电子发烧友论坛|
你好,
我将一个LED连接到一个LED上,我想设置LED闪烁1秒,闪烁。但是1分钟后LED停止工作,PWM也开始工作。 即使我让我的代码闪烁1分钟,LED闪烁仅1秒。 请帮助我解决这个问题 寻找附件 提前感谢。 交换机,CyWrk.CaseV01.Zip 3.9兆字节 以上来自于百度翻译 以下为原文 Hi, I am interfacing an ble to one led , i want to set blink the led for 1sec,it's blinking.but after 1 minute led stops working and pwm also starts working... Even if i make my code to blink led for 1 minute ,the led blinking for 1 sec only. please help me to resolve the issue find the attachment Thanks in advance.
10个回答
你好,
请不要为同一问题创建许多帖子。 我相信你的问题在于广告的超时。你已经设定了30秒快速广告,然后30秒慢广告(见图)。在一起,你有1分钟的超时时间。 1分钟超时后会发生什么?您的代码具有以下内容: CyByLyEvtgpppAuthSmithEngestSturt停止: 如果(CyBythStayeOxDebug== CyByLyGestStand()) { 广告宣传写作(Redion); CysLyGabPopStudioStand(); CysSpMiHiBiNATE(); } 所以你的系统在一分钟的广告之后休眠。当休眠系统关闭时,你的定时器/PWM / WDT将停止工作。 这个问题的解决方法取决于你的设备的用途。 你可以关闭BLE设置中的超时时间,但是你的设备会永久地做广告,当不需要时,它可以使用大量的电源。 您可以添加一个按钮来再次启动广告,并从超时中删除Hibernate函数。 当做, 以上来自于百度翻译 以下为原文 Hello, Please do not create many posts for the same issue. I believe your problem lies with the BLE Advertisement timeout. You have it set to 30 seconds fast advertising and then afterwards 30 seconds slow advertising (See picture). Together you have a 1 minute timeout. What happens after this 1 minute timeout? Your code has the following: case CYBLE_EVT_GAPP_ADVERTISEMENT_START_STOP: if(CYBLE_STATE_DISCONNECTED == CyBle_GetState()) { Advertising_LED_Write(LED_ON); CyBle_GappStopAdvertisement(); CySysPmHibernate(); } So your system hibernates after one minute of advertising. While hibernating the system turns off and your Timer/PWM/WDT are going to stop working. The solution to this problem depends on the purpose of your device. You could turn off the timeouts in the BLE settings but your device will permanently advertise, which could use a lot of power when it is not needed. You could add a button to start advertising again and remove the Hibernate function from the timeout. Regards, |
您使用的是深度睡眠模式,其中高频组件不运行。
鲍勃 以上来自于百度翻译 以下为原文 You are using deep sleep mode where the high frequency components do not run. Bob |
谢谢您的回复,先生。 我做了一个低功耗实现()API,然后评论设备如何进入深度休眠模式。 以上来自于百度翻译 以下为原文 thanks for your reply sir. i made a lowpowerimplementation() api as commented then how device go to deep sleep mode |
我正试图将LED闪烁1秒,但LED闪烁2秒。 请帮帮我 Time.CyWrk.CaseV01.Zip 2兆字节 以上来自于百度翻译 以下为原文 i am trying to blink an led exactly for 1 sec but led blinks for 2sec . please help me
wang_901218 发表于 2018-11-13 17:31 我正试图将LED闪烁1秒,但LED闪烁2秒。 请帮帮我 Time.CyWrk.CaseV01.Zip 2兆字节 以上来自于百度翻译 以下为原文 i am trying to blink an led exactly for 1 sec but led blinks for 2sec . please help me
wang_901218 发表于 2018-11-13 17:31 谢谢你的回复先生 我制作了CysSpMiHiBurnEnter();如注释,现在它正在工作。 再次感谢大家。 以上来自于百度翻译 以下为原文 thanks for your reply sir i made CySysPmHibernate(); as commented ,now it,s working. once again thanks alot. |
请参阅定时器数据表以解释“时段”。在你的情况下必须设置为0。 鲍勃 以上来自于百度翻译 以下为原文 See timer datasheet for explanation of "Period". Must be set to 0 in your case. Bob |
你能告诉我计算所需时间的公式吗? 我为PIC控制器工作 回放时间=预分频器*周期*(1/f) 在PSoC4的情况下,计算时间周期的公式是什么? 以上来自于百度翻译 以下为原文 can you tell me the formula to calculate the required timeperiod. i worked for pic controllers in that reuired time=prescaler*period*(1/f) in case psoc4 bles what is the formula to calculate the time period |
wang_901218 发表于 2018-11-13 17:31 你能告诉我计算PWM周期的公式吗? 提前感谢。 以上来自于百度翻译 以下为原文 can you please tell me the formula for calculating dutycycle of PWM. Thanks in advance. |
您好! 请参考此& lt;HTTP://www. CyPl.com /Fiel/220361/Sudio&Gt; 最佳问候 以上来自于百度翻译 以下为原文 Hi Please refer this < http://www.cypress.com/file/220361/download > Best Regards, VSRS |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7220 浏览 0 评论
2482 浏览 1 评论
2174 浏览 1 评论
4037 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2082 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7724浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6280浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
750浏览 2评论
725浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
8119浏览 2评论
/9
GMT+8, 2025-12-8 08:48 , Processed in 0.966336 second(s), Total 92, Slave 75 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
823
