我们目前的设计将外部时钟晶体连接到P12〔0〕。当与任何芯片资源一起使用时,时钟似乎不起作用。事实上,即使我把它返回到一个输出引脚,它只是坐在高处。当把这个时钟连接到P3管脚上时,我能很好地使用它。我知道P12引脚是SiO…它们需要特殊类型的设置吗?我在另一篇文章中读到,如果输入缓冲区没有启用PIN,就会出现问题。当我更正时,我能看到P3针上的时钟,但是P12针上仍然没有骰子。我目前有PIN设置为数字输入,HW连接,高阻抗数字。我也有CMOS阈值和输入缓冲区启用。
你知道问题是什么吗? 以上来自于百度翻译 以下为原文 Our current design connects an external clock crystal to P12[0]. The clock does not seem to be working when used with any of the chip resources. In fact, even if I route that back to an output pin, it is just sitting high. When wiring this clock to a P3 pin, I am able to use it just fine. I understand that the P12 pins are SIO...do they require some special type of setup? I read in another post that there was an issue if the input buffer was not enabled for the pin. When I corrected that, I was able to see the clock on the P3 pin, but still no dice on the P12 pin. I currently have the pin set up as a digital input, hw connection, high impedance digital. I also have CMOS threshold and input buffer enabled. Any idea what the problem might be? |
1个回答
只有小组成员才能发言,加入小组>>
726个成员聚集在这个小组
加入小组1938 浏览 1 评论
1685 浏览 1 评论
3448 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1606 浏览 6 评论
1404 浏览 1 评论
GMT+8, 2024-6-26 08:45 , Processed in 0.733771 second(s), Total 78, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
