我正在使用E3631A和labview.the驱动程序是从NI.the驱动程序查询系统的即插即用驱动程序下载:错误?
对于几乎所有发送到电源的命令。如果通信速度很快,这不是问题。我现在的问题是E3631响应时间约为1秒。 (最坏情况)正常通信需要不到5ms甚至系统:错误? 只需不到100毫秒。但是,它只需要〜1秒。有一种方法可以加速系统:错误? 查询?还是有一个驱动程序在每个命令后都没有发送过这个?谢谢 以上来自于谷歌翻译 以下为原文 i am using the E3631A with labview. the driver was plug and play driver download from NI. the driver query syst:err? for almost all command it sent to the power supply. that's not a problem if the communication was fast. my problem now is that the E3631 takes ~1 second to response. (worst case) normal communication takes less than 5ms. and even syst:err? takes only less than 100ms. but ocationally it takes ~1second. is there a way to speed up the syst:err? query ? or is there a driver that actually do not sent this after every command ? thanks |
1个回答
安捷伦为此电源提供IVI驱动器。
我不熟悉NI的驱动程序,但我不认为E3631A需要大约1秒来响应“SYST:ERR?” 查询。 我在这里尝试使用直接SCPI,我没有看到这种症状。 我让“SYST:ERR?” 继续循环1000次,最长时间为150ms。 要确定是由于驱动器还是由于电源,您可以尝试直接SCPI并查看此问题是否仍然存在。 以上来自于谷歌翻译 以下为原文 Agilent offers IVI driver for this power supply. I'm not familiar with NI's driver, but I don't think E3631A will take ~1s to respond to "SYST:ERR?" query. I try it out over here with direct SCPI and I don't see this symptom. I let the "SYST:ERR?" continues looping for 1000 times and the longest time it takes is 150ms. To isolate whether it is due to driver or due to the power supply, you may try out direct SCPI and see if this problem still exists. |
只有小组成员才能发言,加入小组>>
2130 浏览 1 评论
1907 浏览 1 评论
1758 浏览 5 评论
2633 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1598 浏览 4 评论
576浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
405浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
489浏览 0评论
2296浏览 0评论
1343浏览 0评论
GMT+8, 2024-6-26 17:05 , Processed in 1.800588 second(s), Total 79, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
