电子发烧友论坛|
大家好,
我使用MC workbench生成头文件,然后将它们复制到sys_drive_param文件夹中。然后当我在项目文件夹中打开工作区时。它只包含STM32F30x_userpoeject,但根据um1054手册,还应该有STM32F30x_MCLibrary,我可以编译代码而无需添加STM32F30x_MCLibrary,并且批量构建是Web发布库所必需的。 请指导我.. 谢谢 #stm32f100x-FOC-LIV-V4错误 以上来自于谷歌翻译 以下为原文 hello every body, i generated header files using MC workbench, and then copy them into sys_drive_param folder. then when i open workspace in project folder. it contains only STM32F30x_userpoeject, but according to the um1054 mannual , there should also be STM32F30x_MCLibrary, can i compile the code without adding STM32F30x_MCLibrary, and batch build is necessary for web distribution lib.? please guide me.. thanks #stm32f100x-foc-liv-v4-error |
4个回答
是的,我也面临着这个问题..任何人都可以帮助我......?
以上来自于谷歌翻译 以下为原文 hye, i am also facing that problem.. can anybody please help me...? |
你好,
我遇到了似乎同样的问题: - 我已经从st motor workbench(lib foc V4)正确生成了我的配置。所有检查似乎都没问题。 (mcu:STM32F100 =中等) - 当我尝试编译时,我得到了几次错误: 致命错误[Pe035]:#error指令:''配置无效:控制阶段parameters.h中的MCU定义与选定的板不兼容。请将ST电机控制工作台用于E: ST_WORSKPACE LOW_VOLTAGE Project CrossCheck.h 118 虽然,我的配置似乎很好。根据stm32f100的要求,我使用单个分流器,因为我使用的是demoboard ihm033V1,所有用户界面都被禁用。 我错过了什么吗? 在CrossCheck.h中,似乎没有任何与STM32F100x_MD相关的检查,STM32F100x_MD被定义为“控制阶段parameters.h”中的MCU。这是故意还是错误? 以上来自于谷歌翻译 以下为原文 Hello, I encounter what seems to be the same problem : - I have properly generated my configuration from st motor workbench (lib foc V4). All checks seems to be ok. (mcu : STM32F100 = medium) - When I try to compile, I got several time the error : Fatal Error[Pe035]: #error directive: ''Invalid configuration: MCU definition in Control stage parameters.h not compatible with selected board. Please use the ST Motor Control Workbench to E:ST_WORSKPACELOW_VOLTAGEProjectCrossCheck.h 118 Although, my configuration seems to be fine. As required with a stm32f100, I am use single shunt and as I am using demoboard ihm033V1, all user interfaces are disabled. Am I missing something ? In CrossCheck.h, there does not seem to be any check related to STM32F100x_MD, defined as the MCU in ''Control Stage parameters.h''. Is it intended or is it a bug ? |
对不起人!
我忘了编辑项目配置(fot stm32f100 MCU ...) 在IAR中:project-> edit configuration->选择STM32100B-eval 让我们现在运行GUI! 以上来自于谷歌翻译 以下为原文 Sorry folks ! I forgot to edit the project configuration (fot stm32f100 MCU...) In IAR : project->edit configuration-> Select STM32100B-eval let's get the GUI running now ! |
再见,
通常没有必要改变项目设置。这是因为我们提供了不同的配置,并且每个评估板都有适当的设置。 IAR或Keil内有一个下拉框菜单,用于选择与旧主板相关的项目设置。 CrossCheck负责根据ST MC Workbench中的设置验证用户是否在此下拉框菜单中选择了正确的值。 再见 梁咏琪 以上来自于谷歌翻译 以下为原文 Ciao, usually there is no need to chenge the project setting. This because we provide different configuration with the proper setting valid for each evaluation board. There is a drop box menu inside IAR or Keil to select the project setting related to the used board. The CrossCheck take care to verify that the user select the right value in this drop box menu according to the setting done in the ST MC Workbench. Ciao Gigi |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1469 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1521 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3668 浏览 1 评论
3860 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2477 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
748浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
680浏览 5评论
727浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
968浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
771浏览 5评论
/9
GMT+8, 2025-12-12 03:28 , Processed in 0.843099 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1890
