电子发烧友论坛|
大家好!
我在异步模式下使用带有UART的STM8S003F微控制器。我想在推挽模式下使用UART1_CK引脚作为常规GPIO。这个引脚是PD4。外围设备配置如下: PD_DDR_DDR4 = 1; //输出引脚PD4(EN) PD_CR1_C14 = 1; //引脚PD4设置为P-P模式。 PD_CR2_C24 = 1; //引脚PD4可以运行高达10 MHz。 UART1_CR3_CKEN = 1; 在每次字节传输时,字节通过UART传输。然后我通过写入来禁用UART时钟输出: UART1_CR3_CKEN = 0; 在那个引脚PD4变低,并写入 PD_ODR_ODR4 = 1; 什么都没有。 PD4引脚上不会出现高逻辑电平。 我的代码出了什么问题?我还应该检查什么? #stm8s003f3#pd4#push-pull 以上来自于谷歌翻译 以下为原文 Hi all! I am using STM8S003F microcontroller with UART in async mode. I want to use UART1_CK pin as regular GPIO in push-pull mode. This pin is PD4. When peripherals are configured as below: PD_DDR_DDR4 = 1; // Pin PD4 (EN) is output PD_CR1_C14 = 1; // Pin PD4 is set to P-P mode. PD_CR2_C24 = 1; // Pin PD4 can run up to 10 MHz. UART1_CR3_CKEN = 1; and byte is transmitted via UART, on each byte transmission. Then I disable UART clock output by writing: UART1_CR3_CKEN = 0; After that pin PD4 goes low, and writing PD_ODR_ODR4 = 1; gives nothing. High logic level doesn't appear on PD4 pin. What's wrong with my code? What else should I check? #stm8s003f3 #pd4 #push-pull |
4个回答
我没有经验,但检查是否需要禁用UART(不仅关闭其时钟)以取消其对连接引脚的控制
以上来自于谷歌翻译 以下为原文 I am not experienced, but check if it is needed to disable UART ( not just turning its clock off ) to cancel its control over the connected pins |
问题是我需要UART =)在我的电路中,PD4用于驱动RS485芯片的ENABLE引脚。
以上来自于谷歌翻译 以下为原文 The problem is that I need the UART =) In my circuit PD4 is intended for driving ENABLE pin of RS485 chip. |
这似乎是因为TIM2_CH1,它可以映射到PD4。调查正在进行中=)
以上来自于谷歌翻译 以下为原文 It seems that's because of TIM2_CH1, which could be mapped to PD4. Investigation is in process =) |
解决了。默认情况下,TIM2_CH1输出映射到PD4。我必须通过设置AFR0选项位将此输出重新映射到PC5。
以上来自于谷歌翻译 以下为原文 Solved. TIM2_CH1 output is mapped to PD4 by default. I had to remap this output to PC5 by setting AFR0 option bit. |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1447 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1494 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3641 浏览 1 评论
3834 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2454 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
658浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
940浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
744浏览 5评论
/9
GMT+8, 2025-12-1 19:41 , Processed in 0.640311 second(s), Total 46, Slave 39 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2806
