电子发烧友论坛|
嗨,
我们正在使用带有ICS电流检测和状态观察器+ PLL的FOC SDK 4.1。具有21极对和11mOhms和Ls0,017mH的电动机可以很好地运行到6000rpm。 现在使用霍尔传感器改变速度/反馈以改善启动会给电流调节带来一些问题。启动工作完美,电流接近正弦波达1800 rpm(观察者+ pll更完美)。在较高的RPM下,相电流看起来像正确的位置是不正确的。 电流的幅度非常不同,并且在短时间内与速度不同步,然后与高电流幅度同步 。 ICS和霍尔传感器有任何已知的限制吗?当前/霍尔过滤或引擎设置的变化没有带来任何改进 。 任何帮助都会很棒。 30.03.2016问题解决了顺利进行 以上来自于谷歌翻译 以下为原文 Hi, we are using FOC SDK 4.1 with ICS current sensing and State Observer + PLL. A Motor with 21 pole pairs and Rs 11mOhms and Ls 0,017mH runs up to 6000 rpm very well. Now changing to Speed / Feedback with Hall Sensor for improved startup give some problems in current regulation. Startup works perfect, currents are near sinusoidal up to 1800 rpm (more perfect on observer + pll). On higher RPM the phase currents look like positon is not right calculated. The amplitudes of the currents are very different and are not synchronous with the speed for a short time, then be synchronized hard with high current amplitude . Are there any known limitations with ICS and Hall sensors? Change in the current/hall filtering or engine setups brought no improvement . Any help will be great. 30.03.2016 Problems solved running smoothly |
4个回答
再见
阅读你的帖子我的第一个想法是,FW从HALL传感器信号中引入的延迟可能会在测量角度时产生一些误差(因为我认为霍尔传感器的电气频率应该非常快,有21个极对)虽然我没有看到ICS有任何特殊问题。 您能否详细介绍一下您是如何解决这些问题的? 谢谢 再见 梁咏琪 以上来自于谷歌翻译 以下为原文 Ciao Reading your post my first idea was that probably the delay introduced by the FW from the HALL sensor signal generates some error in the measurement of the angle (since I think that the electrical frequency of the hall sensors shall be quite fast with 21 poles pairs), while I don't see any particular issues with the ICS. Can you give us few details about how did you resolve the issues? Thanks Ciao Gigi |
嗨吉吉,
我们已经解决了这个问题,从传感器开始,从霍尔传感器到Observer + PLL的机械速度从400转/分钟切换。如果速度低于300转/分钟 加工 再次 带传感器 。 辅助传感器和大厅之间的良好固件切换非常容易并且工作完美。 最好的祝福 工学硕士。 ING。约翰斯佩格尔 以上来自于谷歌翻译 以下为原文 Hi Gigi, We have solved the problem by starting with sensors and switch from a mechanical speed of 400 rev / min from Hall sensors to Observer + PLL. If speed is below 300 rev / min working again with sensors . Great Firmware switching between aux sensor and hall is very easy and work perfekt. Best regards Dipl. Ing. Johann Spegele |
Ciao Johann
很高兴看到这个!谢谢 再见 梁咏琪 以上来自于谷歌翻译 以下为原文 Ciao Johann Nice to read this! Thanks Ciao Gigi |
你好吉吉,
这是一篇古老的文章,但我对HALL传感器有疑问。 真的有HALL速度传感器的一些限制吗?我的意思是一些最大频率?你提到了FW的一些延迟 - 你是在谈论中断的处理时间吗?还是其他一些问题? 我也面临着一个非常类似的问题。我有4极电机。高达~2500rpm的电机与HALL平稳运行,但我无法超过3000rpm。电机运行不规则。最高速度为8000rpm。使用无传感器传感器,达到此速度是没有问题的。 我也将尝试以与此处描述的方式相同的方式解决此问题。无论如何,我想知道是否真的没有机会使用HALL传感器进行高速运转。 以上来自于谷歌翻译 以下为原文 Hello Gigi, It's qiute an old post here, but I have a question regarding HALL sensor. Is there realy some limitation of HALL speed sensor? I mean some maximum frequency? You mentioned some delay of FW - Are you talking about processing time in interupt? Or some other issue? I'm also facing a very resemble problem. I have 4 poles motor. Up to ~2500rpm motor runs smoothly with HALL, but I'm not able to go above 3000rpm. Motor runs irregularly. The max speed is 8000rpm. With sensorless sensor there is no problem to reach this speed. I will also try to solve this problem the same way as it is describet here. Anyhow, I would like to know if there is realy no chance to use HALL sensors for high speed. |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
661浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
941浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-1 23:52 , Processed in 0.654726 second(s), Total 46, Slave 39 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3464
