电子发烧友论坛|
我在尝试完成一个项目后完成以下的错误:
我已经运行了更新组件,并看到安装的CythBooD版本为5.6。时钟版本为1,2。这两个都属于 所以我认为它们是相关的问题。 以上来自于百度翻译 以下为原文 I am getting the following error(s) when I try to build a project after just completing schematics: I have already run Update Components, and see that the installed cy_boot version is 5.6. The clock version is 1,2. Both of these fall under So I assume they are related issues. |
7个回答
还有几个问题。我的目标是CyBul-21400—00。我很好奇,因为表说这只支持BLE版本4.1,但是BLE版本4.2仍然显示在“组件”选项卡下。有一个CYBLY-21401501,它是BLE组件4.2兼容的。但由于缺乏可用性,我不愿使用这部分。我假设Cyb BooToV420的抱怨与使用BLE组件4.20是巧合,因为这些是完全不同的事情。
以上来自于百度翻译 以下为原文 A couple more questions. The device I am targeting is CYBLE-214009-00. I am curious because the table says this supports only BLE version 4.1, but still BLE version 4.2 is showing up under components tab. There is a CYBLE-214015-01 which is BLE component version 4.2 compatible. but I would rather not use this part due to its lack of availability. I am assuming that the complaint of cy_boot_v4_20 is coincidental with the use of BLE component 4.20, as these are completely different things. |
***kwnefd 发表于 2018-11-22 16:01 你能用LFY-CLK做其他事情吗?或者当它只用于BLE时,它会抱怨吗? (可能是CyPress无法过滤BLE V4.2的可用性/可用性) 以上来自于百度翻译 以下为原文 Can you use the LF_CLK for other things? Or is it complaining when trying to use it for BLE only? (It could be that Cypress failed to filter the BLE v4.2 from being available/usable) |
(可能是CyPress无法过滤BLE V4.2的可用性/可用性) 是的,但是当我指向一个V4.2的设备时,我也有同样的抱怨吗?? CyBooGo和收音机BLE是一样的吗? 以上来自于百度翻译 以下为原文 (It could be that Cypress failed to filter the BLE v4.2 from being available/usable) Yes, but I get the same complaint when I point to a BLE v4.2 capable device?? Is the cy_boot the same thing as the radio ble? |
我注意到,设计宽的资源指示器是灰色的,旁边有一个问号。你知道那意味着什么吗? IMAG1001.PNG 18.1 K 以上来自于百度翻译 以下为原文 I’m noticing that the Design Wide Resource indicator is grayed out with a question mark next to it. Do you know what that means
***kwnefd 发表于 2018-11-22 16:31 CyoBooT不同于无线电广播,每个都有它自己的版本。AFIK,CythBoog是处理接口命令/指令到底层ARM芯片的代码,而BLE组件负责处理蓝牙堆栈/ API/配置文件。 可能尝试清洗,然后重建整个项目? 否则,您可能会干扰项目文件以使其重新加载导致问题的文件: 从头开始创建一个新的项目,看看是否引起了同样的问题,使文件出错,然后重新加载并尝试重建项目。 以上来自于百度翻译 以下为原文 cy_boot is different than the radio BLE; Each one has it's own version. Afaik, the cy_boot is the code that handles interfacing commands/instructions to the underlying ARM chip, and the BLE component is responsible for handling the bluetooth stack/apis/profiles. Potentially try cleaning, then rebuilding the whole project? Otherwise, you could messing with the project files to get it to reload the files that are causing issues:
不知道,以前没见过。这可能是一个PSoC Creator版本不匹配问题,或丢失/损坏的项目文件,或损坏/丢失安装文件? 以上来自于百度翻译 以下为原文 No idea; Haven't seen it before. It might be a PSoC Creator version mismatch issue, or missing/corrupted project files, or corrupted/missing installation files? |
这是我自己制造的问题。我尝试在Windows资源管理器中重命名文件,而不是在PSoC创建者中重命名,我想我漏掉了一些。 谢谢 吉姆 以上来自于百度翻译 以下为原文 This was a problem of my own making. I tried renaming files within Windows Explorer, rather than within PSOC creator, and I guess I missed a few. Thanks Jim |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7102 浏览 0 评论
2477 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2074 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7579浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6127浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7973浏览 2评论
/9
GMT+8, 2025-12-2 22:22 , Processed in 0.697170 second(s), Total 84, Slave 67 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1644
