你好
我正在使用ISE Design Suite进行设计,而在翻译一个设计时出现以下错误。 FATAL_ERROR:PersonalityModule:baspmdlm.c:168:1.27 - dll库不存在。 请告诉我这个错误的可能原因。 问候 以上来自于谷歌翻译 以下为原文 Hello I am using ISE Design Suite for my design, and while Translating one design I got the following error. FATAL_ERROR:PersonalityModule:baspmdlm.c:168:1.27 - dll library does not exist. Can please let me know the probable cause of this error. Regards |
8个回答
我尝试从头开始重建项目它没有用,甚至其他项目也显示类似的错误。
但是在重新安装ISE相同的版本后,它得到了解决。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 I have tried rebuilding the project from scratch it didn't worked and even any other project is also showing the similar error. However after re-installation of ISE same version it got resolved. View solution in original post |
@mjuneja,
在ISE GUI中,选择Project - >清理项目Files并重新运行综合 --Syed -------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 @mjuneja, In ISE GUI, select Project-->Clean up the project Files and rerun the synthesis --Syed --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. --------------------------------------------------------------------------------------------- |
@syedz
我尝试过,但没有奏效。 还是一样的错误。 mjuneja 以上来自于谷歌翻译 以下为原文 @syedz I tried that but it didn't worked. Still the same error. mjuneja |
@mjuneja,最好提供尽可能多的信息。
或者,如#35083中所述,此问题可能是由于安装损坏引起的,可能是在安装工具时没有足够的磁盘空间。 我建议尝试通过最新版本的ISE 14.7运行设计。 -------------------------------------------------- -----------------------不要忘记回答,kudo,并接受为解决方案.------------- -------------------------------------------------- ---------- 以上来自于谷歌翻译 以下为原文 @mjuneja, it's best to provide as much information as possible. Alternatively, as stated in AR# 35083, this issue can be caused by a corrupt installation, possibly if there wasn't enough disk space when installing the tools. I would suggest try running the design through the latest version of ISE, 14.7. ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
@peadard实际上对于这种情况我在下面描述我使用的ISE设计套件版本14.7(nt64)我已经安装了很久(大约一个月前)。
之后我一直在使用它而没有任何问题。 直到今天我才第一次看到这个问题,我不知道它是如何起源的。 将重新安装ISE解决此问题.. 如果需要任何其他信息来解决此错误,请与我们联系。 以上来自于谷歌翻译 以下为原文 @peadard Actually for this case I have described below I am using ISE design suite version 14.7 (nt64) which I have installed long back (around a month ago). After that I have been using it without any issue. Only today I have seen this problem first time for which I have no clue how it originated. Will re installation of ISE solve this issue.. Please let me know if any other information is required to resolve this error. |
@mjuneja,感谢您提供的信息。
在重新安装之前,尝试从头开始重新构建项目,然后通过工具重新运行新项目。 很难说重新安装是否会解决问题,但根据AR,它会! -------------------------------------------------- -----------------------不要忘记回答,kudo,并接受为解决方案.------------- -------------------------------------------------- ---------- 以上来自于谷歌翻译 以下为原文 @mjuneja, thanks for the information. Before re-installing, try re-building the project from the scratch, very beginning, then re-running it through the new project through the tools. It's difficult to say whether a re-installation will resolve the issue however, according to the AR, it will! ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
但是在重新安装ISE相同的版本后,它得到了解决。 以上来自于谷歌翻译 以下为原文 I have tried rebuilding the project from scratch it didn't worked and even any other project is also showing the similar error. However after re-installation of ISE same version it got resolved. |
@mjuneja,这是一个好消息,很高兴你现在可以继续设计。
希望在重新安装后你不会再遇到问题:) -------------------------------------------------- -----------------------不要忘记回答,kudo,并接受为解决方案.------------- -------------------------------------------------- ---------- 以上来自于谷歌翻译 以下为原文 @mjuneja, that's somewhat good news, glad you can now continue with the design. Hopefully, after the reinstallation you won't again encounter the issue :) ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2873 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-2 02:40 , Processed in 2.113080 second(s), Total 88, Slave 71 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3488
