嗨,我尝试控制Agilent MXG N5182A并需要帮助。
我有一个创建的数据包库,其中包含各种通道衰落配置文件,用于自动,可重复的系统回归测试。 在matlab中生成的数据包/波形应加载到Agilent MXG N5182A中,并通过SCPI以Python脚本注入DUT。 我需要播放大量的数据包,为此我计划将波形加载到MXG并创建序列(如果可能的话?)现在我可以使用我的Python脚本仅使用安捷伦工作室创建的波形文件(.wfm)。 我在加载一组IQ数据文件并播放它时遇到问题。 我没有成功添加标记和头文件。 我使用SCPI命令将IQ数据文本文件加载到MXG。 自动创建标记和头文件,但标记文件似乎为空,可以使用VSA(矢量信号分析仪)接收。 我不明白有什么不对。 请帮忙。 我的工具:1。创建分组数据作为文本文件2.安捷伦工作室工具包3.安捷伦MXG N5182A我的数据文件供审查(是13292行的文本文件):1185,64491,63752,1070,1764,65069,60 ,64811,64341,663,64925,64738,4497,835,2055,410,63937,65245,24,226,66489,64473,2261,875,64532,64830,64894,63908,65206,3309,781,604,...... 我需要一个加载和播放一些数据文件的Python示例(使用/不使用序列)。 丹尼尔 以上来自于谷歌翻译 以下为原文 Hi, I try to control Agilent MXG N5182A and need a help. I have a created bank of packets with various channel fading profiles for automated, repeatable system regression tests. The packet/waveform generated in Matlab shall be loaded into Agilent MXG N5182A and injected to DUT with Python script via SCPI. I need to play big number of packets, for this purpose I plan load waveform to MXG and create sequences (If it possible?) Now I can play with my Python script only waveform files(.wfm) which was created with Agilent studio, And I have a problem with loading a bank of my IQ data files and playing it. I don't succeeded with adding a marker and header files. I loaded the IQ data text file to MXG with SCPI commands. Automatically created marker and header files, but marker file seems empty and can be received with VSA(Vector Signal Analyzer). I don't understand what is wrong. Please help. My tools: 1. Created packet data as text file 2. Agilent Studio Tool kit 3. Agilent MXG N5182A My data file for review (is it text file of 13292 lines) : 1185,64491, 63752,1070, 1764,65069, 60,64811, 64341,663, 64925,64738, 4497,835, 2055,410, 63937,65245, 24,226, 64689,64473, 2261,875, 64532,64830, 64894,63908, 65206,3309, 781,604, ... I need an Python example of loading and playing some data files (with/without using sequences). Daniel 附件
3个回答
您可以使用MATLAB和Instrument Control Toolbox将波形发送到仪器。
请参阅:http://www.mathworks.com/help/instrument/examples/generating-and-downloading-a-baseband-signal-to-an-rf-signal-generator.html 以上来自于谷歌翻译 以下为原文 You can use MATLAB and Instrument Control Toolbox to send the waveform to your instrument. See this: http://www.mathworks.com/help/instrument/examples/generating-and-downloading-a-baseband-signal-to-an-rf-signal-generator.html |
fen556 发表于 2019-1-29 08:59 vcherian,谢谢你的回复。 我以前读过这份文件。 不确定如果我想使用Matlab工具。 我更喜欢运行Python脚本。 有任何想法吗? 以上来自于谷歌翻译 以下为原文 vcherian, Thanks for the responce. I read the document before. Not sure If I want to use Matlab tools. I prefer to run a Python script. Any ideas? |
我没有成功添加标记和头文件。 不确定哪种格式以及如何添加标记文件? 以上来自于谷歌翻译 以下为原文 I don't succeeded with adding a marker and header files. Not sure which format and how to add a marker file? |
只有小组成员才能发言,加入小组>>
1846 浏览 0 评论
2740 浏览 1 评论
2641 浏览 1 评论
2451 浏览 5 评论
3461 浏览 3 评论
1847浏览 0评论
420浏览 0评论
/9
GMT+8, 2025-12-3 06:06 , Processed in 0.798089 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2445
