电子发烧友论坛|
嗨团队,需要你的帮助!
我们有Agilent E3631A,我们正面临以下问题,请帮助!!!!!!!!!!! 显示器持续保持恒定值+ 6v通道“0.096v和0.040 A”和+ 25v通道“0.00v和0.037 A”但我可以更改“DIPLAY LIMIT”模式中的值,我可以观察到的变化 显示,我们可以使用万用表测量读数。 在正常操作模式下,它不反映显示的变化,它给出了上面的恒定值(回读不工作)即使我多次关闭和打开电源,我看到相同的是否有任何命令或寄存器设置回读问题? 在此先感谢您的支持。 此致,TPO 以上来自于谷歌翻译 以下为原文 Hi Team, Need your Help! We have Agilent E3631A,we are facing below problem, kindly help!!!!!!!!!!! The display is continuously staying in constant value for +6v channel “0.096v and 0.040 A” and +25v channel “0.00v and 0.037 A” But I can change the value in” DIPLAY LIMIT” mode and I can observe the changes in the display and we can able to measure the readings using Multimeter. In normal operation mode it doesn’t reflect the changes in display and it gives above constant value(readback not working) Even I did multiple time power off and on and I am seeing the same Is there any commands or register setting for readback issue? Thanks in advance for your support. Regards, TPO |
1个回答
即使输出不同的电压和电流,仪表也不会更新?
如果是这种情况,您似乎可能希望将设备发回给我们进行维修。 对于那个很抱歉。 以上来自于谷歌翻译 以下为原文 SO even though it is outputting different voltages and currents, there meter is not updating? If that is the case, it seems like you might want to send the unit back to us for service. Sorry about that. |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1844浏览 0评论
416浏览 0评论
/9
GMT+8, 2025-12-1 23:46 , Processed in 0.647895 second(s), Total 70, Slave 53 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2003
