电子发烧友论坛|
亲爱的先生…
我的项目是从RFID标签读取RFID数据。RFID的频率是125千赫。我要做的是捕捉在125千赫的脉冲在单针。PIN DEMODE I配置为捕获PIN,因为我将接收关于该特定PIN的数据。我配置的定时器[V2.70]作为捕获和配置设置,它作为定时器配置文件在这个页面中被附加。 在该定时器块时钟输入是存在的。在那个输入端应该出现什么时钟信号?内部时钟信号在哪一个控制器上工作,或者应该是125千赫? 我想在每一个上升沿和下降沿中断,然后我需要计算脉冲的时间,高时间和低时间。因此,当中断发生时,我需要获得捕获计数,同时需要计时器计数。哪个寄存器或哪个函数提供捕获计数和计时器计数? 以上来自于百度翻译 以下为原文 Dear sir.. My project is to read RFID data from RFID tag. Frequency of the RFID is 125 KHZ. what I am supposed to do is to Capture the pulses at 125 KHZ on the single pin. PIN DEMODE I had configured as capture PIN as I will receive the data on that particular pin. I configured TIMER [V2.70] as capture and configurations setting for it is attached in this Page as TIMER Configuration file. In that timer block Clock input is present. what clock signals should be present at that input? either internal Clock signal on which entire controller is working or it should be 125 Khz? I want interrupt at every rising and falling edge then I need to calculate the time of the pulse high time and low time. So for that I require to get the capture count when interrupt occurred and also the timer count at the same time. Which register or which function provides the Capture count and the timer count ? |
5个回答
在PSoC文档中,“捕获计数”反映了捕获事件的数量。在有效捕获时,当前计时器计数被转移到一个4字深度FIFO,从那里您可以读取TimeReAdvAccess()API。
125kHz的中断频率太高,不能工作。 配置中的“时钟”信号会降低计数值。 我不太熟悉RFID信号,请提供一个链接到您的设备的数据表。 鲍勃 以上来自于百度翻译 以下为原文 In PSoC documentation the "Capture Count" reflects to the number of apture events. At a valid capture the current timer count is transferred into a 4 word deep FIFO from where you may read with the Timer_ReadCapture() API. An interrupt frequency of 125kHz is way too high and will not work. The "Clock" signal in your configuration will decrease the count value. I am not quite familar with the RFID signal, please provide a link to the datasheet of your device. Bob |
ncmza 发表于 2018-11-15 07:54 希伊先生, 我在这封邮件中附加了数据表EM4095。或链接 HTTP://www. En微电子公司.COM/SITES/DeFult/Fiels/Puffuls/DaseHeTs/EM4095G.DS.PDF 菲力克科技(印度)有限公司 G.I.D.C.路6号PLOT-63 KATWADA,AHMADABAD-38 2 430。 pH值08401219941。 手机- 98250 0942093740,22660。 电梯控制面板,ARD,DOTMART,LCD-TFT显示器,地板 ANN系统,触摸屏,COPS,LOPS,门禁控制器,门 集箱,光幕传感器,音频设备,电梯主,电梯显示器。 定时器,TEMP.PROGRAMMER,PLC,SCADA和自动化面板,PCC,MCC 面板。 菲尔布里克斯控制网@ YaHoo.com www. PyrBrimkimdia.com 在THU,2018年1月11日下午4:05,USER13138899&社区管理器CyPress。 EM4095HMSO16A.PDF 206.2 K 以上来自于百度翻译 以下为原文 Hii sir, I have attached the Datasheet em4095 in this mail. or link http://www.emmicroelectronic.com/sites/default/files/public/products/datasheets/em4095_ds.pdf philbrick Technologies (India) Pvt. Ltd. PLOT-69,ROAD NO.-6, G.I.D.C. KATHWADA, AHMEDABAD-382 430. PH- 08401219941. Mobile- 98250 09420,93740 22660. ELEVATOR CONTROL PANELS, ARD, DOTMATRIX, LCD-TFT DISPLAYS, FLOOR ANN.SYSTEM, TOUCH PANEL, COPs, LOPs, DOOROPERATOR CONTROLLER, DOOR HEADER, LIGHT CURTAIN SENSOR, AUDIO DEVICES, LIFT MASTER, LIFT DISPLAY. TIMERS, TEMP.PROGRAMMER, PLC, SCADA& AUTOMATION PANELS, PCC, MCC PANELS. philbrick_controls@yahoo.com www.philbrickindia.com On Thu, Jan 11, 2018 at 4:05 PM, user_1377889 <community-manager@cypress.com
adonknight 发表于 2018-11-15 08:09 125 kHz的频率是RF载波频率。数据在RF上进行调制。因此,你应该找出你想要读取的设备产生了什么样的信号。可能是像FRMOM UART那样的串行数据。 鲍勃 以上来自于百度翻译 以下为原文 The 125 kHz frequency is the RF carrier frequency. The data is modulate on the RF. So you should find out what kind of signal is generated by the device you want to read from. Could be something like serial data as frfom UART. Bob |
ncmza 发表于 2018-11-15 08:29 嗨,鲍伯 我正在接收单针DEMD DIN上的数字信号。 由代码解码为1或0。我在曼彻斯特得到信号 编码格式。UART不支持EM4095。 菲力克科技(印度)有限公司 G.I.D.C.路6号PLOT-63 KATWADA,AHMADABAD-38 2 430。 pH值08401219941。 手机- 98250 0942093740,22660。 电梯控制面板,ARD,DOTMART,LCD-TFT显示器,地板 ANN系统,触摸屏,COPS,LOPS,门禁控制器,门 集箱,光幕传感器,音频设备,电梯主,电梯显示器。 定时器,TEMP.PROGRAMMER,PLC,SCADA和自动化面板,PCC,MCC 面板。 菲尔布里克斯控制网@ YaHoo.com www. PyrBrimkimdia.com 在SAT,2018年1月13日凌晨1时28分,USER13138899&社区管理器CyPress 以上来自于百度翻译 以下为原文 hi Bob I am receiving Digital signal on the single pin Demod din which is to be decoded as 1 or 0 by the code. I am getting the signals in MANCHESTER encoding format. UART is not supported by EM4095. philbrick Technologies (India) Pvt. Ltd. PLOT-69,ROAD NO.-6, G.I.D.C. KATHWADA, AHMEDABAD-382 430. PH- 08401219941. Mobile- 98250 09420,93740 22660. ELEVATOR CONTROL PANELS, ARD, DOTMATRIX, LCD-TFT DISPLAYS, FLOOR ANN.SYSTEM, TOUCH PANEL, COPs, LOPs, DOOROPERATOR CONTROLLER, DOOR HEADER, LIGHT CURTAIN SENSOR, AUDIO DEVICES, LIFT MASTER, LIFT DISPLAY. TIMERS, TEMP.PROGRAMMER, PLC, SCADA& AUTOMATION PANELS, PCC, MCC PANELS. philbrick_controls@yahoo.com www.philbrickindia.com On Sat, Jan 13, 2018 at 1:28 AM, user_1377889 <community-manager@cypress.com |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
709浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7961浏览 2评论
/9
GMT+8, 2025-12-1 17:26 , Processed in 0.798684 second(s), Total 80, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1160
