电子发烧友论坛|
你好,
我使用StLING LWB模块评估板与STM32 F411E迪斯科板和最新的WICD SDK(V3.0.1)在Windows上。 我有2个问题: 1)我开始用Snif.SCA-LSRSTELLIN 900950-THEXX-NETXSDIO下载下载程序运行,WiFi不工作。 2)当我尝试调试时(SNIP.SCA-LSRSTURLIGHON9950-Debug下载)不运行并返回此错误: [新螺纹1752347062 ] 程序接收信号SIGTRAP,跟踪/断点陷阱。 [切换到线程1752347062 ] 0X0800 C65 A在WICES/Stale/MCU/STM32 F4XX/..…/ARMYCM4/CRT00GCC。C:81() (81) 谢谢, 阿尔贝托 以上来自于百度翻译 以下为原文 Hi, I'm using the STERLING-LWB module evaluation board with an STM32F411E-DISCO board and the latest WICED SDK (v6.0.1) on Windows. I have 2 problem: 1) I started to flash firmware with snip.scan-LSRSTERLING_00950-ThreadX-NetX-SDIO download download_apps run and the WiFi doesn't work. 2) When i'm trying to debug (snip.scan-LSRSTERLING_00950-debug download ) doesn't run and return this error: [New Thread 1752347062] Program received signal SIGTRAP, Trace/breakpoint trap. [Switching to Thread 1752347062] 0x0800c65a in _start () at WICED/platform/MCU/STM32F4xx/../../ARM_CM4/crt0_GCC.c:81 81 __asm__( " ldr r1, =link_stack_endn" Thanks, Alberto |
9个回答
更新:
如果我使用WSDICSDK V4.1.3,WiFi工作正常,但是OpenCOD全BRCM-LIbftdi.EXE进程崩溃。 以上来自于百度翻译 以下为原文 UPDATE: If I use the WICED SDK v4.1.3 the wifi works correctly, but the openocd-all-brcm-libftdi.exe process crashes. |
你好,
我们有我们的支持团队来调查这个问题。我们很快就会回复你。谢谢您! 以上来自于百度翻译 以下为原文 Hi There, We have our support team looking into this. We will get back to you shortly. Thank you! |
埃里克森1709311 通过在AppultIsStistAd()中添加断点,解决了调试模式。 当我在V3.0.1上使用下载程序时,我注意到WiFig固件的大小低于V4.1.3,但我不知道问题到底在哪里。 以上来自于百度翻译 以下为原文 ryan.erickson_1709311 I solved the debug mode by adding a breakpoint in application_start(). When I use download_apps on v6.0.1 I noticed that the size of WIFI_FIRMWARE is lower than v4.1.3, but I didn't understand where is exactly the problem. |
asd008 发表于 2018-11-23 18:36 我很高兴你解决了这个问题。我们用老SDK做的例子。为了使用较新的V1.01 SDK,可能需要一些移植工作。我们需要当前的计划来更新我们的例子来与SDK V60.1一起工作。 以上来自于百度翻译 以下为原文 I am glad you have solved your issue. Our examples we made with the older SDK. To use the newer v6.01 SDK some porting work is likely needed. We have to current plans to update our examples to work with SDK v6.0.1. |
keith3000 发表于 2018-11-23 18:48 如果这个问题解决了,你能把它标记为答案吗?谢谢! 以上来自于百度翻译 以下为原文 If this issue is solved, could you please mark it as answered? Thanks! |
keith3000 发表于 2018-11-23 18:48 嗨,瑞恩.埃里克森1709311,我现在需要和SDK 60.1一起工作。 我怎样才能改变图书馆工作呢? 谢谢, 银 以上来自于百度翻译 以下为原文 Hi ryan.erickson_1709311, I need to work with SDK 6.0.1 now. How can I change the library to work with that? Thanks, AG |
你好, 我们目前没有任何SDK 60.1的移植指令。你需要亲自完成这项工作。 以上来自于百度翻译 以下为原文 Hello, We currently do not any porting instructions for SDK 6.0.1. You will need to go through this effort yourself. |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-2 07:14 , Processed in 0.895263 second(s), Total 88, Slave 71 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2662
