奥斯威德只能在超大规模/超大规模的8:1 ddr +你需要在你的结构中使用某种齿轮箱来取10位字并使它们成为8位
-------------------------------------------------- -----------------------不要忘记回答,kudo,并接受为解决方案.------------- -------------------------------------------------- ---------- 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 The oserdes only does 8:1 ddr in ultrascale/ultrascale+ You will need some sort of gear box in your fabric to take 10 bit words and make them 8 bits------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. -------------------------------------------------------------------------View solution in original post |
-------------------------------------------------- -----------------------不要忘记回答,kudo,并接受为解决方案.------------- -------------------------------------------------- ---------- 以上来自于谷歌翻译 以下为原文 The oserdes only does 8:1 ddr in ultrascale/ultrascale+ You will need some sort of gear box in your fabric to take 10 bit words and make them 8 bits------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
尝试使用40位输入和8位输出的变速箱组件:
https://github.com/VLSI-EDA/PoC/blob/master/src/misc/gearbox/gearbox_down_dc.vhdl 这将需要MMCM / PLL提供3个时钟,周期比为1:8:40 不要忘记通过接受帖子作为解决方案来尽可能地关闭线程。 以上来自于谷歌翻译 以下为原文 Try this gearbox component, with a 40 bit input, and 8 bit output: https://github.com/VLSI-EDA/PoC/blob/master/src/misc/gearbox/gearbox_down_dc.vhdl This will require an MMCM/PLL to provide 3 clocks, with period ratios of 1:8:40 Don't forget to close a thread when possible by accepting a post as a solution. |
我需要将10位转换为8位。
谢谢你们! 以上来自于谷歌翻译 以下为原文 I need to convert 10 bit to 8 bit. Thanks all the same! |
你没有因为树木而看到森林...拿你的10位数据流...比如100 MHz ......这是1 Gbit / sec
现在将100 MHz的10位转换为25 MHz的40位..再次使用从属时钟变速箱.. 现在将25 MHz的40位转换为125 MHz的8位。 你仍然有1 Gbit / sec ..然后运行8位到OSERDESE3你已经完成.. 1 Gbit / s输出.. 你需要的时钟: 100 MHz,25 MHz,125 MHz和500 MHz。 单个MMCM可以做到这一点,VCO运行在1500 MHz。 然后MMCM中的分隔符是15,60,12和3.完成。 QED。 不要忘记通过接受帖子作为解决方案来尽可能地关闭线程。 以上来自于谷歌翻译 以下为原文 you aren't seeing the forest because of the trees... Take your 10 bit data stream... say at 100 MHz.. which is 1 Gbit/sec Now convert from 10 bits at 100 MHz to 40 bits at 25 MHz.. again using a dependent clock gearbox.. Now convert 40 bits at 25 MHz to 8 bits at 125 MHz. Still you have 1 Gbit/sec.. then run the 8 bits to the OSERDESE3 and you are done.. 1 Gbit/s output.. Clocks you will need: 100 MHz, 25 MHz, 125 MHz, and 500 MHz. A single MMCM can do this, with the VCO running at 1500 MHz. Then the dividers in the MMCM are 15, 60, 12, and 3. Done. QED. Don't forget to close a thread when possible by accepting a post as a solution. |
只有小组成员才能发言,加入小组>>
2416 浏览 7 评论
2821 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2292 浏览 9 评论
3372 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2458 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
1120浏览 1评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
581浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
447浏览 1评论
2002浏览 0评论
725浏览 0评论
GMT+8, 2024-12-21 17:52 , Processed in 1.642368 second(s), Total 86, Slave 69 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
