扫一扫,分享给好友
你好。
我正在使用一个需要使用Web Pack的计算机体系结构类,所以我下载了.tar,未压缩它但是每当我双击“setup.exe”文件时,都没有任何反应。 但有时,我会得到一个对话框,询问程序是否正确安装。 我的一位同学说他在Win7 x32下安装它(11.1)就好了,所以我不确定发生了什么。 我试着在董事会中寻找解决方案,但一无所获。 我也看到这个问题发生在另一个运行Vista x64的同伴(设置无法打开)。 请帮忙, 谢谢。 编辑:它是vista x64而不是x32 消息由xvelezv编辑于09-01-2009 10:13 PM 以上来自于谷歌翻译 以下为原文 Hello. I am taking a computer architecture class that requires the usage of the Web Pack, so I downloaded the .tar, uncompressed it but whenever I double click the "setup.exe" file, nothing happens. Sometimes however, i get a dialog asking if the program installed properly. One of my class mates said he installed it (11.1) just fine under Win7 x32, so I'm not exactly sure what is happening. I tried searching for solutions in the board but have found nothing. I also saw this problem happening to yet another class mate who was running Vista x64 (setup wouldn't open). Please help, Thanks. edit: it was vista x64 not x32 Message Edited by xvelezv on 09-01-2009 10:13 PM |
5个回答
你在哪里找到setup.exe文件?
它是在桌面上还是其他带空格的路径上? 如果是这样,请尝试将其移至C:并查看它是否会运行。 以上来自于谷歌翻译 以下为原文 Where do you have the setup.exe file located? Is it on the desktop or another path with spaces? If so try moving it to the C: and see if it will run. |
你好!
我的一个朋友告诉我将它移动到c:也,并重命名文件夹...所以我将其重命名为“xilinx”并将其移至c:但是,它仍然无法打开。 Webpack可能与64位操作系统完全不兼容吗? 以上来自于谷歌翻译 以下为原文 Hello! One of my friends told me to move it to c: also, and also to rename the folder... so I renamed it to "xilinx" and moved it to c: however, it still doesn't open. Is the webpack just completely incompatible with 64bit operating systems perhaps? |
您是否尝试从/ bin / nt64下运行xsetup.exe?
以上来自于谷歌翻译 以下为原文 Have you tried running xsetup.exe from under /bin/nt64? |
我在Win7 x64上使用了Firefox,并通过webinstaller安装了它(没有.tar文件,听起来好像你使用的是Linux版本)。
它工作正常,除了安装失败后执行的11.2升级。 虽然没有调查过,也许没什么。 祝你好运! 以上来自于谷歌翻译 以下为原文 I've used Firefox on my Win7 x64, and installed it through the webinstaller (no .tar file, sounds as if you've used the Linux version). It worked fine, except the 11.2 upgrade which it performs after the installation keeps failing. Haven't looked into it though, perhaps it is nothing. Good luck! |
只有小组成员才能发言,加入小组>>
2322 浏览 7 评论
2734 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2217 浏览 9 评论
3295 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2369 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
656浏览 1评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
463浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
226浏览 1评论
669浏览 0评论
1864浏览 0评论
GMT+8, 2024-10-1 21:14 , Processed in 1.463994 second(s), Total 84, Slave 68 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
