在Win7 64位机器上安装13.2后,没有任何图标可以工作(在开始菜单或桌面等)
所以我看了一下为什么,并发现他们都先调用了settings64.bat文件。 在查看此文件时,我注意到它与前一个12.4版本的区别在于一个点: 在10号线和10号线上 11: 如果EXIST %% d .settings64.bat(调用%% d .settings64.bat 如果你删除settigns64.bat中的点,一切都很好: 如果EXIST %% d settings64.bat(调用%% d settings64.bat 有人可以详细说明为什么要做出这种改变吗? 之前的版本没有使用前面的点。 以上来自于谷歌翻译 以下为原文 After installing 13.2 on a Win7 64bit machine none of the icons would work (in the start menu, or desktop, etc.) So i took a look into why, and found that they all called the settings64.bat file first. In looking at this file I noticed that it differs from the previous 12.4 version by a single dot: on lines 10 & 11: if EXIST %%d.settings64.bat ( call %%d.settings64.bat if you remove the dot in from of settigns64.bat everything works great: if EXIST %%dsettings64.bat ( call %%dsettings64.bat Could someone elaborate on why this change was made? The previousl versions didnt use the dot in front. |
2个回答
好吧,所以我想通了,你需要settings64.bat文件中的点,因为EDK目录中有.settings64文件。
我仍然不确定在弹出并立即消失的cmd窗口中显示的错误消息是什么,但是当右键单击快捷方式& 选择以管理员身份运行,一切都很完美。 它甚至修复了我与EDK无法找到一些核心文件的其他问题(我认为这是有道理的,因为正在设置的环境可变量没有设置,没有这个脚本正常运行)。 因此,如果您遇到问题,请安装在windows7 64bit中,只需设置快捷方式以管理员身份运行即可。 Xilinx也应该在Windows7用户的安装帮助文件中提到这一点。 以上来自于谷歌翻译 以下为原文 Alright, so i figured it out, you need the dots in the settings64.bat file since there are .settings64 files in the EDK directory. Im still not sure what the error message is that is being displayed in the cmd window that pops up and disappears immediately, but when right clicking on the shortcut & choosing run as administrator, everything works perfectly. It even fixed my other issue I was having with EDK not being able to find some core files (which i guess makes sense since the environment vairables that were being setup werent setup without this script running correctly). So to all that are out there installing in windows7 64bit if you have issues, just setup the shortcut to run as administrator. Xilinx should mention this in their installation help file for Windows7 users as well. |
你好。
我遇到了同样的问题。 当我从磁盘C的根目录中删除TEMP目录时开始:(我“几乎”确定,TEMP目录是在ISE 13.2安装期间创建的) 没有指向此目录的系统变量,但是当您删除它时,ISE将无法运行。 马丁 以上来自于谷歌翻译 以下为原文 Hi. I've had the same problem . It started when I removed the TEMP directory from root of disk C: (I'm "almost" sure, that the TEMP directory was created during the ISE 13.2 install) There are no system variables pointing to this directory but when you remove it ISE won't run. Martin |
只有小组成员才能发言,加入小组>>
2383 浏览 7 评论
2800 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2263 浏览 9 评论
3336 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2430 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
756浏览 1评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
545浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
366浏览 1评论
1964浏览 0评论
683浏览 0评论
GMT+8, 2024-11-23 11:02 , Processed in 1.147896 second(s), Total 80, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
