Module's own address // Step2: Config Module Clock // tips: clk_module = SYSCLKOUT/(IPSC+1) #if (CPU_FRQ_150MHZ) // Default - For 150MHz SYSCLKOUT I2caRegs.I2CPSC.all = 14; // Prescaler - need 7-12 Mhz on module clk (150/15 = 10MHz) #endif #if (CPU_FRQ_100MHZ) // For 100 MHz SYSCLKOUT I2caRegs.I2CPSC.all = 9; // Prescaler - need 7-12 Mhz on module clk (100/10 = 10MHz) #endif // Step3: Config I2C Bus SCLK clock // Reference: User Guide Page34 Section5.7.1 I2caRegs.I2CCLKL = 10; // Low-time duration , MUST BE NON ZERO I2caRegs.I2CCLKH = 5; // High-time duration , MUST BE NON ZERO // Step4: Config I2C Interrupt Source // Reference: User Guide Page26; Enable = 1, Disable = 0 I2caRegs.I2CIER.bit.AAS = 1; // Addressed as slave, poll I2CSTR.AAS I2caRegs.I2CIER.bit.ARBL = 0; // Arbitration lost, poll I2CSTR.ARBL I2caRegs.I2CIER.bit.ARDY = 0; // Register access ready, poll I2CSTR.ARDY I2caRegs.I2CIER.bit.NACK = 0; // No-acknowledgement, poll I2CSTR.NACK I2caRegs.I2CIER.bit.RRDY = 0; // [USED IN NON-FIFO MODE ONLY]Receive data ready, poll I2CSTR.RRDY I2caRegs.I2CIER.bit.SCD = 0; // Stop condition detected, poll I2CSTR.SCD I2caRegs.I2CIER.bit.XRDY = 0; // [USED IN NON-FIFO MODE ONLY]Transmit data ready, poll I2CSTR.XRDY // Step4: Config I2C Mode /* // [!!CRITICAL!!] Config it carefully, or I2C won't work // Reference: User Guide Page23 [NOTICE:USE .all FORMAT] I2caRegs.I2CMDR.bit.NACKMOD = 0;// [/15] NACK bit, 0:proper ACK bit will be sent, 1:NACK bit will be sent, and NACKMOD will be cleared I2caRegs.I2CMDR.bit.FREE = 0; // [/14] Free running, 0:breakpoints will work after I2C operation, 1:free run, ignore breakpoints I2caRegs.I2CMDR.bit.STT = 0; // [/13] Used in MASTER mode only, set to generate a START condition(S) [IRS=1 required] I2caRegs.I2CMDR.bit.rsvd1 = 0; // [/12] Reserved I2caRegs.I2CMDR.bit.STP = 0; // [/11] Used in MASTER mode only, set to trig a STOP condition(P) when data count to 0 [IRS=1 required] // MST & TRX have 4 combinations, corresponding to 4 modes supported by 28335 I2caRegs.I2CMDR.bit.MST = 0; // [/10] MASTER/SLAVE bit, 0:slave, 1:master(change to 0 after a STOP) I2caRegs.I2CMDR.bit.TRX = 0; // [/09] TRANSMITTER/RECIEVER bit, 0:receiver, 1:transmitter I2caRegs.I2CMDR.bit.XA = 0; // [/08] Expanded Address, 0:7-bit add, 1: 10-bit add I2caRegs.I2CMDR.bit.RM = 0; // [/07] Repeated Mode, 0:Non-repeat(set the I2CCNT), 1: Repeat mode(Manually STP required) I2caRegs.I2CMDR.bit.DLB = 0; // [/06] Digital Loop Back, 0:disable, 1:enable(useful in standalone test) I2caRegs.I2CMDR.bit.IRS = 0; // [/05] Reset bit, 0: module in reset/disabled, 1: module enabled I2caRegs.I2CMDR.bit.STB = 0; // [/04] START Byte bit, for low speed I2caRegs.I2CMDR.bit.FDF = 0; // [/03] Free Data format, 1:enable, XA is ignored, no address, data only I2caRegs.I2CMDR.bit.BC = 