我的系统NUC7i5DNH是远程无人值守的。
通常我没有通过ME远程桌面更新BIOS更新 - 直到今天。 尝试更新到DNKBLi5v.86A.0053.2018.0903.2245与FwUpdateFullBuffer失败。 这是我尝试通过MeshCommander闪存时所拥有的。 问题是什么。 在这种情况下有没有办法刷新BIOS(无人值守的远程系统只能通过网络访问) 亲切的问候, 克里斯 以上来自于谷歌翻译 以下为原文 My system NUC7i5DNH is remote and unattended. Normally I had no issues BIOS updating via ME Remote Desktop - until today. Trying to update to DNKBLi5v.86A.0053.2018.0903.2245 fails miserably with FwUpdateFullBuffer. This is what I've got when trying to flash via MeshCommander. What is the problem. Is there any way to flash BIOS in this case (unattended remote system accessible only via network) Kind regards, Chris |
3个回答
克里斯,
当您看到此错误时,您需要使用BIOS恢复方法安装新固件(BIOS更新包)。 不幸的是,使用这种方法绝对需要物理机器访问。 目前,英特尔已经取消了对Windows内部启动BIOS更新的支持。 没有解释为什么这是必要的。 他们所说的只是他们在设施中发现了一个严重的问题,在这个问题得到解决之前,不会支持这种能力。 对这样的基本功能进行更改非常复杂且耗时(尤其是在所有各种NUC BIOS版本中进行验证)。 我完全相信,在再次提供此功能之前,将需要几个月(是的,几个月)。 抱怨这一点并没有帮助。 它需要很长时间才会采取,而且你可以说会加快速度。 很抱歉这会造成不便,但这是现实情况。 再一次,抱怨不会有所帮助。 请不要这样做。 内容S 以上来自于谷歌翻译 以下为原文 Chris, When you see this error, you need to install the new firmware (BIOS update package) using the BIOS Recovery method. Unfortunately, using this method absolutely requires physical machine access. At present, Intel has withdrawn support for the ability to initiate BIOS updates from within Windows. No explanation as to why this was necessary has been provided. All they are saying is that they have found a serious issue in the facility and, until this issue can be addressed, the capability will not be supported. Making changes in a fundamental capability like this is very complicated and time consuming (especially its validation across all of the various NUC BIOS releases). I fully expect that it will be some number of months (yes, months) before this capability is again provided. Complaining about this is not going to help. It is going to take however long it is going to take and NOTHING you can say will speed this up. Sorry for the inconvenience this causes, but this is the reality of the situation. Again, complaining is not going to help. Please don't do so. ...S |
亲爱的斯科特, 如果我不够精确,我很抱歉。 我不是试图从Windows刷新BIOS。 一点也不。 我是通过Mesh Commander AMT远程KVM服务来实现的 - 这总是有效的,这实际上是去vPro系统的原因之一。 有问题的BIOS更新没有警告它需要使用BIOS恢复方法安装(这发生在你记得的过去,但现在不是)。 这就是为什么我现在在这里寻求帮助,认为一定有什么问题 - 也许其他人对这个BIOS版本也有同样的问题。 克里斯 以上来自于谷歌翻译 以下为原文 Dear Scott, I am sorry if I was not precise enough. I am not trying to flash BIOS from windows. Not at all. I am doing it through Mesh Commander AMT remote KVM service - and this always worked and that was actually one of the reasons to go for vPro system. The BIOS update in question does not have warning that it needs to be installed with BIOS recovery method (this happened in the pas as you remember, but not now). This is why I am asking for help here now thinking that there must have been something wrong - maybe others are having the same issue with this BIOS edition. Chris |
对不起,我确切地知道你在问什么,但有些事情需要说,你的查询提供了机会。 在发布之前,BIOS更新将作为多个级别进行详尽测试。 如果问题就像需要BIOS恢复一样简单,他们就会这么说。 如果他们在测试系统上发现了这个错误,他们就会拒绝发布。 不,这是您的系统特有的,恢复的方法是使用BIOS恢复。 所有这一切,事情发生了,事情滑倒了; 我会下来尝试更新我的DN,看看我是否看到同样的事情。 我会尽快更新你的... 内容S 以上来自于谷歌翻译 以下为原文 Sorry, I knew exactly what you were asking but some things needed to be said and your query presented the opportunity. BIOS updates are exhaustively tested, as multiple levels, before release. If the issue was something as simple as BIOS Recovery being needed, they would have said so. If they had seen this error occur on test systems, they would have rejected the release. No, this is something specific to your system and the way to recover is to use BIOS Recovery. All that said, stuff happens, things slip through; I will go down and try the update on my DN and see if I see the same thing. I will update you shortly... ...S |
只有小组成员才能发言,加入小组>>
/9
GMT+8, 2025-12-2 12:21 , Processed in 0.848222 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4020
