电子发烧友论坛|
各位大家好,我有一些序列有多个段(ARB波形)接近1024,因此我不能做一个新的序列来一个接一个地播放它们。
所以我想一个接一个地播放这些序列,我正在使用SCPI命令来控制发生器,我已经尝试用“列表扫描”来做它,但它看起来像是一个新的序列,所以段的数量 是高就做那样的工作。 你是否知道例如是否可以发送一个命令:“播放第一个序列”然后在播放序列1时发送一个新命令说:“当你完成播放你的实际序列时,播放这个新的 一个(序列2)“? 谢谢你的帮助,Antoine 以上来自于谷歌翻译 以下为原文 Hello everybody, I have some sequences which have a number of segments (ARB waveforms) close to 1024, thus I can not do a new sequence of these to play them one after another. So I would like to play these sequences one after each other, I am using the SCPI commands to control the generator and I already try to do it with a "List Sweep" but it seems it works as a new sequence so the number of segments is to high to do it work like that. Do you know if it is possible for example to send a command which says: "Play this 1st sequence" and then to send a new command while playing the sequence 1 to say: "When you finished to play your actual sequence, play this new one (sequence 2)"? Thanks for your help, Antoine |
1个回答
嗨Antoine - 如果您获得选项019,它会将您的基带内存增加到64 Msa。
内存的增加将允许您访问8192个段或8个1024段的序列。 问候 - 以上来自于谷歌翻译 以下为原文 Hi Antoine - If you get option 019 it will increase your baseband memory to 64 Msa. The increase in memory will allow you to access 8192 segments or 8 sequences of 1024 segments. Regards - |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1844浏览 0评论
416浏览 0评论
/9
GMT+8, 2025-12-2 02:45 , Processed in 0.778450 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2445