0; // [/02-00] Bit count, 0:default 8bit per byte, 1-7: 1-7 bit per byte I2caRegs.I2CMDR.bit.IRS = 1; // Take I2C out of reset */ I2caRegs.I2CMDR.all = 0x0020; // [RECOMMENDED IN NON-INIT OPERATION] 0000 0000 0010 0000 //Step5: Config FIFO Regs // Reference: User Guide Page36 [NOTICE:USE .all FORMAT] /* I2caRegs.I2CFFTX.bit.rsvd1 = 0; // [/15] Reserved I2caRegs.I2CFFTX.bit.I2CFFEN = 1; // [/14] Xmit FIFO mode enable, 1:en, 0:dis I2caRegs.I2CFFTX.bit.TXFFRST = 0; // [/13] Xmit FIFO reset, 0:hold in reset, 1:enable operation I2caRegs.I2CFFTX.bit.TXFFST; // [/12-08] READONLY, status counts of Xmit FIFO I2caRegs.I2CFFTX.bit.TXFFINT; // [/07] READONLY, Int Flag of Xmit FIFO I2caRegs.I2CFFTX.bit.TXFFINTCLR = 0;// [/06] Int Flag Clear, 1:clear TXFFINT I2caRegs.I2CFFTX.bit.TXFFIENA = 0; // [/05] Xmit FIFO int enable, 1:enable I2caRegs.I2CFFTX.bit.TXFFIL = 0; // [/04-00] Status level to trig Xmit FIFO int I2caRegs.I2CFFTX.bit.TXFFRST = 0; // enable Xmit FIFO Operation I2caRegs.I2CFFTX.bit.TXFFINTCLR = 0;// clear Xmit int at once to avoid detrimental events */ I2caRegs.I2CFFTX.all = 0x6000; // [RECOMMENDED IN NON-INIT OPERATION] /* I2caRegs.I2CFFRX.bit.rsvd1 = 0; // [/15-14] Reserved I2caRegs.I2CFFRX.bit.RXFFRST = 0; // [/13] Recv FIFO reset, 0:hold in reset, 1:enable operation I2caRegs.I2CFFRX.bit.RXFFST; // [/12-08] READONLY, status counts of Recv FIFO I2caRegs.I2CFFRX.bit.RXFFINT; // [/07] READONLY, Int Flag of Recv FIFO I2caRegs.I2CFFRX.bit.RXFFINTCLR = 0;// [/06] Int Flag Clear, 1:clear RXFFINT I2caRegs.I2CFFRX.bit.RXFFIENA = 0; // [/05] Recv FIFO int enable, 1:enable I2caRegs.I2CFFRX.bit.RXFFIL = 0; // [/04-00] Status level to trig Recv FIFO int I2caRegs.I2CFFRX.bit.RXFFRST = 0; // enable Xmit FIFO Operation I2caRegs.I2CFFRX.bit.RXFFINTCLR = 0;// clear Xmit int at once to avoid detrimental events */ //I2caRegs.I2CFFRX.all = 0x2040; // [RECOMMENDED IN NON-INIT OPERATION] I2caRegs.I2CCNT = 1; return; ] //I2C的ISR如下 __interrupt void i2c_isr(void) [ Uint16 IntSource, i; // Read interrupt source IntSource = I2caRegs.I2CISRC.all; // Interrupt source = stop condition detected if(IntSource == I2C_AAS_ISRC) [ i=I2caRegs.I2CDRR; __asm(" ESTOP0"); ] else [ __asm(" ESTOP0"); for(;;); ] PieCtrlRegs.PIEACK.all = PIEACK_GROUP8; return; ] |
1 个讨论
只有小组成员才能发言,加入小组>>
600 浏览 0 评论
1653 浏览 0 评论
2095 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1542 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1385 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1794浏览 29评论
2820浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1748浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1666浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1681浏览 13评论
/9
GMT+8, 2025-12-14 16:29 , Processed in 0.736418 second(s), Total 46, Slave 36 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2677
